12-28-2016, 01:01 PM | #1 |
3843
Rep 54,362
Drives: F80 M3
Another sway bar option: aFe Sway Bar Set - BMW M2/M3/M4 (F80/82/83/87)
aFe Control is proud to introduce the Sway Bars for the 2014-2016 M2/M3/M4 (F80/82/83/87) models. Anyone can make a stiff sway bar, at aFe Control we provide you the perfect balance by pairing the proper size front and rears together to offer increased roll stiffness without upsetting the vehicles balance and traction control systems. Designed specifically for the F80, the lightweight tubular sway bars will transform your M’s handling and inspire driving confidence. Cornering will be flatter and neutral in any corner. Perfectly balanced, the 32mm front and 29mm rear bars are lightweight tubular construction and feature CNC machined, TIG welded bar ends for a perfect fit. The kit includes CNC machined 6061-T6 sway bushing brackets that are anodized black and a direct fit for the included polyurethane bushings. For years of durability and great looks, the bars are powder-coated a special 2 stage tangerine orange and are a direct fit on 2014-2016 M2/M3/M4 models. Perfectly balanced, aFe Control sway bars will have your M handling just as good at the track as it will around town.
CNC Bent, Lightweight Tubular Alloy Steel 32mm Front, 29mm Rear Sway Bars CNC Machined, TIG Welded Bar Ends Includes Polyurethane Bushings and CNC Machined 6061-T6 Aluminum Brackets Direct Fit Installation, Requires No Modifications 2 Stage Tangerine Orange, Powder-coated Finish Direct Fit Installation, Requires No Modifications Application: BMW M2/M3/M4 (F80/82/83/87) Part Number: 440-503001-N |
