M2 Technical Topics > S55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > How to disable burbles?
      12-13-2020, 07:37 PM   #221
veenut28
veenut28's Avatar
658
Drives: 2020 M2, 6MT
2020 BMW M2 Competi ...  [10.00]
  [0.00]
Why does the "disable burbles" feature have to be done via bimmerlink rather than being able to be coded out using bimmercode?
With bimmerlink, you have to keep the obd adapter plugged in and have the app running. That's my understanding, anyway. So that requires opening the app each time you get in the car, right?
      12-13-2020, 07:48 PM   #222
CKr
Drives: 1998 E36 M3
I can't effectively explain the difference between BimmerLink and BimmerCode, but with regards to the "sound tuning" (burbles) setting, you do not need to open BimmerLink every time you drive your car. I've been in the BimmerLink beta since August, and haven't had to open BimmerLink to disable sound tuning since initially turning that setting off.
      12-13-2020, 08:45 PM   #223
Mr Pete
Mr Pete's Avatar
Drives: 997 GT3 4.1, Golf R (daily)
Thank you for this. Just ordered the obd2 adapter. Looking forward to turning off the obnoxious burbles.
      12-14-2020, 02:35 AM   #224
DieselDrink
DieselDrink's Avatar
Drives: 2020 M2 Comp in HS
I'm just about to take delivery of my new M2C in HS.
The Carly app which I've used before, but not on a newer BMW has an exhaust flap coding section. Will this change/code the exhaust flap? Is this the same essentially as the bimmerlink mentioned?
      12-14-2020, 02:58 AM   #225
cpxchewy
Monkey
119
Drives: 2020 M2C
No. The Carly app manages the exhaust flap, which determines how loud or quiet depending on flap open or not.
The BimmerLink activates a hidden engine config without burbles. The config is written in by bmw but not enabled by default.
      12-14-2020, 08:48 PM   #226
M2Cmtl
Drives: 21 Q7 & 22 4XE
FYI I played with it this morning and with the burbles off and in efficient mode I got these weird pops coming from the rear of the car (like if someone was dumping fuel in the exhaust if that makes sense. You could feel it rumble throughout the car...
      12-14-2020, 10:23 PM   #227
Bryan1978
Drives: Bmw m2
Hello.
Can i use my obdlink mx+ adapter or i need to buy another obd adapter to use bimmerlink? I already have the bimmercode but thinking of purchasing the bimmerlink. Don't like the burbles too
Thanks
      12-15-2020, 05:12 AM   #228
swampfox94
swampfox94's Avatar
1187
Drives: 2020 F87 - M2 Competition
I won't lie, pops were one of my car buying criteria when I was looking lol
      12-15-2020, 06:00 AM   #229
mcgel
Drives: BMW M2 Competition on order
Originally Posted by Bryan1978 View Post
Hello.
Thanks
I successfully disabled burbles via Bimmerlink's Sound Tuning option. I did this via the obdlink mx+ device as well. Takes approximately 2 seconds to disable via the app and less then a second to enable again. This is done via an ON and OFF buttons in the app. Definitely worth the money just for this feature alone but it can also be used to reset the battery in future when its replaced as well which is another additional benefit I'll look forward to.
      12-15-2020, 06:03 AM   #230
mcgel
I can also confirm that once it's off, it remains off. Does not require the device to be connected once you've finished the setting you desire. Can easily be reverted back as well if required (via the Bimmerlink app).
      12-15-2020, 06:06 PM   #231
Bryan1978
Drives: Bmw m2
Hello.
Thanks
Thank you so much
      12-15-2020, 08:46 PM   #232
Mr Pete
Mr Pete's Avatar
Wow, amazing. This shit really works haha no more burbles.
I'll know more if it stays completely off after I disconnected the adaptor. I didn't bother to start the car up and go after removing
it haha
Fuji550i389.50
      12-18-2020, 10:40 AM   #233
AZ-Wildcat
AZ-Wildcat's Avatar
620
Drives: BMW HS M2C DCT
For those who used this I have a few clarifying questions before I purchase the app:
1. Can disable using iOS correct?
2. It mentions on the app that it will only disable "factory" flaps. Anyone try this with aftermarket exhaust? I assume a non issue but wanted to check.
3. Same BT OBD adapter that I use w/ Bimmercode work? I assume yes
TIA
      12-18-2020, 10:46 AM   #234
CKr
Drives: 1998 E36 M3
TIA
1. Yes
2. I imagine, yes, as long as OEM flaps were transferred to new exhaust
3. It should work. The list of supported adapters is here
      12-18-2020, 02:02 PM   #235
veenut28
veenut28's Avatar
658
  [0.00]
Gotta say - I like it. I live in a rural area and previously spent most of my time with the throttle in Sport plus, but I usually dropped it to Economy in traffic or when driving through downtown or neighborhoods. The burbles were too much at low speeds.
With the burbles off, I can just keep it in Sport plus all the time. The M2C looks too aggressive to be a true Q car but it sticks out a bit less now.
      12-19-2020, 06:38 PM   #236
Mr Pete
Mr Pete's Avatar
No burbles with the adaptor completely off. Man, it's like a whole new car haha obnoxious burbles gone!
Fuji550i389.50
      12-24-2020, 12:29 AM   #237
MidnightM2
MidnightM2's Avatar
53
Drives: 2018 BMW M2 LCI
I wonder whether bimmerlink will offer the same function for OG n55 M2
      12-24-2020, 01:28 PM   #238
PilotxERAU
Drives: 2018 F87 M2
Originally Posted by Lost in München View Post
Greetings.
What are the options for disabling burbles on M2 competition with locked dme?
Can dealer do it ? Maybe?
OBD flashers are out?
Only bench unlock?
Thanks.
You bought a fart machine my man. You can put lipstick on it but it still farts.
      01-26-2021, 03:50 AM   #239
Lillianuerrero
Drives: x3
I have found a solution!
AK motion display has option to disable burbles.
As i understood there is no flashing inolved...
thank for sharing!
      01-26-2021, 01:12 PM   #240
GioM2Comp
Drives: 2021 BMW M2C ZED 6MT
Can bimmercode or bimmerlink be used on a 21 M2Comp with locked ecu?
      01-26-2021, 04:03 PM   #241
M2COD
Drives: 2021 M2C
Yes. I've not used Link to disable burbles just yet, but I've used bimmercode to code a bunch of stuff into my '21. Rear DRLs are great
      01-26-2021, 04:53 PM   #242
bitcore
bitcore's Avatar
107
Drives: F87 BSM Manual M2 Comp
Any issue with warranty status if you disable burbles? I'm not interested in power-adders while under warranty, I just don't want it to sound like this new car has a backfiring problem (which these burbles "are", IMO). Also seems like a waste of fuel for the sake of annoying people outside of the car, as it does not appear to be an actual antilag.
