10-25-2021, 02:24 PM | #1 |
Rep 53
Drives: 2021 M2C
19X10.0" 788M on front of M2C
Is it possible to mount 19x10.0" 788M's to the front of an M2C? Are any modifications, spacers, or camber adjustments required?
Background: I have a M2C with 2NH brakes, stock suspension, and do not plan to make changes to this. This is my daily and is only being driven on street. I would like two sets of wheels and tires, one for winter, and the other for the remainder of the year. I would also like a square setup for both sets so that I can rotate the tires from corner-to-corner. I currently have Michelin Pilot Sports in 245/35/19 and 265/35/19 mounted on 19x9.0" 788M (front) and 19x10.0" 788M (rear) wheels. I am trying to figure out if I can mount a set of rear 19X10" 788M wheels to the front of my M2C and my searches so far haven't verified if it can be done. My idea was to try to find another set of 788M's and use those to create two square sets of wheels/tires. I would use the four 19x9.0" for my winter set and the 19x10.0" as my summer set (with my two 265/35/19 Michelin PSS's and buying two more of them). It doesn't look like there are any issues mounting the front 788M's to the rear of the car. I have read Apex's fitment guide and a lot of posts on here. It seems that in order to go above a 255 width in the front, people are using a 19x9.5" wheel with a 265/30 or 275/30 sized tire. It looks like the aspect ratio is being dropped from 35 to 30 to make wider tires & wheels fit on the front of M2C's. So is it possible to fit a 19x10.0" 788M on the front with a 265/35/19 tire? Or can a 265/30/19 be used? |
10-26-2021, 02:31 AM | #2 |
Rep 1,977
Drives: 2020 M2C HS & Ferrari Roma
The offsets won't work.
The front wheels are 19x9 +29 and rears are 19x10 +40 Very rarely do you see anyone fit a +40 offset up front.
2020 M2 Competition | Hockenheim Silver | 437M Wheels / 763M Wheels | RHD | 2NH Brakes OEM M2 CS Steering Wheel | MP Carbon Steering Wheel Trim | MP Pedals | MP Dash | MP Interior Kit OEM M2 CS Bonnet | M Performance Coilovers | MP Rear Spoiler | MP Rear Diffuser| Perl Carbon Front Lip | Remus Race Exhaust |
Yetti83.00 |
11-08-2021, 01:47 PM | #4 |
Rep 53
Drives: 2021 M2C
Thanks for the responses. It looks like it isn't straightforward and I didn't want to spend time testing out spacers and maybe eventually getting it to work. So I decided to buy a set of 19x9 Apex EC-7's in Anthracite for my winter set and will keep the 788M's for my summer set for now (will probably change to something different once the summer tires wear down as I hate cleaning the 788's).
