09-08-2021, 12:12 AM | #67 | |
Rep 547
Closer to the OP topic, I look forward to driving a manual C or CS to be able to compare more one day, but the DCT in the CS is very 'engaging', and satisfying to punt hard or cruise. |
chris7197363.50 |
09-08-2021, 02:39 AM | #68 |
Rep 2,208
Drives: G81 M3 Touring (Frozen Black)
I've never read anyone saying the roof improves the 6MT shifting experience. That's a new one
MadBimmeRad7122.50 |
09-08-2021, 08:52 AM | #69 |
Rep 1,657
Pretty sure they used special blinker fluid in my M2 CS. It should last the life of the car. My blinkers are so much smoother and more quiet than the blinkers in my M2C
This also enables me to enjoy the shifter experience more as I'm shifting without the additional noise from the blinkers with the old fluid. Maybe it's just me but me thinks that makes a big difference when comparing the C to the CS.
1995 LTW: Modified by BMW NA Factory team from new
M2 CS: CF Buckets & more (track toy) Last edited by ptgltw; 09-08-2021 at 09:12 AM.. |
09-08-2021, 04:54 PM | #70 | ||
Rep 99
1. Three different GHAS settings (DSS TASC / DSS IPM):
2. Three different MDM settings:
3. Two different EPS settings :
So, it seems like different software settings for GHAS/MDM is a contributing factor. I have the CS GHAS/MDM/EPS settings coded for my OG, and I felt significant difference in steering/handing characteristics. I am not sure about available coding options for DCT, as I have a manual transmission. More information can be found here: https://f87.bimmerpost.com/forums/sh....php?t=1605090 |
09-08-2021, 05:04 PM | #71 | |
Rep 7,318
Yep, there are DCT options also. It's been known for a while as you mentioned. I also wonder if those settings do different things with 2021 ISTEP. I thought there were 3 EPS settings? Last edited by chris719; 09-08-2021 at 06:18 PM.. |
09-08-2021, 07:02 PM | #72 | |
Rep 99
I was hoping for 3 EPS settings in the new iSTEP (with an additional unique setting for CS, so I could experiment), but there are only 2 settings for F87 (F87 for OG and F87CS for M2C/CS). See the last photo attached above for all available options. A lot of people have used F82GTS steering on F87 as an additional option. |
Megator517.50 |
09-09-2021, 01:49 AM | #73 | ||
Rep 744
The first 2 I don't really notice. Steering is a bit heavier but it's hard to say it has more feel. I never use MDM, on the street it's full traction because these cars like oversteering at any moment lol. On track I run DSC off so no difference. The diff made a huge difference, it locks way sooner and harder now making it great to put the power down out of a corner but more likely to do a fat drift if you lack throttle control. Might try the CS steering.
chris7197363.50 |
09-09-2021, 03:35 PM | #74 | |
Rep 2,208
FaRKle!4023.50 MadBimmeRad7122.50 |
09-10-2021, 01:41 AM | #75 | ||
BMW forever!
1392
Rep 2,423
Some of us get cars we like!
2020 BMW X5
2019 BMW M2C 2014 BMW 335i 2009 BMW 328i |
chris7197363.50 |
09-10-2021, 02:38 AM | #76 |
Rep 7,318
I hope to drive a CS soon to see how it is. I have to say, I hope it’s lighter than the other F8x steering.
My Z4M had much more honest steering than any E9x or F8x I’ve driven, and without being overly heavy. I used to complain about E9x (non M) having artificially heavy steering, and to my disappointment, BMW seems to have kept the weight only as if they believed weight == feedback. I almost exclusively use Comfort on the M2C as do most of the instructors in Spartanburg. Ultimately, it’s not a big issue with the car as a daily driver. As a track tool I’m not sure. I suggest people that think any BMW after E46 has good steering feel drive a Porsche 997 or 997.2 911. Those racks make the Z4M feel mediocre. Closer to E36 levels of feedback. Time marches on, so I’m not expecting anything new to steer like a car from 1996. Still, it would be nice for BMW to stop pretending that more effort means better. I blame journalists for this. Last edited by chris719; 09-10-2021 at 02:44 AM.. |
09-10-2021, 06:18 AM | #77 | |
Rep 2,363
BSM ///M2cs, 6spd
chris7197363.50 |
09-10-2021, 06:37 AM | #78 | |
Rep 2,208
chris7197363.50 |
09-10-2021, 07:08 AM | #79 | |
Rep 2,363
The car is spectacular with everything in comfort.
