09-29-2020, 12:54 AM | #177 | ||
Rep 488
Thanks for picking it up with them. I have also forwarded them some logs in case it helps the investigation. Did you send them stock tune logs for them to compare against? |
09-29-2020, 01:07 AM | #178 | |
Rep 488
09-29-2020, 09:32 AM | #179 | |
Rep 553
I've deleted the Sport+ throttle (replaced with Sport) in my BM3 custom tune because it was too sensitive. Currently up to 20% accelerator my Comfort & Sport throttles deliver identical acceleration (toggling between the modes & using Bimmerlink for accelerator position). My memory is that with my original iStep (July 17 LCI build) there was a greater difference between Comfort/Sport (current iStep is F020-18-11-531). |
09-29-2020, 02:04 PM | #180 | |
Rep 643
comfort throttle is too lazy, and sport throttle is too aggressive.
M235i rwd 6mt
David.m437.00 |
10-01-2020, 04:26 AM | #181 |
Rep 1,389
Just rang a coding garage but they can't do it as will need to be done via a tune.
Not sure what to do, suppose I can try stage one and see what it's like up top, the engine is willing to rev out at the moment albeit it craps out hard at 7k. Have not nearly as much info about MHD. |
10-01-2020, 05:13 AM | #182 | ||
Rep 4,510
Shame though as PTF are continually evolving BM3 to improve UI, functionality, connectivity and OTS map updates incl long awaited stg 2+ Quote:
It reads to me like PTF may have prioritised it's catalogue of OTS maps for DCT cars. If so this is odd given that, IIRC, highest proportion of MT : AT M cars are sold in the USA, their domestic market. FWIW, whilst I can't comment on lag wrt MT as my M2 is DCT, with BM3 OTS stg2 c/w SVP99, I'm not seeing any additional lagginess nor the power loss/timing pulls from mid to upper rev ranges you refer to above. Car has been tracked too and does well for typical TD 15-20min stints. BP
Current '22 X3M LCI.. |
10-01-2020, 11:21 AM | #183 |
Rep 1,389
I worry re MHD targeting higher boost pressures albeit with less aggressive/advanced timing, to me this yells 'turbo lag' in the truest sense, since it will be asking for the turbo to achieve higher pressure?
Wether noticeable or not is the question and I have a turbo inlet which on stock map as been felt to greatly enhance turbo response. Kinda annoying as I bought the Thor WiFi dongle but if I'd gotten MHD would have more options but at the time thought I'd always be going BM3 so saved fifteen dollars by getting the Thor only adapter! Last edited by 3t3p; 10-01-2020 at 11:29 AM.. |
10-01-2020, 02:00 PM | #184 | |
Rep 1,644
I was told there is an rpm limit that the DME will hold full boost between shifts. Doing a test today to see what that limit is. Thought to be around 4k or 4500 rpm (if rpms drop to below this on upshift, DME will release boost). |
10-01-2020, 02:20 PM | #185 | |
Rep 1,389
What is stage 2+? I like the idea MHD runs off your phone and is very fast with their connector. Also they have a linear throttle map? I am also encouraged to see BM3 may be aware of the lag between shifts and seeing what they can do? |
10-01-2020, 03:19 PM | #186 | |
Rep 488
MHD 2+ had very little lag imo and is much more exciting and more powerful than the stock tune (with same mods). You have a relatively large ic in the do88 - you will actually get less lag with a tune. Mhd Stage 2+ = Bm3 stage 2 (the + with MHD indicates the tune is for cars with upgraded ic) |
10-01-2020, 03:21 PM | #187 | |||
Rep 488
10-01-2020, 03:36 PM | #189 | |
Rep 1,389
Still, I want upper RPM reward, though I do like turbo low down launch feel too! Can't I have it all?! Let us know how you get on and thanks for your approach one of a kind as far as I can see with this info. FWIW I have this shift lag effect (SLE?) on what is as far as I can tell ancient istep from 2016! Last edited by 3t3p; 10-02-2020 at 05:16 PM.. |
10-04-2020, 07:37 PM | #190 | ||
Rep 1,644
By full load I mean full torque request according to throttle map, not necessary max torque for the map itself (that could damage motor at lower rpm and high load). We're not changing the torque requests in throttle mapping. |
widetyres279.00 |
10-21-2020, 08:24 AM | #191 | |
Rep 488
I've just gone out for a drive and the difference is AMAZING!!! :-) You have nailed it! It's wet again, so the drive was a bit limited, but there didn't seem to be any lag anywhere in the rev range following a shift, which is really great. Cheers for your work on this. Great job!!!! I will get a log to you later in the week once we get a dry day. The map I tried a couple of weeks ago bought the map back to OEM levels of lag - but this new version is really amazing. This post-shift lag issue was the one thing that bothered me about the M2 as a package, and it is now sorted! Mega pleased!!!! Cheers for you help in progressing these test maps also PackPride85. :-) |
DarthFader133.50 |
10-21-2020, 10:18 AM | #193 |
Rep 1,644
10-21-2020, 12:17 PM | #194 |
Rep 488
10-21-2020, 05:50 PM | #195 | |
Rep 1,389
I wonder if MHD can or will do something like this. Not yet bought a license but swaying me back to BM3! Is this going to be a general release OTS map for 6MT cars or custom tune only? And safe for drivetrain? |
10-30-2020, 12:23 PM | #196 |
Rep 488
Extract of my Stage 2 98 test map below - you can see that after the clutch comes up that the wastegate now stays closed until boost pressure has reached target. (even with the lower RPM shifts)
The throttle is near as damn it immediate now. Perhaps there is the faintest moment of (genuine) turbo lag in some scenarios, but it's pretty much instantaneous most of the time. Halim has said that he plans to release an update (but I don't know when that will be). |
10-30-2020, 03:17 PM | #197 | |
Rep 1,644
10-30-2020, 06:03 PM | #198 |
Rep 1,389
Well BM3 just beat MHD then despite more PITA factor for making changes.
Don't know how to read logs but sounds like you're enjoying it. Those BM3 raspberry pi project boxes look fun and an excuse to buy some pi for first time! |
