10-11-2016, 07:05 PM | #507 | ||
TIM YOYO
1505
Rep 3,283
Drives: 2013 M3
I'm not sure if you saw zenmaster's post, but I'll extract the important bit: Quote:
You seem a little agitated, based on the "!?!?" — maybe just emphatic — but in the absence of actual observation, it's just kind of fun (for me anyway) to dig through the details and see if we can filter out any clues.
His: 2019 R1250GS - Black
Hers: 2013 X3 28i - N20 Mineral Silver / Sand Beige / Premium, Tech Past: 2013 ///M3 - Interlagos Blue Black M-DCT Past: 2010 135i - TiAg Coral Red 6MT ///M-Sport |
10-11-2016, 07:06 PM | #508 | |
TIM YOYO
1505
Rep 3,283
Drives: 2013 M3
I too, am curious exactly what the difference is, but we already know what counts: that the turbocharger on the M2 is near its limit. We know this from the tuning that has already happened.
10-11-2016, 07:32 PM | #509 | |
Rep 310
Drives: 04A6 2.7T(DD), 16M2 BSM MT EP
The m2 and x4 m40i engines N55B30T0 are otherwise identical! |
M3 Adjuster7909.00 |
10-11-2016, 07:41 PM | #510 | |
Rep 310
Based on realOEM it seems that there is a block difference between the N55B30T0 and N55B30O0. Unless the block part number includes the pistons? (that is how the block part number is listed for the M235. Block and pistons, look it up on my prior post) That is different for the M2 and M40i block since they use s55 pistons and unique rings. Lots of questions re open vs closed deck... I don't know I am ready to commit one way or another. However I do agree it doesn't mean diddly squat. The M2 motor is awesome. As i have previously said.. Time will tell! Last edited by reppucci; 10-11-2016 at 08:03 PM.. |
10-11-2016, 07:49 PM | #511 | ||
7909
Rep 11,785
reppucci339.50 |
10-11-2016, 08:54 PM | #513 | |
Rep 265
Pardon the shorthand but trying to keep it simple. The N55 in the M2 is a technical update so it works for the purpose of this discussion.
They are parts bin but there is still a cost to them. If they're not needed at 365 hp, why spend the money? |
bradleyland1504.50 |
10-11-2016, 08:55 PM | #514 | |
Rep 208
The thread went so fast on me I missed a page. My bad. Well the engine is a closed deck block in my mind. Ive seen everything I need to see. |
10-11-2016, 09:04 PM | #515 | |
Rep 265
R&D and manufacturing budget |
SoCalRob281.00 |
10-12-2016, 11:18 AM | #516 | |
Rep 13,139
X4 M40i US press release of October 1, 2015 (available here - full PDF document here): alike the M2 US press release of October 14, 2015 (available here - full PDF document here) reference is made to a 'closed deck' design: "The newly developed M Performance TwinPower Turbo inline 6 cylinder gasoline engine for the new BMW X4 M40i combines high performance with exemplary fuel economy. Accordingly, the lightweight, thermodynamically optimized aluminium engine has been constructed with a closed-deck design. In this type of construction, the water jacket surrounding the cylinders is sealed at the top, which endows the crankcase with an exceptionally high degree of stiffness."X4 M40i German press release of February 17, 2016 (available here - full PDF document here): alike the updated M2 German press release of February 17, 2016 (same day) the reference to 'closed deck' design has vanished (available here - updated full PDF document here): "Der neue BMW X4 M40i verfügt über einen neu entwickelten M Performance TwinPower Turbo Reihen-Sechszylinder-Benzinmotor. Das leichte, thermodynamisch optimierte Aluminium-Triebwerk wurde auf maximale Drehfreude bei gleichzeitig souveränem Durchzugsvermögen ausgelegt und bietet dementsprechend eine Motorcharakteristik, die begeisternde Fahrdynamik mit beeindruckender Effizienz verbindet."So zenmaster, does your source have a sound explanation for the update by BMW AG in February 2016 of the October 2015 German press releases for both the M2 and X4 M40i with no 'closed deck' design references anymore ?
///M is art ↔ Artemis
10-12-2016, 11:28 AM | #518 | |
Rep 208
This issue is "closed". Be happy your car has some special engine features compared to the rest of the N55 batches. A really a great motor has been put in this car. |
SoCalRob281.00 |
10-12-2016, 11:34 AM | #519 | |
King of the World
281
Rep 301
In other words, is it typical or atypical to include this level of detail in press releases? I tried sifting through old press releases on their website, but, given my woeful German language skills, I eventually just gave up. -scr Last edited by SoCalRob; 10-12-2016 at 11:52 AM.. |
10-12-2016, 11:47 AM | #520 |
Rep 13,139
Engine pictures will silence the discussion. Someday these will pop up over here.
10-12-2016, 12:04 PM | #521 | |
Rep 13,139
FWIW, BMW AG indeed referred to it in its M3/M4 German press release of May 9, 2014 (available here - full PDF document here): "Das Kurbelgehäuse des Sechszylinder-Motors ist dank seiner sogenannten Closed-Deck-Bauweise besonders steif und ermöglicht somit höhere Zylinderdrücke und damit eine bessere Leistungsausbeute. Seine buchsenlosen, LDS-beschichteten Zylinderlaufbahnen tragen maßgeblich zu einer deutlichen Gewichtsreduzierung bei."The same paragraph features in the BMW Global English M3/M4 press release of May 9, 2014 (available here - full PDF document here): "The six-cylinder engine features a closed-deck crankcase design which is very rigid and allows cylinder pressures to be increased for improved power output. And instead of liners, the cylinder bores feature a twin-wire arc-sprayed coating, which results in a significant reduction in engine weight."
10-12-2016, 12:10 PM | #522 |
Rep 2,148
Drives: F87 M2 BSM MT
Agreed! Who is will to pull the head off their M2 and take pic?
10-12-2016, 02:32 PM | #524 | ||
TIM YOYO
1505
Rep 3,283
Drives: 2013 M3
What we have here is a mountain of inconsistency lol.
reppucci339.50 |
10-12-2016, 03:20 PM | #525 |
King of the World
281
Rep 301
Indeed. However, at this point, it's fair to note that we have at least a couple of ostensibly knowledgeable BMW technical insiders unambiguously confirming 'closed deck'.
By contrast, the only info we have against 'closed deck' is the absence of those words in some BMW press releases, not concrete statements to the contrary. Official BMW press releases from numerous other countries still claim 'closed deck', such as the BMW UK press release, dated April 11, 2016. Regards. -scr Last edited by SoCalRob; 10-12-2016 at 03:29 PM.. |
10-12-2016, 04:46 PM | #526 | ||
Rep 13,139
I am by no means affiliated to BMW (except from being a loyal customer), so got no authority to make any claims whatsoever. But that does not imply that I may not point out - FWIW - a discrepancy between some original and updated M2 and X4 M40i press materials. As told earlier: the truth is out there, more particularly under the hood.
10-12-2016, 10:23 PM | #527 |
Rep 2,577
Gentlemen, this thread should be closed as we're pretty sure turbo is the same. The discussion on open/close deck is a bit off topic but certainly deserves a new dedicated thread.
Lemania 2320
10-13-2016, 08:16 AM | #528 |
IG @bmwF9xG80
3813
Rep 7,594
When BD_F87 brings his M2 to our local tuner to baseline on Dynojet & then see its potential with the flash and custom parameters.
60-130mph 6.5s X4M #HCP
zenmaster1576.50 |
Tags |
open_or_closed, turbogate |
