01-16-2021, 08:40 PM | #1 |
381
Rep 731
Tension Rods
Thinking of replacing my Tension Rods. Anyone have any feedback of Pros and Cons of doing this. Is it worth the upgrade for the Tracking ability of the M2? Have new suspension coming and thinking this is a good time to add.
At a Point above 7,000 RPM.
01-16-2021, 09:20 PM | #2 | |
Rep 151
01-16-2021, 09:33 PM | #3 |
381
Rep 731
Yes, so did I. Tension rods are completely different. They are the Arm towards the rear from the Thrust Arm. They are to the rear of Thrust arm.
01-17-2021, 03:36 AM | #4 |
844
Rep 1,962
Do you mean the Tension Strut, or? I'm fairly certain you can get monorail versions of the Tension Struts
Front: Item 10 https://www.realoem.com/bmw/enUS/sho...diagId=31_1123 Rear: https://www.realoem.com/bmw/enUS/sho...diagId=33_1818 Edit: This thread might be useful. https://f87.bimmerpost.com/forums/sh....php?t=1720518 Last edited by M Fifty; 01-17-2021 at 03:45 AM.. |
01-17-2021, 08:20 AM | #5 | |
381
Rep 731
01-17-2021, 03:09 PM | #6 |
844
Rep 1,962
01-24-2021, 08:24 PM | #7 | |
3814
Rep 54,307
Drives: F80 M3
This is our best selling monoball to date: https://www.hpashop.com/SPL-Adjustab...?categoryId=-1 Last edited by HP Autosport; 01-27-2021 at 10:52 AM.. |
01-27-2021, 04:13 AM | #8 | |
Rep 4,510
Tension strut/rod aka Upper Control Arm (UCA) - solid rubber bush from factory - I (and a number of others) have retrofitted m/ball bush to help improve EPS feel + response and stabilise front geo under heavy/late braking on track. I used Bimmerworld m/balls - not the cheapest but no regrets and ideal for dual duty - DD + TD's.
Current '22 X3M LCI.. |
02-02-2021, 01:22 AM | #9 | |
Rep 200
02-02-2021, 07:37 AM | #10 |
381
Rep 731
It's amazing how much confusion there is when you talk about M2 Front suspension parts. Different names for the same parts, even on BMW's own ordering site. Those parts in the diagram aren't even on an M2.
02-02-2021, 12:23 PM | #11 | |
3814
Rep 54,307
Drives: F80 M3
These: https://www.hpashop.com/SPL-Adjustab...8X-SPL-FKS.htm https://www.hpashop.com/SPL-TITANIUM...nsion-Rods.htm |
02-09-2021, 04:52 PM | #12 |
Rep 10
SPL tension arms
I have used the spl lower control arms and then needed the tension arms to get the caster sorted. I could only dial in about -1.8 camber without the tension arms due to the tyres rubbing on the inside plastic in the wells.
The tension arms pull the wheel back and allowed it to go to -2.5 (its as far as I wanted to go) without the rubbing - lots of clearance. Its by far the best bang for buck money I've spent to decrease my lap times, the car rotates much better and keeps my corner speed up. |
02-09-2021, 07:50 PM | #13 | |
381
Rep 731
02-15-2021, 01:52 AM | #14 |
Rep 10
Camber Plates Vs lower control arms and tension rod
To answer the question camber plates will give you camber but that's it with the lower control arms and tension rods then you can adjust everything in fine detail. As to what to buy - I am of the opinion to buy once, cry once but I only really drive it on the track so I've adjusted all the geometry toe, caster & camber for grip and quicker turn in - you wouldn't use my settings on a road car. Also the standard shock and springs are actually ok - so if you were going after some nice but expensive coilovers - they are actually wasted IMO without having the rods in first and adjusted up - the coilovers are only for "ultimate" grip / handling after you get the camber, caster and tom sorted - again only my opinion.
I sort of work on the principle if I'm going to change something then I'll do it properly from the start it saves money in the long run. My day to day cars are all stock as a rock. PS the cost of camberplates and with the the cost of installation - its not too much more to put the rods on and be able to dial in what you like - for serious tracking I chose that or I would have ended up paying twice to get the adjustment I wanted. I am also of the opinion the couple of grand I spent was the cheapest $ for a couple of seconds improvement in time that I or anyone else could spend on a M2. |
02-15-2021, 08:55 AM | #15 | |
381
Rep 731
02-18-2021, 02:28 AM | #16 | |
Rep 4,510
Millway do 2 versions, one of which is a street m'ball of tension strut monoball - if you look at their website you will see the difference between track and street wrt seals/covers I mention above. I chose Bimmerworld m'balls as they're are sealed and use an oem grade m'ball similar to what F8x LCA's come with from the factory. HTH, BP
