09-24-2016, 10:56 AM | #1 |
Avid Car Enthusiast
152
Rep 266
stainless steel brake lines..
Hey guys! Does anyone know where I can get some stainless steel brake lines for my m2? getting track ready :-)
History will never be forgotten
1992 Red Acura Legend 4dr, 2003 Daytona Blue Nissan, 350z 6spd, 2007 Black Audi B7 RS4 6spd Current Girlfriends Alpine White BMW M2 6spd; 2015 Arctic White Yukon XL Denali |
09-24-2016, 01:35 PM | #2 | |
BMW Newb
582
Rep 903
http://f87.bimmerpost.com/forums/sho....php?t=1268366 http://www.hpashop.com/Stoptech-F8x-...ech-SS-F8x.htm |
12-06-2016, 01:07 AM | #5 |
Rep 295
12-06-2016, 12:24 PM | #6 | |
3843
Rep 54,362
Drives: F80 M3
12-06-2016, 01:22 PM | #7 | |
Rep 295
12-06-2016, 01:59 PM | #8 |
Rep 549
Drives: The Bus
Why would you want to replace the factory lines with SS?
12-06-2016, 04:24 PM | #9 |
3843
Rep 54,362
Drives: F80 M3
12-06-2016, 05:53 PM | #10 |
Rep 295
12-06-2016, 06:33 PM | #11 |
Rep 1,153
Tracking the car, especially in high heat conditions, will cause the brake fluid to heat and expand, which causes the rubber lines to expand, which mushes up the brakes. And mushy brakes are a no-no anywhere, but especially at the track.
Even though this won't be my primary track car, I've got SS lines ready to install. Cheap insurance. |
CommitConfirm474.50 |
12-06-2016, 08:26 PM | #12 | |
Rep 295
12-07-2016, 12:10 PM | #13 |
Rep 549
Drives: The Bus
I'm with you now... for moment there I though you guys meant replacing the factory hard copper line with SS.
12-07-2016, 12:35 PM | #14 |
3843
Rep 54,362
Drives: F80 M3
12-07-2016, 12:54 PM | #15 | |
Rep 295
I don't flush after every track event, just annually. Only bleed+refill before the event. Used to love alternating ATE colors till the gov put the kibosh on the blue dye |
12-07-2016, 01:00 PM | #16 |
Rep 295
12-07-2016, 01:12 PM | #17 |
Rep 295
Huh, MUCH higher wet boiling point. DEFINITELY not cheaper. I might actually give it a shot next year. Motul does lose some of its oomph later in the year.
12-07-2016, 01:25 PM | #18 |
3843
Rep 54,362
Drives: F80 M3
07-13-2021, 02:21 AM | #19 |
New BMW owner
325
Rep 842
Has anyone got a video they can share documenting how to do this stainless line swap? Or just take the old one and replace.... then do the bleed. That easy.
07-29-2021, 12:53 PM | #21 |
1026
Rep 842
Since this necro-thread was given new life, I'll throw our Spiegler Stainless Steel Brake Lines into the mix. They have some really cool features like the rotatiting fittings, which releases tension on the lines. While our lines aren't the cheapest, they are made with the highest quality components and every set is properly tested and DOT compliant. You can learn more about Spiegler here: https://www.essexparts.com/brake-lines
You can find the specific lines for the M2 and M2 Comp here: Front: https://www.essexparts.com/spiegler-...mw-m2-m3m4-f80 Rear: https://www.essexparts.com/spiegler-...m4-f80-f82-f87 |
