11-26-2018, 12:20 AM | #1 |
Rep 501
Drives: 2015 M4
Drop in air filters?
One of my initial mods is to install K&N drop in air filters- the air boxes look the same as the M3/4 - will the M3/4 air filters work on the M2 C?
2018 R8 V10+ - Ara Blue/Gray
2022 MS Plaid - Red/White (Daily) 2021 Alfa Stelvio - Red/Black 2013 135is - LeMans Blue/Gray 2003 M5 (56k miles) - CB/Black |
11-26-2018, 10:15 PM | #4 |
Rep 501
Drives: 2015 M4
Thanks guys - appreciate the input...filters ordered...
11-28-2018, 01:11 PM | #6 | |
Rep 699
http://www.gmtruckcentral.com/articl...ter-study.html |
11-28-2018, 04:00 PM | #7 |
Rep 216
It’s a little difficult to tell what kind of difference I noticed, I put them in right after break in so I don’t have a great before/after comparison. It looks like there were some pretty significant gains (at least I consider significant) from people that put them in their m3/4 s55s. I like having the reusable filters too.
11-29-2018, 07:00 AM | #8 |
IG @bmwF9xG80
3813
Rep 7,593
I'm running Magnum Pro Dry Filters from AFE
To be honest, keep stock filter and just do charcoal delete
60-130mph 6.5s X4M #HCP
Enabled1406.00 |
11-29-2018, 11:25 AM | #9 |
Rep 739
12-06-2018, 10:03 PM | #11 |
IG @bmwF9xG80
3813
Rep 7,593
Not sure if there's any gains really but I know it helps somewhere
12-07-2018, 12:01 AM | #12 | |
Luxury at the redline :)
9105
Rep 7,563
At higher RPM it helps the car breathe better.. The MAF sensor only allows for so much pre-programed air before it triggers an error, so a drop in charcoal is perfect amount of air flow, as oppose to a cone intake.. |
12-11-2018, 11:35 PM | #13 |
24143
Rep 190,707
We offer K&N, AFE & Pipercross.
Pipercross is by far our most popular option
12-12-2018, 11:18 PM | #14 |
Rep 479
Drives: CB E46 and SG E92 M3s
I got BM fresh in box unused. Bought intakes. Lmk if u interested.
12-13-2018, 07:48 AM | #16 |
Rep 699
I've decided to go with a dry panel replacement. I'll never use anything oiled again. I had a factory oiled K&N on my Harley and you could see a film of oil and fine dirt on the back side every time you removed it. I also see customers here at the shop where I work that use them and there's always dust on the back sides of the filters.
nachob2314.00 |
01-13-2019, 01:01 PM | #18 | |
Rep 4,341
These are racing filters! Racing motors in a race are often rebuilt after each race no one is expecting their race motor to last 120,000 miles and 10 years. It is really stupid to put one on a street car if you want your engine to last a long time. Everyone has opinion of course in some cases where the car is never in a dusty environment it might not affect the engine whereas in some environment it would. BMW made a performance intake for the E46 and they used a larger paper element that was arched in a U shape for better airflow but still a paper element. Oiled filters are better if the filter is exposed to the elements where water would damage the paper. But then again if not done correctly, you could be drawing hot air into the engine and more dust and grime into the filter. Hot engine bay air will also break down the oil quicker. In my autocrossing days I would put a freshly cleaned KN filter in my Scirocco for the weekend event, then put the factory one back in for daily driving. But leaving one of these in your $60K M2 for years is really not a good idea. |
01-18-2019, 09:09 PM | #21 |
Rep 7,594
Drives: '19 M2C
I'm more interested in his next video with the charcoal filters removed.
www.ReTuneTheDeTune.com
Rumbloki176.00 |
11-05-2021, 07:51 AM | #22 |
Rep 7
Most of what I’ve read is that high-flow or low-restriction filters don’t do as good a job filtering the air as an OEM paper filter. They also don’t flow as well as OEM paper once they start to get dirty. And they can deposit oil on the MAF sensor, leading to problems. We use them in race cars because they are cleaned after every race and do flow better at high RPMs where race cars run. For a daily driver, though, it’s a sketchy way to get maybe a few HP. After all, you’re filtering the intake air for a reason. So using an effective filter is best, even if you’re giving up a couple peak HP under ideal conditions. My two cents.
kthor70348.00 |
