10-24-2021, 06:17 PM | #1 |
Rep 1,244
Drives: 2017 Big Turbo BMW M2
Hey guys, so I'm looking to potentially upgrade my adaptive pre LCI xenon headlights to OEM LCI retrofitted OSS Design LED headlights but had questions about the install. Since he has OEM LCI retrofitted headlights, doesn't that mean I still have to buy the Control Unit For Front Light Electronics, LED Daytime Running Light Modules, and LED headlight fans. Does anyone know if these are needed or if it's just plug and play ?
Thanks, Shane |
10-25-2021, 04:34 AM | #2 |
844
Rep 1,962
I imagine this is going to be a seriously expensive project unless you've found a late model car with an intact front end in a Breakers. In which case - buy everything you might need in one go - and eBay it if you don't.
10-25-2021, 10:28 AM | #3 |
Rep 1,244
update: apparently I need new LCI modules and a coding cable which isn't being sold anymore so I don't think this will work unless I find one for sale or a coder
10-26-2021, 11:14 PM | #4 |
Rep 360
I don't understand some of these conclusions, but the cost of retrofitting the LCI headlamps is pretty prohibitive. Plus it creates a potentially really big headache on the backend.
1) You don't need a whole front clip. You need the lamp assemblies and modules, but they physically fit the pre-LCI, so not sure why you'd want the front part of the car. 2) I don't know what this "coding" cable is, but the headlights never needed a special cable or anything that wasn't available or isn't currently available. That said, it's not just flipping some factory options ala BimmerCode or the like. It's updating modules in factory based software. But, none of that is the issue, outside of cost. Just like replacing the cluster, or even the amp, the headlights have associated modules that are assigned to the car. You can tell the car that it has the new modules, but if a factory software fix is required, it expects the original modules. If you ever need them to update anything software related on the, even for something completely unrelated, you have to have the original modules attached. Original amp gets fried and you want to replace it? BMW can't do it with your LCI headlamps installed. Etc. How likely is it...I don't know, probably not highly, but you're really putting yourself in a corner if you swap out any of the "smart" parts in the car...
Current:
2017 F87 M2 6MT 2013 F25 X3 3.5i 2008 E90 M3 6MT |
10-26-2021, 11:26 PM | #5 | |
Rep 1,244
10-27-2021, 12:17 AM | #6 |
Rep 360
I guess I don't understand, fair. And really, I'm not trying to be dismissive; I have a pre-LCI and, I really wish I had the LCI headlights.
I was just warning you of the issue that many people didn't expect. Any headlight that isn't the headlight that came with the car is going to create issues if you ever need the dealer to do anything that requires updating the software in an electrical module. That would be the case if you used an OEM LCI headlight, or if you bought a OSS Design OEM LCI headlight. People replaced the amp and ran into the same issue. Go to the dealer and they're completely out of luck unless they still have the old amp handy to plug in so that the computer gives it the okay. I was just saying, hey, be aware of the issue. Some people really got screwed upgrading to the LCI cluster as well. I think the LCI retrofit, even with all OEM parts, and the best coding in the world still presents risks. I will not speak for IND, but they don't advertise the kit for sale anymore. If it's me, I'd have OSS do their mods to a pre-LCI headlight, swap that in with factory modules from your car and know I was never going to have an issue.
Current:
shaneguags1191.00 |
10-27-2021, 12:21 AM | #7 | |
Rep 1,244
WagonR293.00 |
10-27-2021, 02:22 AM | #8 | |
844
Rep 1,962
As you say otherwise, unless it's similar to seat swapping where provided you use the original seat modules the car has no problems as to what seat is actually fitted (so your airbags and SRS still work) and firmware updates don't require swapping parts. |
WagonR293.00 |
10-27-2021, 11:01 AM | #9 | |
Rep 360
It may be cheaper to buy a set of headlamps with modules from a breaker, it might be cheaper to buy them already taken off the car. That probably depends on the seller? Just for reference. Here's a diagram of the lamp and modules: 1 is the headlamp control unit 2 is the LED daytime module 3 is the fan Here's a random headlamp for sale on ebay: It has all of the modules attached. Here's one where someone stripped the modules:
Current:
10-27-2021, 11:14 AM | #10 | |
Rep 360
Not trying to discourage, but I think the issue described there would be an issue for the cluster too. I can't find where I read it, but there were people who did the LCI cluster upgrade, had something else fail, and the dealer couldn't help because they needed to update the car's software and factory software didn't recognize the non-original part. I think if you do the cluster, you can just keep your original one, and then in that case, would just need to plug the original cluster in and then the car would recognize it as the the original one, do the software update to fix the unrelated issue, then you'd just need to re-code the updated software for the LCI cluster. No the biggest deal, just making sure you're aware. I think someone sold the original cluster, had an issue with something unrelated, and it created quite the headache to sort out.
Current:
shaneguags1191.00 |
10-27-2021, 08:20 PM | #11 | ||
Rep 1,244
