12-23-2020, 06:18 PM | #355 | |
Rep 1,389
Got mine plus CF brace, reinforcement rings and screws £360. Last edited by 3t3p; 09-28-2023 at 10:18 PM.. |
12-24-2020, 11:22 PM | #356 |
Rep 1,313
Nice mod. I think the aluminum brace made the biggest difference.
Anyone install the corner braces https://bimmercat.com/bmw/en/search/...ng/ECE/51_9764 3 and 5 2 and 4. Looks like a pain. I'm not sure if another rivnut has to be installed on the fender mount #8? |
12-26-2020, 02:04 AM | #357 | |
Rep 553
12-26-2020, 04:59 AM | #358 | |
Rep 4,515
I ran alloy brace only on my ogm2 for ~6 months whilst waiting for a good used CF brace. Corner extensions aren't standard on the m2comp and require a lot of remedial work to retrofit.
Current '22 X3M LCI.. |
12-26-2020, 09:06 AM | #359 | ||
Rep 1,313
12-28-2020, 07:36 PM | #361 | |
Rep 553
I cut the ends off my extension rods to use a 3rd bolt on the carbon to alloy brace junction. Last edited by David.m; 12-28-2020 at 07:45 PM.. |
01-14-2021, 05:18 AM | #362 |
Rep 553
For anyone interested I've found a solution to torquing the fender riv-nut bolt (E14 torx). Get a 3/8 drive E14 torx socket, cut 5mm off the torx end and now fitted to my Kincrome 3/8 drive torque wrench I can get it under the guard lip, into the cup & onto the bolt.
I had considered cutting out a section out of the guard rail like the M2C has stock (as it's hidden by the plastic hood seal) but a panel beater mate warned that removing the rail's raised edge will increase risk of the panel buckling even from very minor impact. |
01-15-2021, 08:13 AM | #363 | |
Rep 9,709
01-15-2021, 10:04 AM | #364 |
Rep 57
01-15-2021, 11:27 AM | #365 | |
Rep 9,709
The above sounds daunting, but realistically, the steel if very thin and easy to work. WIP pic |
04-21-2021, 12:15 AM | #366 | |
Rep 12
05-01-2021, 11:09 PM | #367 |
Rep 523
Just did the conversion and installed ohlins at the same time. Wow what a transformation! The front end is even more responsive and connected now!! Highly recommended esp if you're tracking. Hoping to test track effectiveness soon.
18 M2 6 Spd AW - VRSF DP / CP & Race FMIC, ER TIC & GFB DV+ with BM3 Stage 2 Retired 09 135 JB4 G5 ISO w/BEF, N54 Tuning Performance DPs, BMS DCI, ER Charge Pipe |
08-02-2021, 11:23 AM | #368 | |
Rep 488
I fitted it complete with Vorshlag camber plates. Wow - what a difference - the setup feels absolutely fantastic (and I haven't even dialed in any additional camber yet). (this is with GTS coding and AST coilovers also) Bee Pee Please can you expand a little on the brake hose re-routing - I also have this issue also. Does twisting the connector 180 degrees enable the hose to push down further into the servo unit? I guess that you had to bleed the brakes after this? Thanks. Last edited by widetyres; 08-02-2021 at 11:34 AM.. |
08-02-2021, 12:36 PM | #370 | |
Rep 488
What I am referring to is the brake pipe for the right front brake - the red one in the picture below. My brace is pressing down on this. It is not too bad at the moment, as I don't have the fillster bolts in, but if there were in, I think that there would be too much pressure on the pipe. Did anyone else have this issue? I suspect it is just be a case of undoing the pipe attachment to the ABS unit, and then sliding the pipe down a bit more. Also, I really struggled to get the rivnuts to bite - I wasn't using a tool, but googled how to do it, and had washer/bolt/nuts with a couple of spanners, but it just wouldn't expand enough to hold properly. Any tips on how people did it, or recommendations on a tool that will fit in that space? Thanks. Last edited by widetyres; 08-02-2021 at 12:45 PM.. |
08-02-2021, 12:44 PM | #371 | |
Rep 3,539
widetyres279.00 |
08-02-2021, 12:55 PM | #372 |
844
Rep 1,962
Did you not consider deploying Brute Force to "realign" the pipe?
08-02-2021, 12:57 PM | #373 | |
844
Rep 1,962
widetyres279.00 |
08-02-2021, 02:11 PM | #374 | ||||
Rep 488
Tags |
bmw m3, bmw m4, carbon fiber strut conversion |
