08-26-2021, 03:33 PM | #1 |
@lbb_kev
491
Rep 514
Nexsys Motorsports Ignition Coil Upgrade Kit
It looks like Nexsys finally released pre-orders for their B58 coil conversion kit for N55 and S55s. Who wants to give it a go?
https://nexsysmotorsport.com/n-s55-i...l-upgrade-kit/
08-26-2021, 04:47 PM | #2 | |
Rep 7,429
In terms of who wants to give it a go, you'd be the ideal candidate! You're making enough power for this to actually have a meaningful impact, and you have a tuner that can tune for the new coils (since most ots maps guys won't have the check box option for it yet).
-Eidos491.00 |
08-26-2021, 10:39 PM | #3 | |
@lbb_kev
491
Rep 514
I'll have to look into which B58/S58 plugs to run for this kit.
F87source7251.50 |
08-26-2021, 11:13 PM | #4 | |
Rep 7,429
BTW are you manual or dct?
08-27-2021, 11:10 AM | #6 |
Rep 7,429
Yeah I heard they're super busy and have some crazy back logs, you'll need to be patient.
08-27-2021, 02:55 PM | #7 |
@lbb_kev
491
Rep 514
I'm manual
F87source7251.50 |
08-27-2021, 03:04 PM | #8 |
Rep 7,429
Very nice! 3 pedal life!
Btw did you upgrade the clutch? If so what clutch are you using?
08-27-2021, 05:01 PM | #9 | |
@lbb_kev
491
Rep 514
SD Garage in San Diego gave me the opportunity to use my car as a test mule for a beta variant of what's going to be the F8x X-Clutch twin-disc kit. I don't really have a timeline for when X-Clutch will release the finalized product, but I know they're working on implementing some of my recommendations to make it better than it already is. I recommend waiting for the X-Clutch if you're not in any rush to upgrade. They are the clear leaders in the space: https://www.xclutchusa.com/
F87source7251.50 |
08-27-2021, 06:13 PM | #10 | |
Rep 7,429
For me the stock clutch will be more than enough, since I will be doing a track build and cooling will be the limiting factor not the clutch.
08-28-2021, 01:45 AM | #11 | ||
Rep 485
08-28-2021, 02:54 AM | #12 | |
Rep 7,429
Because I know OG shark on here made the s55 air to water intercooler unit fit on his OG m2, but the shop that did it for him didn't plan to have a kit made iirc. But if a pnp kit is going to be available that would be incredible, because it would allow us to run a full sized radiator from the s55 which would greatly improve coolant temps which is what we are currently struggling to fight.
08-28-2021, 10:04 AM | #13 | ||
Rep 485
Let's be real lol, our cars struggle with coolant and oil temps. |
F87source7251.50 |
08-28-2021, 10:41 AM | #15 |
Rep 485
08-28-2021, 10:52 AM | #16 |
Rep 4,146
Has that happened to anyone here? I’ve seen that happen preEWG N55s, but not now. And mostly due to no oil cooler (which we have) and a small intercooler.
08-28-2021, 10:57 AM | #17 | |
Rep 485
I've seen 240+ degree temps on not even hot days and my car has all coolers except the radiator upgraded. |
F87source7251.50 |
08-28-2021, 11:08 AM | #18 | |
Rep 4,146
I know ZM2 had some issues, but that seems like an instal issue, or a calibration issue - not a temp issue. Have you ever reached the threshold of limp mode? |
08-28-2021, 11:36 AM | #19 | |
Rep 3,696
You’re saying basic things that we’re well beyond. This is an issue for N55 folks that push their cars hard on track in the summer. If you’re just cruising around town, there’s no issue. |
08-28-2021, 01:34 PM | #20 |
Rep 7,429
Thanks! You're the MVP!
08-28-2021, 01:38 PM | #21 | |
Rep 7,429
This man would know, amouray give this guy's thread a read he has literally been trying everything to solve the issue and we're getting close. If we have the air to water cooler and could run the full sized s55 radiator I'm sure water temps would be in check. You could also likely do the same with the arm intercooler (if the end tanks aren't too intrusive) because it doesn't stick backwards. Then if oil cooling is an issue you could always grab a giant an intercooler and use the thermostat delete plates to make it work, or find out how ER is able to adapt the stock heat exchanger lines to an fittings fie the oil cooler, then that will retain the stock heat exchanger loop.
09-05-2021, 10:31 AM | #22 | ||
4693
Rep 2,542
So you know the backstory the owner of M Technik has basically become like a little brother to me since I have started out on the track. He and another good buddy of ours first built my M3 race car and we have done everything on my BMWs together since. He is the one that put together the conversion to the A2W - very much a mad scientist. M-Technik is primarily a service and repair shop first though - so the three of us are collaborating together in OG Shark Motorsport with a focus on race/track/high performance builds and parts. Not that any of that makes much of a difference here - the main thing being that we are working on the pnp kit! Just taken a bit of time for us to be able to get to this point with all that we needed to do to get up and running (and also get a race in here & there). Our in house parts & kits are starting to come out now though (M2 half cage prototype is ready and we are starting production!). This conversion kit is definitely one of priorities now. And price - he hasn’t been able to answer that because we are not 100% sure of the total cost yet. Getting close but I like to know exactly what we have in something before we figure out the price. Also working on the final parts/options that we want to make available with these kits
F87source7251.50 |
