M2 Technical Topics > S55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > Center Armrest Vibrations Driving Me Crazy!
      10-28-2021, 07:49 AM   #1
Tupps11
Drives: BMW M2 Competition
It's so annoying that I'm forced to leave it open (vertical) because at low RPM in 2nd, 3rd, & 4th gears the deep exhaust note makes it buzz non stop.
Only other solution is to put all the weight of my right elbow on it which is starting to hurt.
Anyone have the same issue, and if so, what did you do to resolve it?
Car is M2C manual and i have OEM downpipes/cats, AA single mid pipe, and AA valved axle back muffler.
      10-31-2021, 11:15 AM   #2
RD85
Drives: '13 Subaru BRZ
I have completely stock '21 M2C, and have zero rattle. I'd look at taking it in, but unless you have a nice dealer, they'll just blame the exhaust mods.
You might be able to fix descreetly with a bit of well placed black foam though.
      11-05-2021, 02:13 PM   #3
SilverM2_CS
Drives: M2 CS, 2011 135i Convertible
What's a center arm rest?
to_riffic3023.50
      11-06-2021, 08:11 AM   #4
hlm2c
Drives: M2C
Perhaps the midpipe is making contact with the center brace under heavy load, which is leading to buzzing noises and vibrations into your cabin. The clearances between the midpipe and center brace are tight, so I would recommend re-examining and adjusting your exhaust to make sure you have adequate clearance between the midpipe and center brace.
      11-14-2021, 07:19 AM   #5
Finz
Finz's Avatar
Drives: 02 M Coupe, MY20 M2C ED Sept
2020 M2C  [0.00]
I have the same setup and no arm rest vibration at all.
Bill
2020 M2C 6MT SO
      11-14-2021, 08:27 PM   #6
M3R1
Drives: ///M2cs
https://f87.bimmerpost.com/forums/sh....php?t=1847498
BSM ///M2cs, 6spd
      08-30-2022, 10:09 AM   #7
Tupps11
So its been months. I made sure the exhaust has good clearance on all sides.
It's clearly not that.
I basically gave up. Started driving faster and more aggressive. The higher/louder the RPM, the less i hear the noise.
Until my wife gets in the passenger seat on Sunday and notices the rattle/vibration.
After asking what's causing that noise, she very casually reaches to the arm rest, lifts it open, and places her finger down on the stupid wireless charger that i never ever use.
The second she pressed down on it, it stopped!
Now that its diagnosed...how the hell do i get rid of it? Has anyone removed the wireless charger from inside the arm rest?
      08-30-2022, 08:25 PM   #8
chris719
Drives: '08 M Roadster
There are a bunch of threads on removing it I think. I don't have a link handy but I was pretty sure you can just rip it out. I would check before you do this, however.
      08-31-2022, 01:58 AM   #9
Tupps11
Once removed correctly, are you left with a hole?
Or is there some sort of part/accessory that fills the gap?
      09-08-2022, 02:15 PM   #10
Swish77
Swish77's Avatar
Drives: M2 Competition '21
Yes, and this could be what you need.
https://www.ecstuning.com/b-genuine-...gaAonHEALw_wcB
      09-09-2022, 04:49 AM   #11
Tupps11
Thank you! Looks like a good solution.
Anyone know how to take out the wireless charging component?
Instructions or a manual would be great.
      09-09-2022, 12:03 PM   #12
Swish77
Swish77's Avatar
Different car but same approach:
https://f30.bimmerpost.com/forums/sh....php?t=1051389
      09-25-2022, 09:03 PM   #13
m2c_6mt
Drives: 2021 M2 Competition
Try moving the armrest to the forward position. I get a creak when it's moved aft, but when I move it forward it's silent...
      09-26-2022, 08:22 PM   #14
Toroinu
Drives: BMW M2c, BMW 528i, Audi RS5
Mine creaks if I rest my arm on it. Keeping it forward feels like it’s “too forward” and not natural.
I heard you can apply some dry lube to the hinges. Might give it a shot but for now I got use to it
