09-25-2020, 07:42 AM | #1 |
Rep 166
Dash Cam Install Without Running To Trunk
I have an Anker Roav C1 dash cam that I pulled out my by previous car and it has a "parking mode" with built in battery so it will turn on at impact if the car is off and I wanted a clean install where I could hide the wire as much as possible. While this is a great install guide, I wasn't interested in running the wire to the trunk and tapping into the fuse box. Partly because I'd have to purchase a new cable but mostly because it was more work -- work smarter not harder! I also didn't want the wire sticking out of the cup holder area or having the wire hanging out of the center console so instead I routed it to the rear 12V cigarette lighter adapter. I don't think that socket would EVER be used otherwise.
I found that the 10-12ft USB cable it came with would reach if I routed the cable just right so I tucked it underneath the roof lining and behind the weather stripping but instead of going all the way down to the door sill I went straight across the bottom of the glove box and was able to tuck it between that and the trim then tucked it behind the center console trim and had just enough to plug it in the rear 12v. Check out the video below if you're interested. I hope this helps others! |
09-26-2020, 12:03 AM | #2 |
Rep 555
Good video! Very creative way to route the dashcam. One question: does the cinerite light port lose power when the car is shut down? Does the parking mode work if that's the case then?
If it's keeping the 12V power when the car is down, wouldn't this be draining the battery power till it depleted?
IG: M2C_SO |
09-26-2020, 08:03 AM | #3 | |
Rep 166
Fabb228.50 |
09-26-2020, 08:21 AM | #5 |
Rep 166
10-07-2020, 10:11 PM | #6 |
Rep 14
10-08-2020, 04:11 AM | #7 |
Rep 1,336
Not sure if there is a compatible tap from these guys. Maybe reach out to them
https://www.mirrortap.com/index.html
10-08-2020, 09:49 AM | #8 | |
Rep 166
10-08-2020, 09:50 AM | #9 |
Rep 166
10-08-2020, 09:59 AM | #10 | |
Rep 744
This is how a lot of cams are wires, GND, constant 12V and switched 12V (ignition signal) to let it go into parking mode. OPs has a battery for parking mode which is also a solution. OP how long does the internal battery last BTW? and also BTW it is probably constantly filming without saving it to the SD card (its stored in an internal buffer memory) otherwise it wouldnt be possible to get the 5-15sec before "impact" on film.
10-08-2020, 10:27 AM | #11 | |
Rep 166
10-09-2020, 02:43 AM | #12 | |
Rep 744
BTW for thoose who wonder what parking mode is good for. https://drive.google.com/file/d/1AqC...ew?usp=sharing In the end I went to the police (no note left behing) who contacted the owner of the car and I got paid for my damages.
10-09-2020, 11:43 AM | #13 | |
Rep 166
10-12-2020, 01:52 AM | #14 | |
Rep 744
Vid might be a bit confusing as the perspective flips halfway through from rear cam big to front cam big.
06-16-2021, 08:16 PM | #15 | |
Rep 891
I looked on mine and there's a hole underneath the glove box the exact size of a power socket, but there's no socket. It's just a hole. So maybe it was there before but since removed? Or maybe mine is just missing the power socket?
Vehicles: 2021 Alpine White M2C 6MT; 2011 Kawasaki Z1000 (1/4 mile 10.3 seconds @ 129 mph - stock)
Previous: 2018 Camaro 2SS 1LE 6MT; 2015 BMW M235i 6MT; 2015 Mini Cooper F56 6MT; 2005 Mustang GT 5MT; 2003 Mini Cooper R50 5MT |
06-18-2021, 07:32 AM | #16 | |
Rep 166
09-02-2021, 07:14 PM | #17 |
Rep 891
I got a Garmin Dash Cam Mini 2 today and am planning on this same install. I don't care about the parking mode. I was just looking for the smallest camera possible that would record the view from the windshield while driving.
So I attached it to the windshield and hooked up the long USB cable to the rear 12v socket. I didn't route the wire yet, but just hooked it up loose to test the camera operation, get the phone app paired, etc. The Dash Cam Mini has no on/off switch, so it just turns on automatically as long as it has power. It also has no battery so it will shut off as soon as the power is off. When I came home from a short ride and shut the car off, the camera stayed on. So I wasn't sure what was going on, since I thought the 12v socket would turn off when the ignition was switched off. Waited a bit, and found out that it stays on for 10 minutes and then does shut off. I guess this is normal and by design, but does anyone know differently?
09-02-2021, 10:51 PM | #18 | |
Rep 121
mine does the same, so I believe it is normal design. Been using my dash cam by this method for almost 6 months now, no issues. |
09-03-2021, 06:47 AM | #19 | |
Rep 166
09-03-2021, 11:42 AM | #20 | |
Rep 891
I routed the wire the same way as in the video. Total time was 10 or 15 minutes. The only part I had trouble with was the trim piece directly underneath the glove box. This is about 54 seconds into the video, where it kind of glosses over how to get the wire behind the trim piece. There is a gap and it seems like two separate trim pieces, but mine are locked together and I was afraid to pry them apart and break something. I couldn't get the wire behind the trim piece or into that gap. It's fine the way it is, but I'm curious whether those trim pieces can be separated more to get the wire behind? Otherwise, I like the stealth aspect of this dash cam, and like the way it's installed.
09-04-2021, 07:04 AM | #21 | |
Rep 166
wjones14658.50 |
09-04-2021, 09:28 AM | #22 | |
Rep 891
Since I know that trim piece needs to come off when the cabin air filter is replaced, I may give the BMW service technician a heads up before the next service that the dash cam wire is running through there now, just so he knows what it is.
