10-19-2020, 02:33 PM | #1937 |
Rep 1,227
What number do you call to get that info? The automated status line?
10-19-2020, 02:48 PM | #1938 |
Rep 92
10-19-2020, 06:51 PM | #1940 | |
Rep 2,787
BTW My BMW online tracker is very accurate
2021 M2C HS/6MT/Exec/Moonroof
10-19-2020, 08:17 PM | #1941 |
Rep 1,369
@Poochie coded the adaptive lighting into my M2C. At first I didn't know if it actually worked! But I'm sure it did as the high-beams are on even with oncoming traffic and I do see some flickering of the various side lamps. At the very least, no one has flashed their lights at me in disgust!
But seriously, I got use to the high beam quickly. Had to turn off adaptive lighting / high-beam to see the disparity of the past. My question now is can this be coded to the G05 X5? I assume it can and with the same steps because it also has adaptive lighting? ///AVM I know you like to say your "mod" days are over (I will believe it when I see it). But you have to do this. Driving in the dark is awesome!
IG: @rise_n_drive
10-19-2020, 08:35 PM | #1942 | |
Luxury at the redline :)
9105
Rep 7,563
They are two versions of operation in what you coded, one, where on low beam, the headlights operate like this: Variable Light Distribution has several different modes of operation (for Low Beam): 1 - City Light: Shallow and Very Wide Beam Pattern active from 0 - 50kph (30MPH) (Both Headlamps are Panned outwards 12 horizontal from center and 0.7 lowered vertically) 2 - Standard Light: Same Basic Beam Pattern as with 8S4 Enabled and Headlamp Switch Set to Auto. Active from 50 - 110kph (30MPH - 68MPH) 3 - Guiding Fog Light - Shallow and Wider Beam Pattern Enabled with the Front Fog Lamps On and Headlamp Switch in Auto and Speed 0 - 110kph (Both headlamps are panned outwards 8 horizontal from center and lowered 0.7 vertically) 4 - Highway Light - Long Throw Pattern illuminating approx. 25% further than Standard Light. Active from 110 to 250kph (68MPH- 155MHP). (Driver's Side Headlamp is panned 3.5 outwards Horizontal from center and lowered 0.25 vertically, while the passenger side headlamp is raised 0.2 vertical) VLD is Variable Light Distribution - It only works on your low beams to move your headlights and position the beams on the road depending on steering angle and vehicle speed. And the other is Auto High Beam Anti-Glare, Anti-Dazzle - European spec high beams that enable your car to keep the high beams on without blinding other cars. It's two different operations; pay attention, you'll see it in motion. As far as the G05 X5, its possible it might have the proper hardware to code this feature but I can't confirm this with certainty. And also, the coding would certainly be different. The parameters I shared only has been confirm to work for the F22/87. Last edited by Poochie; 10-20-2020 at 12:50 AM.. |
10-19-2020, 09:04 PM | #1943 | ||
Rep 5,104
10-19-2020, 09:08 PM | #1944 | |||
Rep 1,369
IG: @rise_n_drive
///AVM2529.50 |
10-19-2020, 09:13 PM | #1945 | |
Rep 5,104
///AVM2529.50 |
10-19-2020, 10:48 PM | #1946 |
Rep 501
So I just went to code my M2C as per the directions given above, but the menus mentioned were different. I'm not sure if that's because I have a 2021 with adaptive LED?
I did it anyway. Posting some photos to make sure I didn't mess anything up. Car fired up and it seems fine, but I need a confirmation from the experts here. For C_HBA_GRHB_ENA, I could only select both of the checkboxes together or the highway one. Is this right? For C_HBA_ENA, I could only select both enable or both disable. For C_HBA_ADAPT_SHUT_ENA, I could only select both disable or enable. When I say "both", I mean both are automatically selected, regardless of which one I select. |
10-19-2020, 11:40 PM | #1950 | |
Rep 501
Strange that these warnings appeared and then disappeared on their own. Ever see that happen? |
10-19-2020, 11:45 PM | #1951 | ||
9105
Rep 7,563
As long as they are not permanent, you have nothing to worry about.. Just clear them a second time and restart the vehicle. Also, when you are coding, put on your seatbelt; this prevents the vehicle from going into "Sleep Mode".. |
10-20-2020, 01:06 AM | #1952 |
9105
Rep 7,563
Now that you're activated the Glare Free High Beam portion of the lighting.
