06-01-2021, 04:25 AM | #1 |
Rep 184
Drives: 2017 BMW M3 Competition (LCII)
DIY BMW M2 Oil Change video
Hi all,
This is me doing an oil change on my M2. Hope this is useful to some of you. Thanks, HunterHofman |
F87source7243.50 mtl8852.00 Kikuchiyo114.50 VisualEcho6633.50 ///M TOWN16300.00 No_curebimmer637.50 M2Pilot278.50 |
06-01-2021, 05:53 AM | #2 |
Rep 72
Thanks for posting detailed instructions from lifting up a car till the measuring oil level. It's great.
Was the oil level lowered after running engine for a while as the oil filling up the empty dead spaces in the channels?
TheHunterHofman235.50 |
06-01-2021, 06:31 AM | #3 |
Restless
1332
Rep 1,031
Great video, very clear instructions.
06-01-2021, 04:01 PM | #4 |
Rep 7,422
Good stuff.
06-02-2021, 03:20 AM | #5 | |
Rep 184
I did the oil level measurement on video after driving about 30 minutes directly afterwards and I did it once a week later; the oil level is still the same. |
06-02-2021, 04:05 AM | #6 |
Rep 184
06-02-2021, 05:48 AM | #7 | |||
Rep 72
Running engine for a minute or two should be enough to make the oil level stable. That may be the reason why you didn't see any changes after a 30 minute drive and thereafter.
06-02-2021, 08:11 AM | #8 |
6634
Rep 4,145
Drives: '18 M2 6MT
Nice video.
Interesting that there is no oil filter priming. I wonder if draining the oil on an angle has any effect on the amount of oil that's drained, as opposed to having it flat on a lift. Regardless, I'll be doing mine at an angle as well, so 6.5L is perfect, thanks for that. I've been doing my own oil changes (on some cars) for the last 30 years, and I do recommend a set of ramps for this job, as it's much faster, and safer, but you've done well. Did you source your parts via FCP Euro so you can return them free after use for replacements, or get them somewhere else? You really should include links/part #'s in the notes on YouTube, it will help. |
06-02-2021, 08:53 PM | #9 |
Rep 350
The car will only let you do the oil level check after it has warmed up enough, this annoys me a lot about the removal of a proper dipstick. I can understand the addition of the electronic level check but when they ARE able to add the dipstick back for motorsports versions of the car (e.g. M235i Cup/M240i Cup/M2CS Cup all have dipsticks), I don't understand why it was removed.
06-02-2021, 10:14 PM | #10 | |
Rep 7,422
tux2005234.00 |
06-03-2021, 04:32 PM | #11 | |
Rep 184
The jack and 2 jack stands were all the tools that I had available, I will be buying a quick jack (or ramps) at some point! The drain plug, however, was relatively far down and on the back side of the sump; the slight angle it was on wasn't an issue at all I think (but yes, having it flat would be better, strictly speaking). Good point on the part numbers, I'll include them in the description! I bought the parts from a Dutch website (I'm Dutch). |
VisualEcho6633.50 |
06-03-2021, 04:33 PM | #12 |
Rep 184
You're right. Circulation goes very quickly indeed. Although I didn't expect any changes, I was just curious after a week .
06-03-2021, 05:08 PM | #13 | |
Rep 7,422
VisualEcho6633.50 |
08-19-2021, 10:11 AM | #14 |
New BMW owner
325
Rep 842
Where did you locate those jack stands?
Thanks for posting the video. I was hoping you also did for the transmission and differential.
08-20-2021, 08:11 AM | #15 | |
Rep 184
Although the car is too young to have the diff- and transmission oil changed already (15k kilometres), I am planning to do that too for my learning and to make a bit more of content (which I both enjoy doing)! |
ghstm268.50 |
09-05-2021, 07:01 AM | #16 |
Rep 1,644
Just changed mine yesterday. I did it on ramps while the car was warm. I drained and measured about 7.1L (it was showing at the max full mark). Put in 7 quarts of PP Euro 5w-40 which is 6.62L and after a short drive measured showing at the max full mark. I think the dealer may have been overfilling just a tad.
09-05-2021, 10:13 AM | #17 | |
Rep 184
Out of interest, why did you go with 5w40? |
09-05-2021, 12:16 PM | #18 |
Rep 1,644
Its one of the best LL-01 (non FE) oil you can buy in the US. You won't find many LL-01 oils in the US that are anything thinner than 0w-40 or 5w-40.
09-05-2021, 07:34 PM | #19 |
New BMW owner
325
Rep 842
Is that electronic dipstick accurate? He measured the drained oil to be 7.1L. I guess he missed to inform if he ran the elec dipstick BEFORE draining the oil. I wonder how accurate that system is….+/– 100mL?
09-05-2021, 08:34 PM | #20 |
Rep 1,644
It was at the full mark before. Not sure at what level it will indicate over fill but I never saw it.
