04-25-2023, 12:50 PM | #1 |
Rep 4,699
What reduces braking zone distance?
Hoping some can explain the factors that go into reducing brake zone so I can put together a game plane. Swapped in the Carbotechs xp12s. Brake zone distance decreased on lower speed corners, but I'd say stayed similar in distance to cool factory pads. I could get into ABS if I were hard on the brakes at the end of a brake zone because I was to aggressive. Usually this was if I overshot the turn point too much because I hadn't scrubbed enough speed to turn in.
I can't decide if I was still overheating the xp12s and need do go to a higher temp compound? The brakes were always there by the next corner. Felt pretty solid, but would get a little softer after a few consecutive laps. My day was short and I wonder if they weren't quite bedded yet. Still a big improvement over the factory brakes. I'd run XP12 on the street if weren't loud. I'm pretty sure I need more tire. I don't plan to run the cup2 connects on track any more. Bias was still pretty good. I thought I could use a bit more rear, but that might lead to trouble since I like to occasionally trail brake. I don't think I'd run a higher compound in rear. Would stickier tires and higher temp brake compounds help shorten brake zone. Or am I running into a brake cooling issue. Higher temp compounds might just mask another issue and making brake consistency really unstable as the pads heat and cool on different parts of the track
04-25-2023, 03:09 PM | #2 |
4730
Rep 2,554
Braking is a function of grip - to shorten the distance you need to improve the grip. Stickier tires, more downforce, etc. I'm oversimplifying it a bit but that is the main focus. You can start getting into rotational mass, vehicle weight, etc but in the end if you overwhelm the amount of grip you have available either it kicks in abs or locks up. If you make the pad grab the disc harder than the tire has available grip - it doesn't matter how much braking force you have as the tires are going to lose traction. Track pads primarily change the characteristics and/or increase fade resistance. You really shouldn't see an increase in braking performance with them. You should however see them hold up to fading much better than the factory pads.
Same thing goes for a BBK. You don't by them to reduce the braking distance - you buy them to reduce fade. A kit like the Essex/AP will actually reduce it a bit due to the weight savings but the main reason to run them is to eliminate fade - which is easy to do on the heavy, fast cars. Certainly other benefits to them as well but that is the main driver behind running them. |
04-25-2023, 08:15 PM | #3 |
Rep 424
Drives: F87 M2 DCT, F15 X5
How big your pair is will have the greatest influence on braking zone length
Followed by tires, brakes, suspension geometry, weight balance, ect. Are you running stainless steel braided lines? Are the tires falling off in other attributes (lateral grip, corner exit grip)? |
04-25-2023, 08:22 PM | #4 |
Rep 4,699
Stock brake lines. I definitely push the brake zones. Sometimes too much. .
04-25-2023, 10:36 PM | #5 |
Rep 584
Start with ensuring your technique is good, then improve your rubber
2017 BMW M2 5Spd, 2007 VW Touareg, 2023 Yamaha MT09 SP
https://www.instagram.com/dvas99/ https://www.youtube.com/channel/UC2j..._as=subscriber |
04-25-2023, 10:48 PM | #6 |
Rep 4,699
Definitely room to fine tune technique. Sometimes I think I might test various modifications too much. Some get me into trouble. Working on trail braking and being able to get on the throttle sooner on corner exit is a focus. I think that's where I found a lot of time this last event. That being said, I don't like feeling like my car equipment isn't in synergy. I might invest in a better data recorder so I can analyze my laps better. It's difficult right now with minimal information being recorded. I'd like to have the brake and throttle positions recorded. First thing will be a second set of wheels with a dedicated track tire. I've already got the RT660s. I don't think they are extreme, but hopefully last a little longer and remain consistent under the abuse.
04-26-2023, 05:17 AM | #7 | |
Rep 424
Not sure what events you do, but having a seasoned instructor or other driver jump in the car and provide some free coaching is always one of my go-to moves when I’m struggling with something. A lot of people I track with use a Garmin Catalyst which they like. I’m using an AIM Solo 2 (don’t have catalyst money haha). Consider focusing on consistency first. Do a session where you intentionally brake exactly in the same spot each time and “log” in your head how the car feels. Then next session like 1-2 corner where you brake a little later. “Log” and compare in your head or on paper how it feels. Write it out, keeps the head fresh for the next session to remember things.
‘18 F87 M2 DCT
'17 F15 X5 xDrive35i M-Sport Sold in 2023 '12 F30 335i 8AT Sport Line Sold in 2020 '08 E92 335xi 6MT Sold in 2016 '08 E90 335i 6MT - FBO Last edited by E90convert; 04-26-2023 at 05:26 AM.. |
04-26-2023, 10:14 PM | #8 | |
Rep 75
When I was racing spec miata I ran Hawk pads (DTC60 and DTC30s for certain tracks). At one point I was talked into to trying G-Loc pads (which are some of the Carbotech guys that left), tried them for a practice and qualifying session, and hated them so much I spent the time to change them before Saturday's race in 90 something degree heat. The co-efficient of friction was too low unless I stood on the brake pedal and when they locked up they were very hard to modulate at limit. The initial pedal feel was not very good and it got more inconsistent as they got hotter. Having said that, there were still plenty of people running Carbotech/GLoc pads with success but they did not fit my driving style at all. Give DTC60 (or 70s if you want insane friction) for your next track day and see what you think. |
04-27-2023, 09:55 AM | #9 | |
Rep 4,699
