BMW M2 Forum > BMW M2 Competition Model > Lowering with spacers...
      10-04-2022, 03:56 AM   #1
CM18 CMR
Drives: BMW M2C 2019
Hi,
Just looking for advice from anyone thats lowered their M2C and used wheel spacers. I am looking at the 20/25mm lowering kits but for the wheel spacers there are 13mm, 16mm and 20mm options, what have you used or which spacing would you recommend?
Thanks in advance
VonB1119.00
      10-04-2022, 11:16 AM   #2
Boysie56
Drives: BMW M2 Competition
Originally Posted by CM18 CMR View Post
Hi,
Thanks in advance
I used to run 15mm front 12mm rear. So 16 and 13 should work
      10-04-2022, 11:25 AM   #3
///MPhatic
The Seeker
///MPhatic's Avatar
13863
Drives: OG M2 • Exige
Hi,
Thanks in advance
Stock height is 620/620.
Normal drop is to 595/600.
Some guys run a little lower at 590/595.
Rare that anyone runs under 590/595.
In all lowering cases, with stock wheels and stock sized tires the standard is 12 front, 10 rear spacers for a great flush fit with no rubbing.
However, I have seen some guys get away with 12/12, 15/12, 15/15 with minimal rubbing.
The biggest thing to consider is the tread width of the tire you are running, and plan to run in the future. 15mm up front rubbed for me with the stock PSS (a wide running tire), but didn't rub when I got the same size (but in fact, skinnier) PS4S.
A safe rule of thumb is 12/10, and if you can't get that then I'd look elsewhere for your spacers.
You might browse a bit through this thread: https://f87.bimmerpost.com/forums/sh....php?t=1251250
Appreciate 5
M3R12168.50
VonB1119.00
LBBFTW9.00
      10-04-2022, 09:48 PM   #4
M3R1
Drives: ///M2cs
Great post! Trust this man...
BSM ///M2cs, 6spd
///MPhatic13862.50
      10-08-2022, 06:54 PM   #5
VonB
Army Welder
VonB's Avatar
Drives: 2008 AW E92 M3
2008 BMW M3   [7.00]
I went with 12mm F and 10mm R and I'm on Eibach lowering springs.
2021 M2 MT SO
IG: von_bee_
YT: VonB
      10-10-2022, 04:26 AM   #6
CM18 CMR
nice video, good to see how its going to look now i have ordered up the parts. its also convinced me on the M sport splitter and rear lip spoiler. I was originally going to wait to save the money for the full kit but it doesnt look like it needs it all right away to look good.
VonB1119.00
      10-10-2022, 04:29 AM   #7
VonB
Army Welder
VonB's Avatar
2008 BMW M3   [7.00]
Thanks and post it whenever you get it installed 😎
2021 M2 MT SO
IG: von_bee_
YT: VonB
      10-10-2022, 05:13 AM   #8
barnshaw292
Drives: M2 Competition
I have an m2c with 20mm eibach Pro springs and 12mm spacers. On standard 788 wheels you get the tiniest of rubbing up front on full lock. That's it. I wouldn't want to run more than 12mm all round. Looks and drives fine though.
      10-10-2022, 08:53 AM   #9
M2_papi
M2_papi's Avatar
Drives: 2020 M2C
Eibach springs, 12/10 spacers
20' HS M2C | 6MT
      10-10-2022, 10:58 PM   #10
billypopo
Drives: Bmw 435i GC, glacier silver
Eibach, 12/10
      12-01-2022, 08:08 AM   #11
m2ss
m2ss's Avatar
1790
Drives: people crazy
Great post, I'm thinking of lowering 595/600 with 10mm all round but tire size 255/275 PS4S on 763M wheels. Your thoughts on potential front rubbing?
Thanks...
      12-01-2022, 08:12 AM   #12
///MPhatic
The Seeker
///MPhatic's Avatar
13863
Thanks...
You shouldn't have any rubbing at all, although since every car is different I can't say for certain.
Remember that the stock 245 PSS runs WIDE, so the 255 PS4S is almost identical in terms of tw. Beyond that, you're going 2mm inside the common 12mm front spacer, so I'd bet you'd be fine, and even if you did rub it'd be super minimal and not damaging.
      12-01-2022, 08:33 AM   #13
m2ss
m2ss's Avatar
1790
Thanks.
      12-03-2022, 01:00 PM   #14
Travo20
Travo20's Avatar
Drives: 2020 BMW M2 Comp
MSS lowering springs and 12.5 mm spacers
Attachment 3047342
      12-04-2022, 03:21 PM   #15
m2ss
m2ss's Avatar
1790
^^^looks perfect...
      01-06-2023, 12:32 AM   #16
projekt-
Cruisin'
48
Drives: '19 LBB M2C 6MT
m2ss let me know your results on your drop + 10mm all around with 255/275. This is the path I may take as well.
      01-06-2023, 07:20 AM   #17
m2ss
m2ss's Avatar
1790
Will be installing MPS or Dinan HAS with the 10mm (future classic) all round on 763m Cup2s stock size for now (as they come with the wheels).
I will then decide on going different size.
Will be doing this in about 3 months and let you know/post pics.
2020 M2C
2018 M2 LCI
Gone 1M, 991.1, 991.2, 718S, 991.2 TT, R8 Spyder RWD
      09-30-2023, 09:56 AM   #18
NathObeaN
NathObeaN's Avatar
1308
Drives: M2 Competition (MY2021)
I’m curious why everyone seems to opt for 12/10 rather than 10/10? I’m thinking of adding spacers to the following setup:
255/35/19, 275/35/19, Bilstien B16 with -2.5 camber. I’m guessing with the camber, 12 at front will look more ‘balanced’…
      10-03-2023, 07:35 AM   #19
m2ss
m2ss's Avatar
1790
I went 10/10 and love it...
2020 M2C
2018 M2 LCI
      10-24-2023, 03:55 AM   #20
BEAR_S55
BEAR_S55's Avatar
Drives: BMW M2C
Thought I’d throw my hat in, I’m on eibach lowering springs and 14mm spacers front and rear. No issues at all even running 275 rear tyres and still 245 front.
m2ss1790.00
