M2 Technical Topics > Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls > Running-in period ?
      09-29-2018, 12:47 AM   #1
lockwood
Drives: m2 lci
Smile Running-in period ?
At what mileage am I able to open up my dct M2? Be sensible, please don't say from day 1.
      09-29-2018, 12:49 AM   #2
AndrewC1989
AndrewC1989's Avatar
Drives: 2015 328d xDrive
After your 1200 mile run in service
      09-29-2018, 02:10 AM   #3
bmxcamel
bmxcamel's Avatar
Drives: F87 LCI, G01 m40i, E90 M3
You can presumably "open it up" without exceeding 110mph or 5500rpm before the break in service. The break in instructions don't say anything about avoiding hard acceleration if I remember correctly. Just don't go nuts.
      09-29-2018, 03:43 AM   #4
F87source
F87source's Avatar
Drives: Bmw M2
+1
Just make sure if you do that never go full throttle as an addition to just hard acceleration. So you can ease into it for maybe about 60% throttle then you should shift. The reason is that the cylinder walls will still be rough after machining and there may be burs that will fall off during break in so your oil will be very dirty. So don't put too much load on it so you don't end up damaging anything.
