M2 Technical Topics > N55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > 2018 M2 Stage 2: Stumbling at High RPM?
      11-28-2021, 02:46 PM   #1
Nandohatesyou
Drives: 2020 MW M340i
Good afternoon, I've worked myself into a headache trying to figure out why my M2 begins stumbling at higher rpms. I've attached two logs (2nd gear WOT) to try and figure out the cause of the stumbling. Opinions anyone?
Mods currently: Race Intercooler (BMS), Catless DP, Upgraded CP, Turner Motorsports CF Intake, Stage 2 OTS ACN 91 Tune (BM3). Thanks Mike @ XPH!
Here's what I know so far (which doesn't say much):
1. It seems that when the stumbling occurs, my HPFP actual is quite a bit below the target.
2. It seems worse, more pronounced when I do it in DSC OFF than regular Comfort.
3. No knock is registered.
4. Stock spark plugs are on the car.
I believe the problems are around the HPFP, but again thats just my guess from looking at the logs. Is this a common issue with an n55 M2? My old M235i never had this issue, but I also had NGK .22 gapped plugs.
Here are the logs:
https://www.bootmod3.net/log?id=61a3...0b43123be407f4
https://www.bootmod3.net/log?id=61a3...0b43123be40807
2020 MW M340i
      11-28-2021, 06:04 PM   #2
Wolfman’s Brother
Wolfman’s Brother's Avatar
378
Something is up, to state the obvious and you’re right to be thinking HPFP as it’s not meeting target like you’ve already identified.
Was this in Sport+? Were you letting out when you detected the stuttering or breakup? I notice you shifted out around 5500….
How many miles on the car? How many miles on the plugs?
I’d be thinking about flashing back to the stock tune and seeing if it provides any relief, while also looking at HPFP upgrades and any Black Friday deals that Dorch may be offering.
Good luck getting it sorted.
      11-28-2021, 07:52 PM   #3
AdventureNoodle
Drives: F87 BMW M2 LCI
This same thing has been happening to me on the stage 2 multimap. The stand alone maps don't seem to have this issue. My buddy (samsamdar) with a catless stage 1 M2 manual is having the same issue as well on the stage 1 multimap ACN91. The standalone map seems to be perfectly okay though. I have NGK plugs gapped to .020 so I'm not sure it's a plug issue tbh. I do have a log with the stutter that I can post if required.
      11-29-2021, 10:10 AM   #4
Nandohatesyou
Yes, everything point's to that but I feel that more people would be reporting this issue if it was more prevalent amongst Stage 2 users..
I was in DSC OFF and yes I was letting off the throttle as I was scared as to what could happen if it fails lol, what can honestly happen if I push it hard and the fuel isn't being delivered?
I will flash to Stage 1, then back to Stock tune and will definitely be looking at Dorch, thank you!
2020 MW M340i
      11-29-2021, 10:12 AM   #5
Nandohatesyou
I'm going to try Stage 1 standalone and report back, never had this issue with my M235i
2020 MW M340i
      11-29-2021, 11:38 AM   #6
AdventureNoodle
Keep me posted!
      11-29-2021, 12:27 PM   #7
Nandohatesyou
Keep me posted!
Flashed to Stage 1 ACN, same issue. The fuel pump keeps up till around 4500 rpms when it just hits like a wall or something and crashes.
Dorch is having a 15% of sale and I might just pull the trigger on a HPFP from them.
Here is the log: https://www.bootmod3.net/log?id=61a5...0b4311b85e9f63
2020 MW M340i
      11-29-2021, 12:30 PM   #8
AdventureNoodle
Keep me posted!
Keep me posted!
You get the same misfire / stumbling issue? Yeah that's interesting as hell. Does it happen on the stock map too? If Dorsch has a sale definitely go ahead and upgrade
      11-29-2021, 12:42 PM   #9
Nandohatesyou
That'll be my last step before buying the upgraded HPFP.. anything on your end? It's odd because its keeping up right till 4500RPM and it's driving me nuts lol!!
2020 MW M340i
      11-29-2021, 12:44 PM   #10
AdventureNoodle
Keep me posted!
Since I switched to the stage 2 stand alone maps I have had no issues
      11-29-2021, 01:00 PM   #11
Nandohatesyou
Anyone* else have any input or ideas?
2020 MW M340i
      11-29-2021, 04:43 PM   #12
Nandohatesyou
Ended up ordering a Stage 1 HPFP from Dorch.
2020 MW M340i
      11-29-2021, 05:15 PM   #13
Wolfman’s Brother
378
How many miles are on your car?
      11-29-2021, 05:58 PM   #14
Nandohatesyou
About to hit the 40k mile mark, I had 50k on my M235i Stage 2 for 28k of those miles and no issues
2020 MW M340i
      11-29-2021, 06:31 PM   #15
Wolfman’s Brother
378
Really appreciate you sharing as it gives others like myself a look at what they can expect.
How many of those 40k were tuned?
The upside here is once upgraded you’re clear for E30 or if not near E85, more power with a custom tune that can take advantage of the additional fuel flow.
If I’d ordered a Dorch I’d be emailing Bend Calibration next
      12-29-2021, 08:50 AM   #16
AdventureNoodle
I got the Dorch stage 2 pump and it fixed all my stumbling issues hahah. I got the stage v2 cause I plan on running full E85 on the stock turbo and maxing it out till it blows, then going big turbo
      12-29-2021, 02:48 PM   #17
rtl32
Drives: M235i 6MT
I also had the same issue, around 40k I started stumbling high rpm, mid pull gunshots and burbles on Stage 2 93. Forget about trying E on that. Upgraded to Dorch stage 1 and the issue is completely resolved. Does come back above E40 though.
14' Alpine White M235i 6MT, BM3 Stg2+, VRSF DP-CP-FMIC, Dinan Muffler, GFB DV+, 3.5 bar MAP, Dorch Stg1 HPFP, NGK 97506, BM3 Flexfuel Kit, CDV delete, KW V3, EDC delete, Powerflex Camber LCA bushings, VMR 801 18x8.5/9.5 et45, Conti Extremecontact 235/265
Next step: M2 Competition or Manual Supra MKV build Summer 2022
      02-02-2022, 10:31 AM   #18
Nandohatesyou
Correct, I also upgraded to Dorch Stage 1 and it solved my issue, except as you stated when I go overboard on E it resurfaces lol.
2020 MW M340i
      02-02-2022, 02:24 PM   #19
Wolfman’s Brother
378
I’m at 15k miles. Sounds like I may need to start a Dorch stage 2 fund.
      02-02-2022, 04:54 PM   #20
Nandohatesyou
I would honestly opt for the Stage 2, Stage 1 your E85 usage will be very very limited..
2020 MW M340i
      02-02-2022, 05:32 PM   #21
rtl32
Drives: M235i 6MT
Stage 1 has been working well for me up to mid/high 40% on Stage 2+ multimap version 1.2 with the revised 29xx psi pump targets. Big improvement over barely being able to go above 30% on the previous 24xx psi targets of the non-customrom Stg2+ E30 or earlier multimaps.
      02-03-2022, 11:04 AM   #22
Nandohatesyou
Around how many gallons of E85 would you estimate that is?
2020 MW M340i
