07-16-2021, 08:00 AM | #3 |
Rep 1,917
Agreed! Should be a cool experience
Matt
07-17-2021, 03:24 PM | #5 |
Rep 1,917
It was definitely greasy later in the day, but felt nice after the sun went down. Night mode was awesome.
Matt
07-19-2021, 06:33 AM | #6 |
4693
Rep 2,541
The night driving was awesome. Been wanting to do that for a long time - definitely worth it!
Was interesting going from brake just inside the 150m board to now just inside the 4th board. I have always just used the numbers on the boards as reference - never had to count them like that since I could barely see the numbers now. Some pretty serious over braking at the beginning but got better towards the end
07-19-2021, 08:04 AM | #8 |
4693
Rep 2,541
07-19-2021, 10:38 PM | #10 | ||
Rep 340
Those little side lights look like they would light the apexes nicely. I thoroughly enjoyed the challenge of driving by memory and realized once a car in gets in front of you, even more concentration is required as most references are eliminated—I chuckled watching cars go way off line at 10, 15, and 20, and have people behind just follow them. |
07-20-2021, 08:16 AM | #11 | |
4693
Rep 2,541
I agree that is excellent practice in avoiding target fixation on the car(s) in front of you. Always something I remind myself of during racing in the day - can be easy to lapse into that trying to make a pass - at night if you do it seemed like it would be much easier to follow someone off line. Very good reinforcement in avoiding this. On the back straight one of the boards wasn't lit up very well - that was what I used to count from. On the first out lap I just went whaaaatttt - why no numbers???? Good practice though in working on being able to adapt quickly. Saw (and guilty of) a lot of early apexes at 10. 15 was ok - mixed bag in the group. 19 and 20 would get some over slowing (probably 19 more than 20 in that group). Fun night though. We were on stock power level for the M3 and still turned some decent times. Was always fun working through the twisties and then having the other cars in the group just leave me in the dust on the straights M1500Z congrats on the PR
mcvaughan704.00 |
07-20-2021, 12:38 PM | #12 |
Rep 340
Thanks, OG Shark! It was a 2:34.666 #metal. I'd love to say I'm thrilled, but I'm not—this was the first time on the 275 squared setup (Goodyear SC3) and new brakes (AP/DS3.12) and I know there's a good bit more time in the car, even on these 220 tires.
Something I found interesting is on the 245/265 setup, I was scrubbing the outside shoulder pretty good on proper tire pressures. With the 275 square setup, either the track, or my driving style is not loading up the fronts enough to wear that outside very much at all. My hypothesis right now is I need more time to adapt to the neutral setup and balance the car better in order to maximize entry and mid-corner speeds. Last edited by M1500Z; 07-20-2021 at 12:43 PM.. |
07-20-2021, 05:38 PM | #13 | |
4693
Rep 2,541
275 square is a great track setup - might consider the Nitto NT01's if you haven't already & have a dedicated set of track wheels. Awesome track day tire. Not sure when you set your last PR - but was plenty hot & humid out there Friday. Not real beneficial for power, especially on a turbo car... Just might take a bit of time too like you said to get used to the square setup. Could you feel a reduction in understeer & increase in grip?
M1500Z423.00 |
07-21-2021, 10:56 AM | #14 | ||
Rep 340
Earlier in the day, the car just felt really loose at the rear coming out of 2 and 18 and that was not confidence inspiring. Again, new tires so maybe that was it, but it really felt like any little throttle wanted to induce a little slip to the rear and I'd rather not have a oversteer moment at 18 (or at the bottom of 2 for that matter). I've got an Aim Solo 2 DL if anyone wants to swap data files. |
OG Shark4692.50 |
07-21-2021, 01:35 PM | #15 | |
Rep 427
So far, they just don’t seem to be that grippy of a tire compared to other 200ish TW tires I’ve run. If you’re chasing times, there are better choices. What were you running before? I do like their durability though. A friend got 9 days on a set earlier this season on his M2 with less than 2 degrees of camber, and said grip level was consistent to the cords. I’m on day 6 or 7 and they still seem to be delivering similar times to when I put them on, and I think I’ll get another day or two out of them (our driving styles are a bit different, so I expect less life than he gets). I’d be interested to hear what you think of the 3R if you try them. I’ve considered throwing a set on. |
07-21-2021, 06:20 PM | #16 |
Rep 1,917
I ran the 3R and was very pleased with the grip. My favorite tire at the moment but have not tried the AR-1.
