07-06-2020, 03:34 AM | #1 |
Rep 59
Does 18x10 275/35 square fit the M2?
Tried to search for this but cannot seem to find this exact combo.
I would love to run this: 18"x10" rims with Nankang AR-1 275/35 rubber in a square setup. Will I make it in the front? How much camber do I need? Anyone running this? |
07-06-2020, 03:02 PM | #2 |
Dom
1078
Rep 1,710
While my setup is not exactly 18x10 I'm running the following setup which I have absolutely zero rubbing. I'm running -2.5 camber F/R and am at about 25" F to G.
18x10 +20 18x10.5 +33 265/35-18 and 275/35-18 Michelin P4S My rear is about 2mm less aggressive from the fender from running a 18x10 +25 wheel. I actually have a bit of room to go. My fronts have room, it may touch front or rear splash guard at full lock but it doesn't seem like it would be a problem. You didn't state offset but I assume it would be 18x10 +25 as i referenced above. Have you identified your specific wheel yet? |
smellslikecurry1.50 |
07-08-2020, 12:30 AM | #3 | |
Rep 59
Ahh thank you for your reply. I'm thinking of two wheel options. Option 1. Protrack ONE 18x10. They are available in ET20, ET25 and ET40. Option 2. TItan T-S5 18x10. They are only available in ET25. But you're saying that for a square setup 18x10 ET25 should be the best option? I'll most likely run -3 camber to start with. |
M2 GT67.00 |
07-08-2020, 02:05 AM | #4 | |
Rep 4,510
https://f87.bimmerpost.com/forums/sh...6&postcount=15 Also some folks have mounted oem wheels upfront using 15-18-20mm spacers IIRC - maybe worth searching the forum for their cars..??
Current '22 X3M LCI.. |
07-08-2020, 01:02 PM | #5 | |
Dom
1078
Rep 1,710
As Bee Pee mentioned there is another member here that has pretty much your exact option 1. |
07-11-2020, 03:54 PM | #7 | ||
Rep 59
Ok, I didn't know that. :/ |
Mook20.00 |
07-12-2020, 01:13 AM | #8 |
Rep 88
I'm in the same situation as you. Do you have the stock Ohlins springs in the front? If so with those tires you might need a spacer even with ET25, but really the issue is the rear. I was actually able to fit the 18x10 ET25 with 265/35 RS4s (super wide shoulders) in the back, but camber was extreme and there is definitely no room for more tires. With a higher ride height, it will show some poke. I believe the 275/35/18 AR1s have the same section width as 265/35/18 RS4s (I could be wrong), so maybe it can work. Here's a reference.
I believe the perfect ET for a square 18x10 setup would be 28-30. Last edited by M2 GT; 07-12-2020 at 01:23 AM.. |
ebisu81078.00 |
07-12-2020, 09:29 AM | #9 | |
Rep 59
Ok thanks for the input. That is a tight fit. |
07-12-2020, 04:27 PM | #10 |
Rep 360
I run 18x10 et25 square with 275/35 federals RS-rr. Rear fits fine with -2 camber, -2.7 camber front with 5mm spacer in front. My status Gruppe coilovers have a very narrow springs though. I do think I could go 285 all 4
-correction et33!! I was thinking of my old f80 haha
Current:
88? M3 15? M3 84 R100 RT Café Racer Past: 2005 E46 ZCP M3 Silver Grey 6MT 1998 E36 M3 Silver 5MT 1968 E10 2002 Roundie Grey 4MT 2018 F87 M2 BSM 6MT |
M2 GT67.00 |
07-14-2020, 02:55 PM | #14 | |
Rep 59
m3welt589.50 |
07-14-2020, 03:02 PM | #15 |
Rep 59
One more thing. Heard from a local guy that runs an M2 (not a comp) with 19x10 ET40 all around. That is, he has the rear oem wheels is the front as well as the back. He told me he ran:
front: 19x10 ET40 + 20mm spacers 265/35 -2.8 Camber rear: 19x10 ET40 295/30 -2.0 Camber öhlins road & track So all the information I can gather tells me that that 18x10 with 275/35 should fit just fine, with extra camber. ET40 in the back and ET20 in the front. |
m3welt589.50 |
07-14-2020, 08:08 PM | #16 | |
Rep 88
Yes, the ET40 is an easy fit for the rear, the 20mm spacer in front is for strut clearance.
10-06-2020, 12:29 AM | #18 |
Rep 88
Yep!! So I am running the 18x10 ET25 setup with 265 square. I do not have any rubbing on track but I left some room for the ride height & also have stiff rear springs. Either way, it looks like it will clear the rear fender following the camber curve. My rear camber isn't maxed out though because of the stock toe arm. I believe this setup right now will depend on the tire, but with a toe arm in the rear it will be much easier.
Front: -3.5 Camber and 0 toe, 10mm spacer Rear: -2.2 Camber and 0.14 total toe in Some photos for reference: |
10-06-2020, 08:56 AM | #20 |
Rep 855
FWIW, I know TC Kline has a 275 square setup on his M2C using four rear 763M 19x10. Not sure about tire profile or spacers but he does track that setup.
I like the Titan but 10.5 rears might be a bit more problematic? Also need to find our price per wheel vs package price. |
10-06-2020, 03:48 PM | #21 | |
Dom
1078
Rep 1,710
There's so many ways to make it work. What offset are the Titan 10.5? |
10-07-2020, 04:56 PM | #22 | |
Rep 433
