07-27-2021, 09:00 PM | #45 | |
Rep 1,759
07-28-2021, 06:36 AM | #46 | |
Rep 658
1st lap is typically a warm up lap. 2nd lap - you try your best 3d lap - cool down lap or you try your best (depends on your decision) 4th lap is you try again your best lap 5th lap - cool down lap They take the best time of these laps. |
CSBM52721.00 |
07-28-2021, 10:31 PM | #47 | |
Rep 1,759
The issue lies with the limited R tyre sizes available in 19 inch..I am not looking forward to the 20 inch on the G87 and I already can envisage people tracking often will move from 20 down to 19 or even 18 If you don't have the M performance BBK and if the rules permit, I would suggest getting a set of stock OG M2 18 inch wheels and run Advan A050, 265/35 & 295/35. That would be one of the fastest setup on OEM 18. A050 G/S compound is popular in TA events. It takes longer to warm up than the A052 but slightly faster. Potenza RE-11S or RE-12D Type A are both R tyres (faster than the RE-71RS or the discontinued RE-71R) available in 265/35 & 295/35 18 but they are not available in Europe, Last edited by Karmic Man; 07-28-2021 at 11:40 PM.. |
07-29-2021, 12:11 PM | #48 | |
Rep 658
I have original BBKs on my M2C, which means 19 rims is the minimum size. Would Nankang AR1 265/35/19 + 275/35/19 or Goodyear Eagle F1 Supercar 3R 265/35/19 + 285/35/19 provide better lap times than 255+275 Yokohama A052? |
07-29-2021, 12:14 PM | #49 |
Rep 3,335
Many have reported issues with too large of a diameter with the 265/35-19 up front -- rubbing into the fender liner (which may or may not be relieved with a heat gun and some work...).
Current Stable:
07-29-2021, 07:43 PM | #50 | |
Rep 1,759
The big issue here is aero. Running 265/285 in 35 profile will slightly raise the height of the car which means a higher centre of gravity and more importantly, less downforce on the front. You might experience more understeer on fast sweepers. If you can run those sizes in a 30 profile then it may work but again not guaranteed because the A052 is still grippier over the 3R inch vs inch. If the critical corners of your track are high speed, I would not bother with the 265/285 35 route as you want the car to be as low as possible which means stick with shorter (relatively) tyres since you won’t be able to drop the suspension without moving to coilovers. |
07-29-2021, 08:42 PM | #51 | |
6634
Rep 4,145
Drives: '18 M2 6MT
07-30-2021, 01:38 AM | #52 |
572whp Stock Turbos/DP E60 Tune by Tier1Tuning
174
Rep 294
A Supercar 3R or Trofeo R are in a different class than the A052, literally.
In your case, with the ability to warm up the tires, I'd go for the 100TW Supercar 3R (in stock sizes) over the 200TW A052. If you want to drive to the event and back on the "race" tires, then the A052 is the correct choice. The SC3R are more of an "install at the track" tire. Don't want to cycle them and wear the tread off in transit. |
07-30-2021, 09:20 AM | #54 | |
Rep 658
The height is adjusted accordingly. I have MP coilovers. There are no high speed corners at the racetrack I am planning to have TA competition. I didn’t know that A052 is grippier than 3R. If this is the case, then I am staying with A052 255+275. |
07-30-2021, 09:22 AM | #55 | |
Rep 658
I am a bit confused. Which tire secures better lap times? A052 or SC3R if running same size? |
07-30-2021, 09:37 AM | #56 |
174
Rep 294
07-30-2021, 09:41 AM | #57 |
Rep 658
infinitekidM2C4206.50 |
07-30-2021, 11:37 AM | #58 |
Rep 555
SC3R is superior in both lap times and also grip drop off under heat. A052 is easy to overheat like every other fast tw200 tires. SC3R should give you more consistent feeling across the session.
IG: M2C_SO |
07-30-2021, 07:25 PM | #59 | |
Rep 1,759
If your track is mostly low speed high G corners and the fact you have the MP suspension to reduce height, then the 3R 265/285 35 may be a viable option. I have not known of a non slick tyre that has a definitive edge over the A052 in TA apart from full on R tyres (A050, RE-11S/RE-12D, Hossier…etc) that are not road legal or simply not available in most countries. If the tyre performance are so close with what’s available to you, my honest opinion is spend more time to dial in the suspension and alignment to the point that you are able to drive at 10/10. Lastly, spend money on weight reduction like getting the M performance carbon bonnet Last edited by Karmic Man; 07-30-2021 at 07:32 PM.. |