BSM ///M2cs, 6spd
09-10-2021, 08:47 AM | #80 |
Rep 2,819
Drives: e82 1M, f87 M2cs
It's the programming, not the EPS itself. My 2004 RX8 has EPS. If you drove it you wouldn't know if I hadn't told you.
09-10-2021, 10:04 AM | #81 | |
Rep 221
But I've done more research on steering feel this year, and it can also be greatly affected by car weight, tire width, and suspension geometry. The BRZ weighs 700lbs less than the M2, has 30mm narrower front tires, and potentially has better suspension geometry from the lower center of gravity.
2017 F87 M2: MGM, 6MT, AA Tune, Eibach Pro-Kit, Fabspeed Catted Downpipe, Evolution Racewerks FMIC+Chargepipe, Autosolutions SSK, CDV Delete, Vorshlag Plates, PFC-08 pads, Apex EC-7 18x9.5"
2013 E92 328i M-Sport: BSM, 6MT, 3IM+AA Tune, BMW PE, M3 control arms, Eibach Pro-Kit, Bilstein B8, BMW SSK, CDV Delete, Apex EC-7 18x9" |
chris7197363.50 |
09-10-2021, 10:04 AM | #82 | |
Rep 1,657
For what it's worth. I track my CSR in rain mode and so do many other pro race teams. Who needs the extra wear and tear on the trans from slightly faster / more aggressive shifts? Also rain mode makes shifting in the turns a breeze. Sorry a little off topic.
M2 CS: CF Buckets & more (track toy) |
09-10-2021, 10:15 PM | #83 |
Rep 3,086
I switch between my M2CS and Z3 each time I drive. As many probably know the Z3 is known to have the best e36 steering with the quick rack and it was a popular mod to replace the stock rack in e30s and other e36 models. I also had all the front bushings replaced in the Z3 to bring it back to its original feel.
So. As I alternate just about every drive I get to experience the differences all the time. If you distill it to one sentence. The Z3 feels organic and M2CS feels manic. With the CS (I have Cup2) you can actually feel the surface of the road. It tramlines more. Turns in much faster and is probably far more irritating to the non enthusiast driver. But I love this. This I feel is the main difference to the C. The C has more of a comfort bias built in to appeal to more people and to make it less nervous. It still points well all the same. I use sport in the CS. Steering weight is about the same in both cars. Neither are the overly light one finger steering Americans seem to love. They are just right for me. I love them both. Very different experiences but both very therapeutic. That's what I want most from cars. Numbers don't matter to me. I just need them to make me feel good. |
Jimjamz4599.50 MadBimmeRad7122.50 |
09-13-2021, 09:21 PM | #84 |
Mmmm... Bavarian
2129
Rep 1,690
Spending a lot of time in the M2 comp today and tomorrow with the M Advanced school. Then more time with my CS this weekend on track as well. Will be interesting I continue to compare and contrast them but the difference between in steering is so immediately obvious and different it is pretty amazing.
And on a side note, damn is the G80 impressive to drive.
M2 CS
2023 CB X5 45e 2018 i3 94 2014 Cayman S |
09-14-2021, 01:17 AM | #85 | |
BMW forever!
1392
Rep 2,423
2020 BMW X5
09-14-2021, 04:09 AM | #86 |
Rep 2,208
They seem to be very different cars. To the point we're aiming to get a G81 to replace our G02 X4 end of next year - it will be the garage buddy for the F87 CS not a replacement for it. I wonder if many will cross-shop them?
09-14-2021, 06:49 AM | #87 |
Rep 3,086
I stepped out of one after an extended test drive and into the other (my CS).
The answer is… it depends. G82 is supremely confident. F87CS is supremely entertaining. What floats your boat? I'm in the raw feeling entertainment camp. Others may not be and I get that. Depends what type of boat you want to float. G82 feels like a floating spaceship from another dimension. Pretty amazing really. F87CS feels like a car from at least 10 years earlier but still just as quick even though it requires a lot more participation. Much more sensation of speed and connection in CS. Effortless speed in g82 and you have no idea how fast you are going. What are you after? That decides your choice. |
buckybadger1391.50 |
09-14-2021, 09:08 AM | #88 | ||
Mmmm... Bavarian
2129
Rep 1,690
M2 CS
buckybadger1391.50 robopp1718.50 |
Tags |
6spd, gold 763m wheels, m2cs |
