02-22-2023, 11:52 AM | #89 |
Rep 95
Does NOT work with Apple Car Play
Just had my M2C updated. Dealer said everything was working fine but I tried to make SOS call after I picked up and problem was same - No audio. I then tried again (NOT in CARPLAY mode) and the voice call went through fine. SO, the update does not work if you are in Apple CarPlay mode. You need to click on Menu or Map to get out of CarPlay and voice will work fine after the update. Hope this helps.
02-22-2023, 12:59 PM | #90 | |
Rep 1,227
02-22-2023, 02:03 PM | #91 |
Rep 7,298
It could be a bug with the software... I mean, I probably wouldn't bother because the odds the dealer can fix it without screwing anything else up is pretty low IMO, lol.
02-22-2023, 05:42 PM | #92 |
Rep 101
Went in for oil change and was told I’m also due for this software update…After reading through the thread I don’t mind doing the update, but my (maybe dumb) question is - can the dealer do anything on the software side that makes the ECU not unlockable? I have a ‘19 which should be unlockable, so I wouldn’t want to do the update if it’s gonna mess with that.
02-22-2023, 05:52 PM | #93 | |
Rep 605
Drives: M2C
Not banking on getting the car back today. Hopefully tomorrow? Did nobody here have a mirror tap? edit: pretty sure i followed this video which says it taps into the rain sensor. Who knew it'd relate to the head unit... I remember it taking me about 45-60 mins to do because I am a DIY noob. I hope I don't have to redo it! Last edited by ESB; 02-22-2023 at 05:59 PM.. |
02-23-2023, 12:10 AM | #95 | |
Rep 7,298
Fred Conoway365.00 |
02-23-2023, 04:07 PM | #96 |
Rep 4,048
02-24-2023, 11:31 AM | #97 |
Rep 95
02-24-2023, 02:30 PM | #99 |
Rep 605
Drives: M2C
The takeaway I got from the thread is that the only things you'll need to redo are the options/features under the Headunit section of bimmercode.
I haven't been able to validate that myself since my car still is at the dealer. Hoping to get it back today but not betting on it. |
02-24-2023, 03:13 PM | #100 | |
Rep 962
I'd avoid at all costs...
2020 M2C
2018 M2 LCI Gone 1M, 991.1, 991.2, 718S, 991.2 TT, R8 Spyder RWD |
02-24-2023, 03:15 PM | #101 |
Rep 605
Drives: M2C
02-24-2023, 04:02 PM | #102 |
Rep 7,298
02-24-2023, 04:07 PM | #103 |
Rep 4,048
02-24-2023, 04:11 PM | #104 | |
Rep 962
2020 M2C
02-24-2023, 04:46 PM | #105 |
Rep 605
Drives: M2C
Got the car back!
So, lots of things seemed to have been reset. M Drive modes reset, full screen carplay is back to stock, ASD is back on, idrive remained on after opening door, lawyer screen ... I suspect everything from bimmercode was reset but I don't think I had tweaked with much else. Was able to turn ASD back off and change the idrive setting, but I am unable to access the Headunit section in Bimmercode now. It says "Exporting activation codes" and then pops up an error "error while reading coding data". Seems like the same think Frank K hit on page 2 ... Frank did you ever get that working? Here is the "activation codes" screen... Remember, my software update ran into some issues which is why it took so long. Here is what the invoice says. I wonder if some of this is related. "Performed SIB 84 08 22, completely programmed vehicle. Upon programming found vehicle to be asking for an enabling code, tried multiple times to download and install enabling code. Found activation to be failing every time, left with shop foreman for further diagnosis on concern. Submitted TSARA case [....], reprogrammed vehicle and performed enabling code activation measure after Technical created new activation codes. All features function normal now." |
FractalFootwork142.50 |
02-24-2023, 05:11 PM | #106 |
Rep 605
Drives: M2C
03-01-2023, 05:19 PM | #107 | |
Rep 605
Drives: M2C
The screen got taken over by an “emergency” screen showing my latitude and longitude. Initially I didn’t hear anything but after 30-60 seconds I started hearing “an operator will be with you shortly” and that message repeated for maybe 2-3 minutes and eventually I got connected to a live person. So, it worked fine for me. This is maybe obvious but make sure your volume isn’t muted before pressing SOS? Ideally this shouldn’t matter but I wonder if it does. |
03-02-2023, 12:06 PM | #109 | |
Rep 95
03-02-2023, 01:23 PM | #110 |
Rep 95
Dear Customer,
Thank you for contacting BMW Assist Customer Care. VIN: Please be advised we see a provisioning issue on the back end, please make sure vehicle is out in the open and Bluetooth is off on your phone before performing the steps below. We recommend performing an Update Services in your vehicle to refresh the connection. This can be done by following the steps below: -Navigate to “ConnectedDrive” and select -Click the physical “Options” button (surrounding your iDrive controller) -Click on “Update BMW Assist” -Finally, remove the MYBMW app from your phone and then reinstall the app. Once the update completes, we recommend shutting the vehicle off and allowing a few minutes before restarting the vehicle to check the connection. If any issues, please share the error image/screenshot directly to this e-mail. Our days of operation are Monday-Friday; 8:30 AM-5:30 PM EST. Sincerely, ConnectedDrive Services Customer Care |
