12-03-2021, 09:39 AM | #265 |
Rep 3,843
Yeah, even the huge drums seem to be out of stock. It's too bad. Maybe it'll come back at some point
01-07-2022, 10:45 PM | #266 |
Rep 344
Just got my UOA back from Blackstone today. This is the first time using the Motul 8100 X-cess Gen 2 5w40. This car mostly gets driven to the track, tracked, and then back home. If I wasn't under warranty, I'd probably switch between this oil and 300V for track usage... but I am under warranty (for a while at that).
Details about this particular usage
F87source7305.00 |
01-08-2022, 04:01 AM | #267 |
New BMW owner
326
Rep 844
So it’s new oil to start with? And after the drive there and back plus the actual 3 days of track…. You get that result which is still good. How much oil life is there left?
01-08-2022, 02:17 PM | #269 |
Rep 7,469
Yeah kind of sketchy, PPE is known to be thin from the start but I've never seen PPE lose that much viscosity even with E85 use or heavy track use. Maybe PPE and it's GTL base stock is better despite slightly lower zinc, PPE does have a really robust additive pack.
M1500Z424.50 |
01-08-2022, 09:36 PM | #270 |
New BMW owner
326
Rep 844
so with that result, time to change the oil? Or would that be good for daily driving still but not another set of track time?
01-08-2022, 11:18 PM | #271 |
Rep 1,489
I don't like that KV100. Other than that it is really good report.
Flash point is still strong, so it is not fuel dilution that sheared down oil but mechanical shearing. What stands out is excellent oxidation control of this oil. Obviously it is Group III oil. I am wondering how PPE 5W40 would do or Valvoline European Vehicle 5W40? If you try other oils and they shear down as much, consider heavier, more track specific stuff like Motul Sport 5W40 or Redline 5W40. |
01-09-2022, 11:24 AM | #273 |
New BMW owner
326
Rep 844
Excuse my ignorance, but how does the 300V going to void the BMW warranty but this one does not? Although I did read the note on the 8100 product page which had a sentence on warranty. Didn’t think there are oils that would void the warranty. The 300V is a better oil? But is not BMW LL-01? Is that it?
01-09-2022, 01:14 PM | #274 | |
Rep 1,489
300V is not approved for anything. It doesn't even have API certification. Reason is that 300V is genuine race oil. It works best when oil temperatures are extremely high as additives specific to race oils work best at high temperatures. However, those additives are not best solution for daily driven cars. Many owners rarely reach operating oil temperature, let alone blast their car all day close to redline. You need different additives, different base stocks (less oxidation, more solubility). BMW sells cars to regular people and will warrant only if approved oils are used. They know if someone is racing they will not care for warranty and they will know what oil to use. That is why Motul has Sport line up. For people that go to track a lot but also daily drive same vehicle. Better oxidation control, additives more geared toward daily driving. But, if one is just occasionally go to track, street oils are best solution. They still have a lot if additives that will easily deal with track. Also, Porsche A40 approved oils are track capable. That approval has specific track test (8hrs Nurburgring simulation). |
01-09-2022, 04:41 PM | #275 | ||||
Rep 344
I believe peak temp was like 248—prob extremely briefly as the histogram doesn't even represent anything over 245°F. I have another sample I'm about to send in that has 2 days at COTA (1 of which was in the cold rain so I doubt it put much energy into the oil). Both days saw peak ambient temps over 40°F cooler so it'll be interesting to compare the two samples. Quote:
01-09-2022, 05:13 PM | #276 | |||||
Rep 1,489
PPE will do good. PPE is thin, BUT, since it is GTL HTHS is strong in 3.8 range. Your oil temperature you said is 248 on track? That is NOTHING!!! You could basically run XW30 with strong HTHS (I wouldn't, just saying). You can try Valvoline European Vehicle 5W40. It has also strong additive package and HTHS of 3.7. You can go maybe Ravenol 5W40 if looking more "exotic " oil. As for shearing, the engine is beating up oil. High revolutions, turbos, vanos etc. Some oils do really good in one engine but not so good in another. https://www.blauparts.com/ravenol-mo...-5w-40-5l.html |
01-09-2022, 05:16 PM | #277 |
Rep 1,489
Also, take into consideration that ambient temperature is irrelevant. Altitude is one that matters. Higher altitude less heat exchange. Running at track at 95 degrees below 2,000ft is much easier than running here in CO at HPR at 5,000ft and 60 degrees.
01-10-2022, 03:33 PM | #278 | |
Rep 344
I didn't know if my oil temps were anything exceptional or not, just thought I'd point it out. I didn't think it was all that high though and S55 is known for having excellent cooling—it's the reason I swapped from M2 to M2 Comp. That Ravenol looks interesting. I could run it for a weekend and the Pennzoil another weekend and see. What's the downside of the PPE (if any?) If I recall, you seem to prefer Motul to the PPE. Yeah, you've mentioned that before and I'd forgotten about it. As much as I enjoy snowboarding, I think I'll continue to live at low altitude . |
01-10-2022, 06:07 PM | #280 | |
Rep 7,469
https://f87.bimmerpost.com/forums/sh...2#post30368242 Last edited by F87source; 01-10-2022 at 06:13 PM.. |
01-10-2022, 07:21 PM | #281 | ||
Rep 1,489
For DD the leftover KV100 is good. But I am bit skeptical bcs. oil pressure going into thin 30 territory after so many miles. Try PPE. PPE is mostly GTL and Group III. It is thin, but HTHS is 3.8 territory and some pds had it at 3.88. I would definitely try it. I used it once on track but never did UOA. Shell put all its chips into GTL although they are known to drop in some PAO. That being said, it crossed my mind that if you can get some old stock of BMW TPT 0W40 M oil, get it. That stuff is ridiculously robust. GTL and PAO combination specifically made for BMW by SOPUS. I think BMW Canada still has it in stock. |
M1500Z424.50 |
01-10-2022, 08:17 PM | #282 | |
Rep 7,469
01-10-2022, 08:41 PM | #283 | ||
Rep 1,489
F87source7305.00 |
01-10-2022, 09:02 PM | #284 |
Rep 7,469
Does shell not have a similar 0W40 formulation for themselves maybe under their helix banner? All I know is they have their PPE 0W40 but that isn't as good as their 5W40.
01-10-2022, 09:09 PM | #285 |
Rep 7,469
BTW I think shell improved PPE 5w40 alot, they probably either used more GTL or added some PAO because pour point iirc dropped from the low mins 20's to minus 30's to -40C
https://www.shell-livedocs.com/data/...2b4b5dbce0.pdf Here's an old TDS showing the 3.88 HTHS btw: https://www.jlwranglerforums.com/for...40-pdf.363257/
edycol1513.50 |
01-10-2022, 09:12 PM | #286 |
Rep 1,489
TPT 0W40 M is specifically made for BMW. Lot's of PAO, -52c pour point, HTHS around 3.9 and Noack as far as I remember in 7% value range. It us really good stuff.