You can now enable Variable Light Distribution, whereas on low beam operation, depending on your speed, the light beam pans out further or retreats, as illustrated in the first photo. BMW explanation of this feature: [COLOR="Blue"]The motorway light distribution increases the range of the driving light under certain conditions. The footwell module (FRM) or front electronics module (FEM) switches the headlights to motorway light distrubution mode under following conditions: Driving speed exceeds 68 miles per hour for longer than 30 seconds Driving speed exceeds 87 miles per hour The headlights are lowered once the driving speed falls below 68 miles per hour. The headlights are lowered (reducing the headlight beam throw) in gradual stages as the speed drops below 68 mph. Miles per hour: 68 miles per hour 62 miles per hour 55 miles per hour 50 miles per hour From 80 kilometres per hour, the headlights are fully reset to country road light distribution. There are different light distributions for city, county road, freeway and full high-beam headlight. An asymmetrical shorter headlight beam through was realised in the light distribution for city. A greater headlight beam throw is not necessary due to the street lighting. In the light distribution for county road the light distribution targets good illumination of the road sides and high range. For this purpose, the light/dark boundary will be raised in the outer area. This illuminates traffic signs and obstacles clearly sooner and better. A limitation of the headlight beam throw in the center serves to prevent blinding oncoming traffic. The light distribution for freeway approximately correspond with the light distribution for county road; however, the limitation in the centre does not apply. Combined light distributions are also available for the last mentioned light distributions. During the transition from light distribution for county road to light distribution for freeway, the characteristic properties of the correspondent light distributions vary. In addition, a speed-dependent raise of the light/dark boundary occurs for the light distribution for freeway to increase the range. Both headlights can be moved vertically and also horizontally by a few degrees. The light cones thereby receive a new targeted alignment.[/COLOR] Front Electronic Module > Expert Mode > 3073 LaMaster1 > [COLOR="DarkRed"]LUT_FLC_FORWARDLIGHTING_Y [/COLOR]> 9C,9C,9C (Both) 3073 LaMaster1 > [COLOR="DarkRed"]C_AFS_ENA[/COLOR] > Enable (Both) Enjoy. |
10-20-2020, 07:05 AM | #1953 |
Rep 1,977
Drives: 2020 M2C HS & Ferrari Roma
I am so glad these functions are standard on my AU spec adaptive
2020 M2 Competition | Hockenheim Silver | 437M Wheels / 763M Wheels | RHD | 2NH Brakes OEM M2 CS Steering Wheel | MP Carbon Steering Wheel Trim | MP Pedals | MP Dash | MP Interior Kit OEM M2 CS Bonnet | M Performance Coilovers | MP Rear Spoiler | MP Rear Diffuser| Perl Carbon Front Lip | Remus Race Exhaust |
Poochie9104.50 |
10-20-2020, 07:53 AM | #1954 |
Rep 1,369
@j23 don't worry, I have MY21 with adaptive and these are the correct functions. Every time you code something, it does throw malfunctions or errors, which will be cleared, per Bimmercode instructions.
Poochie you're giving me homework every night! Where was this the last time?! JK! Also love the screenshots you provide on bimmercode, super helpful and ensures I am actually selecting the correct actions.
IG: @rise_n_drive
10-20-2020, 08:21 AM | #1955 | |
Rep 2,134
I, too, would like to try out the VLD, but am kinda hesitant because the passenger side light’s beam is already quite high IMO. When I pass cars on the 1st lane, I can see my passenger side light shining high enough to brighten exit signs and what not. I feel like the mode 4 you described above (raising it 0.2 degrees) will make it worse. What are your thoughts? Should I manually lower mine, or is it working as designed and I’m just being paranoid? |
10-20-2020, 01:54 PM | #1956 | ||
9105
Rep 7,563
So, if you feel the projection is too high, maybe have a shop or a dealer that specializes in headlight alignment check it out. You can try the VLD then revert back the coding, if you feel it's glaring anyone. I personally had it active for years and I'm very contentious to other drivers, yet, I've never notice it dazzling anyone else. VLD is speed-dependent, so the headlight beam only rises as you traveling at higher speeds. By then, the velocity of the vehicle is moving that quickly, it doesn't have a chance to a nuisance to anyone, In my opinion but keep in mind, normally, the driver side light is always appear lower than the passenger side. https://www.hella.com/techworld/us/T...djustment-835/ This is example of what the manual beam adjustment looks like: |
///AVM2529.50 |
10-20-2020, 02:33 PM | #1958 |
Rep 1,369
Poochie - coded the next set of lighting functions. Interesting enough "LUT_FLC_FORWARDLIGHTING_Y" was already active for both. Just did it for "C_AFS_ENA". We shall see if I notice a difference tonight!
I like how BMW states one feature will only be activated 87 miles per hour. Wont be going that quickly on backroads at night, that's for sure.
IG: @rise_n_drive
