11-20-2023, 11:03 PM | #1 |
Rep 200
Drives: 2021 M2C
What is the torque on the front and rear brake bleeder bolts?
I flushed the brakes for the first time on my M2 Comp, and torqued the brake bleeder bolts to 10NM, like most calipers. Unfortunately, it seemed like the bolts were very slightly weeping some brake fluid. I looked in the shop manual and it said 18NM for Brembo brakes, which is tighter than I expected (but that page was very confusing since it gave different torques for different calipers, so I feel it was generic). I started to torque them to that, but it felt like I was turning them way more than it took to loosen them, so I chickened out. I didn't want to strip or ruin anything. I stopped and loosened the torque wrench until it clicked without tightening the screw more, and I was at about 16.2 NM. It seems like they aren't leaking anymore.
The thing is, I am very anal, and want them torqued to the "proper" torque as per the manufacturer. Can somebody please help me out with the proper torque? PS- I did the brake fluid flush on my wife's 540i Xdrive with the M Package on the same day, and had the same exact results (weeping), but only on the fronts. With the M package, it seems like the fronts are Brembo (but slightly different than the M2), but the rears look a little different, they seem to be a more standard design with a sliding carrier. |
11-21-2023, 12:50 AM | #2 |
Rep 8,970
They do dribble a bit from inside the bleed bolt, just wipe it up with a paper towel. What angle is the bleed valve at?
If it was really weeping when standing then it would spray out when you applied the brakes... Never torqued one in my life, just nip it up by hand with a small spanner. |
11-21-2023, 02:04 AM | #3 | |
Rep 200
Drives: 2021 M2C
Take a look at the factory manual specs: Last edited by Up4speed; 11-21-2023 at 02:17 AM.. |
terrywang94.00 |
11-21-2023, 04:31 AM | #4 |
Rep 8,970
It seems alot for a small steel screw in soft alloy.....
Better make sure you're torque wrench is a good small (1/4") low range one, not using a 200lbft one turned down to 17... |
///MPhatic13862.50 |
11-21-2023, 09:38 AM | #6 |
The Seeker
13863
Rep 3,323
Pure fear tightening these. I never do them to spec. I tighten, check for weeping after a few days, then tighten a bit more if necessary, but it usually isn't because I note the clock position before loosening, and always put it back exactly where it came from. I even made a specific nipple wrench (the one in the middle) so I didn't have to rotate it from side to side because that changes the clock position.
11-21-2023, 11:12 AM | #7 |
Rep 200
Drives: 2021 M2C
11-21-2023, 11:15 AM | #8 | |
Rep 200
Drives: 2021 M2C
11-21-2023, 11:36 AM | #9 | |
The Seeker
13863
Rep 3,323
I'll also say that if you just pull the bleeder tube off and replace the rubber nipple cover it'll weep out what was in the top of the nipple over time, so you have to clean the area really well, then dab the top of the nipple with a paper towel or rag until all of the brake fluid is gone before replacing the rubber cover. |
11-21-2023, 04:06 PM | #10 | |
Rep 8,970
Do you mean static weep or weep when brakes are applied and held? Two very different things. |
11-21-2023, 04:40 PM | #11 | |
Rep 200
Drives: 2021 M2C
11-21-2023, 04:46 PM | #12 | |
Rep 200
Drives: 2021 M2C
It is definitely not behaving like the other dozens of times that I've done this job. That's why I'm searching for a definitive proper torque. |
11-22-2023, 05:11 AM | #13 |
Rep 3,337
You can always try replacing the bleed screw (aka "ventilation valve") with a new one as they aren't too expensive: looks like $9.72 discounted. I'm surprised they're this expensive now, but then again part-flation I suppose, as the part is widely used across many models.
Were the screws very tight when you started working on it? Many years ago on an E46, a BMW service department way, way over-tightened the bleed screws (under warranty/maintenance), and when I later bled the brakes and normally tightened the screws, they weeped. I had to end up tightening them almost as much to stop the weeping. I replaced the screws and that helped a bit, but I assumed the seat in the caliper where the screw face interfaces had some damage. From then on for many years, they (both rear calipers) required very high torque to stop the weeping, but I could always just crank them down and get by.
Current Stable:
11-22-2023, 02:20 PM | #14 | |
Rep 200
Drives: 2021 M2C