Matt
07-21-2021, 08:06 PM | #17 | ||
4693
Rep 2,541
Something to consider on T1 - who was able to get back to full throttle faster - you or your friend? T1 is kind on an odd corner - actually doesn't hurt to spend some time coasting. For me the priority is how fast I can get back to full throttle even if that means sacrificing a bit of entry speed. I can go quick to wot at the apex based on how I setup for the entry - want to be rotated and ready to run down that stretch to the S's wide open. So would just compare your exits as well - make sure that the increased speed for your friend is beneficial in the long run. Could be carrying more speed at apex but takes longer to get back to wot. Sliding through the faster turns like that - definitely could produce some puckering. Maybe bentom2 has the right idea with the pressures. Also could have been going through those corners quicker than before? And now you might have been on the edge? PR and likely down on power - definitely had to be gaining time somewhere. NT01s really are a solid track day tire. Not as fast as a cheater 200 like the RE71s were - but they wear well, don't grease up as bad, and stay as fast on the day you cord them as the first day you put them on. And still have some decent pace in them. They also have pretty friendly recovery characteristics. Quote:
07-22-2021, 07:23 PM | #18 | |||||
Rep 340
Tire pressures I'm finding more and more this tire likes a low pressure. I ran my fastest time at 32-33psi hot and I'm still not using as much shoulder as I'd hoped. Quote:
Here's the vid of the lap too. Don't laugh too hard at my braking into 12 -_- Ignore the mph postings in the top-left, they're going off of ecu speed and incorrect Last edited by M1500Z; 07-22-2021 at 07:43 PM.. |
07-22-2021, 10:24 PM | #19 | |
4693
Rep 2,541
Also with the heat the track definitely might have had less available grip than when you were there previously. Been getting a lot of rain too - so the track likely isn’t rubbered in very well either. Just saying there are a few factors that are pointing to a slower track Friday vs your previous PR. I really do think you made more of an improvement than you realize. The video - quick glance yes I think there are a few small tweaks to your line that could pay off. I’m racing out there this weekend so will take a better look at it next week and shoot you a PM with some data/video.
M1500Z423.00 |
07-23-2021, 02:25 PM | #20 | |
Rep 340
OG Shark4692.50 |
07-26-2021, 12:19 PM | #21 | ||||||
Rep 1,917
Matt
M1500Z423.00 |
07-26-2021, 02:15 PM | #22 | |
4693
Rep 2,541
You have good pace - looks like you run more of a race line though. Hopefully not having to do that to keep people from diving in. By race line it looks like a tendency to drift in too soon towards the low speed corners on entry. It's hard to say for sure because of the helmet cam view - but it looks like a T1 you start to pinch off the corner a bit by drifting in before committing to the turn. At the apex you are still pointed out quite a bit - and with this corner being over 90* you really, really need to be as rotated as possible at the apex in order to be able to get to wot quickly. It also puts you pointed on a better line for T2 - not drifting out on exit so far down the track from T1 so you are able to drop down lower for T2 entry. Can then run that turn faster now that it is straightened out a bit more. T11 looks like the same - drifting in too soon and making it to where you are not rotated enough at the apex. Most important corner - have to get to wot asap. Maybe stay out wider & deeper on entry so that you can be more fully rotated at the apex and can get back to wot much quicker being on a much better line. Might try going to the end of the red/white rumble curb on the right before you start your turn in. T18 - not sure what happened??? Doesn't look like you got loose - was the car pushing out through the turn and you had to stay low throttle to get it through? Lot of time between there and 19 (don't pinch 19 either). Had good pace overall - think in more favorable conditions & a little line clean up will be in the 2:30.xx pretty quickly. Also are you on the stock suspension?
M1500Z423.00 |
