10-06-2021, 09:48 AM | #1 |
Rep 94
S55 FBO stage 2.5 braided Snow Performance meth kit install!
Any questions feel free to drop here. Just completed my second installation on a 2series. Last install was more stealthy but here is my setup as is today. Pending: 1. Re-seal solenoid lines as I found a leak 2. Some cable/piping management to make it more presentable and tidy. 3. Dyno tune it. 4. Modify the trunk flat thingy for tank and pump clearance. 5. Get a boost gauge holder |
10-07-2021, 08:23 AM | #3 |
24093
Rep 190,630
methkingM2C87.50 |
10-07-2021, 08:43 AM | #4 | |
Rep 142
Water Injection : Similar to M4 GTS Setup
Really interested in your stealth installation as I’m looking at a Pure Water Injection System for my M2 Cs similar to the M4 GTS BMW Factory Install . It would good if we could see more photos of the Water Meth Pipe run under the vehicle etc . Much Appreciated Cheers Bruiser |
methkingM2C87.50 |
10-07-2021, 10:20 AM | #5 | |
Rep 94
This is the setup I used for the thank in my M235i few years back. I had to remove the foam holding the suspension ECU. The 2.5 gall fit snug. Also had to stuff some padding beneath the tank so the pump inlet could sit below the tank exit. Also had to drill 1 hole for that braided line from tank to pump. |
12-03-2021, 02:14 AM | #7 |
Rep 1,074
Nice! I'll be running the BMS kit. I ran the snow performance kit on my 428 and loved it. I went with M1 and mixed my own distilled water with it for a 70/30 or 80/20. I just got the crankhub so I'll be running 28psi on the stock turbos hoping for 560-570 wheel. Beautiful dyno curve btw. Holds power. Almost looks like the stock curve but with more power. Is this what you were going for?
Instagram: M2_Medusa
12-03-2021, 08:17 AM | #8 | |
Rep 94
I did crank hub and running the meth on the J pipe as seen above. I don't think you'll achieve the 560-570whp if it's only bung meth. Might need port injection or ethanol fuel mix. |
12-13-2021, 01:24 PM | #9 | ||
Rep 1,074
Keep us updated and can you post pictures under the hood of the lines attached? Sucks we can't run a full stealth kit like the M3/4 can cus of our battery but your creativity is inspiring. Great work! Looks super clean! Is that a 1 gallon tank?
methkingM2C87.50 |
12-14-2021, 07:15 AM | #10 | |||
Rep 94
Detoxified202.50 |
