06-16-2021, 03:31 PM | #1 |
4496
Rep 1,862
Drives: powered by bootmod3
bootmod3: CustomROM release - Map Switching, Flex Fuel, AntiLag, New Map Editor...
bootmod3 CustomROM now available for N55-M2 engine vehicles!
All the features and customization previously released for the S55 and N55-EWG including MapSwitching, Flex Fuel, Antilag, Live Adjust burble and ethanol override, In-dash ethanol check and others are now available for the N55-M2 cars. This work starting with the S55 has been under way since last year and we are really excited to have it finally released on the N55-M2 as well. bootmod3’s integrated Map Editor features 4800+ calibration tables available on the N55-M2 CustomROM for custom tuners on the platform to take advantage of. Advanced logging (RAM) channels support has also been expanded to include many new loggable parameters, many of which are exclusive to bootmod3 software customization. New Stage 1, Stage 2 and Stage 2+ OTS maps are now also available featuring 4 integrated map slots, flex fuel, antilag and all the CustomROM features. Stage 2+ Multimap OTS map, with the presence of a Flex Fuel Sensor, scales all the way up to full E85 content fuels for those with upgraded HPFPs installed that can flow the required fuel volumes.
YouTube Channel [NEW] | Facebook User Group (20,000+ members) | Tech Support Website | Wiki | FAQ | iOS App | Android App | bootmod3 Web
Sales Support Email: sales@protuningfreaks.com | Tech Support Email: support@protuningfreaks.com |
06-16-2021, 03:38 PM | #2 |
Rep 7,429
So good!
06-16-2021, 07:36 PM | #4 |
Rep 3,695
proTUNING Freaks
Simple question: For those of us without an ethanol sensor and switch between Stg 2 93 & Stg 2+ E30 OTS maps and fuel, can we set up map switching via the steering wheel to easily go between these two maps? |
06-16-2021, 09:46 PM | #5 |
Rep 289
Do you have some of the same failsafes for antilag that MHD does?
“ There are also various safeties in place such as coolant temp, EGT temp, max duration per use, and cooldown time between uses. These values, as well as the time delay after button press until antilag activates are all set to safe values for those using the OTS antilag flash option. OTS users will have the ability to adjust the antilag boost target (max value depends on engine). Finally, custom tunes will have the ability to adjust ALL of the above values. We will be uploading the updated XDF files today.” |
06-17-2021, 06:50 AM | #7 |
Yoda of mods
1674
Rep 3,006
Drives: X5 RWD
Nice!
Current: 2020 Explorer ST (Agate Black Metallic), F15 SGM RWD
F87 AW (retired) F30 SBM 316rwhp/440rwtq (retired) Follow me on Twitter: https://twitter.com/EdwyerCLT YT: https://www.youtube.com/@DWYERGARAGE/videos |
06-17-2021, 07:25 AM | #8 | |
Rep 931
06-17-2021, 10:13 AM | #9 |
Rep 289
By all accounts anti-lag is pretty terrible for the engine. Is there actually even a way to implement this “safely” or is it always going to be detrimental in a significant way?
06-17-2021, 10:35 AM | #10 |
Rep 289
06-17-2021, 10:38 AM | #11 | |
Rep 569
Ideally, I would like to be able to choose which maps went in which slot instead of being locked into, for example, all stage 2. But this is a nice start. |
06-17-2021, 04:17 PM | #12 |
Rep 2,363
Drives: 2018 BMW M2 & 2024 BMW X1 M35i
This is great. I am wondering if I have a custom map with a tuner, I now see a convert to Custom ROM button but do I need to do this with the tuner or can I just hit that button and make the jump over myself? Very excited to add these features soon.
Follow my builds:
The Racecar (2018 M2 - M0010): Build Thread | @_m0010 The Daily (2024 X1 M35i - X001M35):Build Thread | @_x001m35 |
06-18-2021, 03:36 AM | #14 |
Rep 2,577
These are good questions I'm yet to see clarification on till this day.
1) How is the anti lag achieved from the engine perspective? I'm assuming it's not done via hanging at stupidly high rpm, so what exactly, when in the low rpm range, is giving the turbine enough momentum to make target boost? 2) Does it have anything to do with fuel economy? 3) One good application I'm thinking is, would it completely solve big turbo drivability issue if anti lag boost target set to 2-3psi daily driving? What if anything is being stressed in that case?
Lemania 2320
06-18-2021, 08:04 AM | #15 | |
Rep 289
https://www.torquecars.com/tuning/anti-lag-systems.php |
06-18-2021, 09:27 AM | #16 |
Yoda of mods
1674
Rep 3,006
Drives: X5 RWD
proTUNING Freaks Sent ya a PM.
06-18-2021, 12:25 PM | #17 | |
Rep 2,577
Lemania 2320
06-18-2021, 12:27 PM | #18 |
Rep 142
This should help to understand all about the CustomRom. Not sure why they don't post these links to alleviate all of the questions..
https://www.protuningfreaks.com/blog...i-enhancements To read about the bootmod3 CustomROM features available on the N55 engine refer to document below: https://bootmod3.atlassian.net/wiki/...BMW+S55+Engine To read about the changes in the new bootmod3 Map Editor, refer to this document: https://bootmod3.atlassian.net/wiki/...Editor+Release For Tuning Tables overview for Map Switching, Flex Fuel and AntiLag refer to this document: https://bootmod3.atlassian.net/wiki/...g+-+S55+Engine |
06-18-2021, 03:29 PM | #20 |
Rep 289
Love this map idea where you have multiple fuel options for one particular stage. I’d assume the flat torque gives you 369 lb ft of linear torque throughout the rev range, rather than having a massive overload of it at low rpms. Personally, I want all the torque I can get at any time...
06-18-2021, 03:35 PM | #21 | |
Rep 6,635
JTO245274.50 |
06-18-2021, 03:35 PM | #22 | |
Rep 569
The short answer is yes, this will cause accelerated wear to down stream components like the exhaust valve, turbo, and cats by exposing them to higher pressures and heat. I can't speak to the amount of wear, but anti-lag isn't something you should be using often anyways. Think of it like the race start function. Use it rarely with the understanding that you are stressing the components. Or don't use it at all. I've found that anti-lag really doesn't make much of a difference on Stage 2 93 octane. So I probably won't use it. But it's a cool feature to have. |
Tags |
bm3, bootmod3 |
