01-27-2014, 10:28 PM | #1 |
Rep 55
Bi-turbo Vs. Twin Turbo
I know what the difference is between the turbos. I'm just wondering if one is more sufficient than the other? I drive a 09 e90 335i. Ive heard its more efficient and I've heard doenst matter. Just needed more opinions.
01-27-2014, 11:06 PM | #2 |
Rep 76
Drives: BMW M2 Competition
Bi = 2
Twin = 2 Therefore: Bi = Twin
“You've gotta dance like there's nobody watching, Love like you'll never be hurt, Sing like there's nobody listening, And live like it's heaven on earth.”
01-28-2014, 12:21 AM | #3 |
Rep 409
Does it have anything to do with sequence as in parallel or series?
09'M3 JerezB/Tech/Cold/Prem/PDC/SR/Black Leather/ANTHRACITE Sycamore/IPOD/USB/Rear Sunshade/Premium Sounnd/6MT***Just Hit The Ground! Delivery 02/25/2009***
01-28-2014, 12:26 AM | #4 |
California-bound
385
Rep 1,480
I have always heard of twin turbos (N54) as being in-parallel, and bi-turbo (a la FD RX7) as being in-series. I'm not sure it really matters either way you splice it, it's just different terminology...
Streets of Willow: 1:27.7 CW 11/15/15; 1:29.5 CCW 8/15/15 |||| Autoclub Speedway ROVAL (CCW): 1.52.6 - 12/2/17
Willow Springs - Big Willow (CW): 1:35.8 - 3/31/18 |||| Buttonwillow #13 (CW): 1:59.3 1/27/18 https://www.facebook.com/JakeStumphRacing |||| http://www.youtube.com/user/RaceMeMZ3 |
01-28-2014, 12:46 AM | #5 |
Rep 4,959
BMW prefers to use "twin turbo" nomenclature when referring to a motor utilizing two turbochargers.
Mercedes, on the other hand, prefers the "biturbo" nomenclature. Both references basically mean the same thing but separate labels help to distinguish the brands when the terms are used to describe each brand's respective motor setup/technology.
Current: '23 G20 M Sport 330i
Current: '20 X253 GLC300 SUV Gone: '20 W205 C43 Sedan Gone: '18 W205 C43 Sedan Gone: '13 W204 C63 Sedan |
01-28-2014, 11:05 AM | #6 |
salty cowboys fan
6185
Rep 3,418
Just a guess, twin sounds like it was maybe a colloquialism that caught on and stuck, like Bimmer or Lambo
Bi-turbo sounds more technically accurate... Germans |
01-28-2014, 12:46 PM | #7 |
Rep 1,922
Drives: 2011 e91
I always thought that twin meant two turbos that feed a single intake plenum, and bi meant that each turbo fed its own plenum
2011 E91
2016 M2 - Sold 2014 X1 - Sold 2002 Land Rover Discovery II - 3" lift & 33s |
01-28-2014, 12:52 PM | #8 |
Rep 9,160
I assume the confusion here is just in wording. N54 = twin turbo. N55 = twin scroll single turbo. As stated earlier, for twin turbos, there's also the issue of whether they work in series or parallel.
01-28-2014, 01:18 PM | #9 |
Rep 5,686
sequential twin turbo is better I think as one spools up while the othe is kicking it. That way you have continuous momentum build up vs. plateau.
bi = twin are the same. n54 is twin turbo n55 is twin scroll single turbo n54 is more tunable from what i heard, but i could be wrong. the last time my sister had Supra Turbo - we blew the turbo by running it too hot. :-(
Un4gettable 435i Extended Test drive thread: http://www.f30post.com/forums/showthread.php?t=881491 |
01-28-2014, 02:39 PM | #10 |
Rep 203
BMW is partially responsible for much of the confusion. When they named their N55 ' twinpower' it confused many. I also think it was intentional, to let customers believe the new engine was still a twin turbo layout.
01-28-2014, 08:18 PM | #11 |
Rep 1,404
I cannot believe this subject is being discussed (????).
Name: Blanca | 07 E92 | AW-Blk | ZSP | Alcon BBK | M3 Bits | VM RR Links | Koni | UUC Sways | V5 | Dinan CAI | ETS IC | Fge DV | ER CP | Cyba | Raden. Exh | Mod Step | Trunk Drawer | Perf LED Wheel | Illum Dr Sills | IS Shifter | Parrot | Philps D1S | 6000k fog | MTECH RR | CSL Trunk | Aero | Roof Spoiler | PSS on BBS RS-GT 19s
03-26-2014, 08:03 AM | #13 |
Rep 112
Drives: 2008 BMW E90 335i
I always thought that twin-turbos were two turbos of same size, which spooled up at the same rate and rpm, and bi-turbos two turbos of different sizes that spooled up at different rpms. For example, on the bi-turbo, one turbo would kick in earlier at the lower rpm and the other at a higher rpm to eliminate turbo lag. In order to make engines more efficient and to eliminate turbo lag, the Japanese had engines with both supercharger and turbocharger; the supercharger activates at lower rpms and the turbos would kick in at higher rpms ensuring constant power range.
I could be wrong with the whole bi/twin theory, but a supercharged/turbocharged engine does sound interesting. You would need a lot of room, and the N55 535i has a lot of room left and right side in the engine bay compared to no room at all in the N54 335i engine bay. |
03-26-2014, 09:00 AM | #14 |
Retired BMW Genius
2903
Rep 3,404
Don't fall for BMW's marketing ploy. BMW calls the N20 a TwinPower Turbo. It's not, it's a single turbo, twin scroll.
03-26-2014, 11:53 AM | #16 |
Rep 162
Because?
-Experienced driver; cocomats
03-27-2014, 12:44 PM | #19 |
Rep 253
Uuuuuhhh, marketing.
Enjoyed some fun cars over the years: 1966 Corvette Convertible, 240Z, E24 L6, 300CE-24, 2004 645 Ci, 550SL, A6s, 535xi, E300/Bluetec/420, Grand Cherokee Overland, 2012 650i Coupe, 12 CL550, 13 SL550, 15 650i Coupe
