03-08-2022, 01:32 PM | #1 |
Rep 1,389
Does suspension 'warm up'
Don't know if I'm tripping balls but I swear that when the whole car is cold the suspension is not as supple as when I've been on it for a bit and the car is warm? I'd go so far as to say it's a bit longer than the engine takes to warm up.
I thought I noticed this without trying to notice it if that makes sense?! |
03-08-2022, 01:39 PM | #2 |
844
Rep 1,962
Probably the tyres. Select the tyre pressure screen and you'll see it also shows temperature.
Go for a drive and marvel at how the temperature climbs 20C just cruising on the motorway... Edit: UK temperatures in February. So it starts at 3C, and ends up in the mid 20s. |
03-08-2022, 01:53 PM | #3 |
Rep 291
Drives: 2023 BMW M2
This is absolutely true! Suspension fluid will heat and cool and become more or less viscous. This is why race cars and other high performance applications have external redivides housing for suspension fluid to help keep it cool and prevent air bubbles from forming ruining the performance.
03-19-2022, 06:21 PM | #6 |
Rep 196
Absolutely. The passing of the fluid through the dampers creates an immense amount of friction that heats it up and affects viscosity, which in turn affects the damping effect. That is why suspension fluid is a science of it's own.
Add in another set of variables to a gas charged system like those found in some mountain bike or motorcycle shocks, and you have the temperature/pressure changes of the gas affecting suspension as well. Motorcycles have hugely noticeable changes in suspension during their warmup laps.
14' Alpine White M235i 6MT, BM3 Stg2+, VRSF DP-CP-FMIC, Dinan Muffler, GFB DV+, 3.5 bar MAP, Dorch Stg1 HPFP, NGK 97506, BM3 Flexfuel Kit, CDV delete, KW V3, EDC delete, Powerflex Camber LCA bushings, VMR 801 18x8.5/9.5 et45, Conti Extremecontact 235/265
Next step: M2 Competition or Manual Supra MKV build Summer 2022 |
03-19-2022, 06:23 PM | #7 |
Rep 196
Also suspension fluids break down over time which makes it a mystery to me how these cars have non serviceable dampers, and how in the coilover community, nobody stresses getting rebuilds from time to time
03-29-2022, 06:15 PM | #8 | |
3847
Rep 54,376
Drives: F80 M3
03-29-2022, 09:45 PM | #9 |
Rep 7,299
Because OEM shocks/struts are considered wear items. They are cheap enough and the fluid may not be standardized.
03-29-2022, 09:49 PM | #10 |
3847
Rep 54,376
Drives: F80 M3
03-31-2022, 09:01 AM | #11 |
Rep 4,254
I can confirm for sure that whatever hydraulic fluid is in the dampers is susceptible to temperature. My car is much stiffer in extreme cold (-25 to -30 deg C) versus warm weather. I think it's cheap fluid. I haven't experienced this on any other BMW prior to this, at least to the extent that it's as noticeable as it is in the M2C. Could be the fact it's paired with stiff springs and cost cutting I guess. Honestly this suspension is terrible. I really hate it but don't want to lower the car.
///M Power
04-11-2022, 05:10 PM | #12 | |
3847
Rep 54,376
Drives: F80 M3
04-29-2022, 11:36 PM | #13 |
Rep 1,389
Stock suspension not that bad after M3 brace retrofit and ps4s above 45mph or do really ok.
I appreciate the Bilsteins more and more though, they do so much when you're on it and give you contact patch all the time. Here's hoping they last as are used as OEM for other cars. Glad I'm not going crazy! |
05-07-2022, 06:49 AM | #14 |
Rep 139
While fluid viscosity in the dampers is susceptible to temperature changes during use, I believe the difference may be more to do with the tyres and rubber compound.
Different tyre compounds behave differently at certain temperatures (think of cold race tyres), and it's often immediately noticeable if you're keyed in, on cold mornings. This isn't just the compound at the contact patch, but the construction and sidewall stiffness. The tyres are an integral part of the suspension system and differences in tyre sidewall stiffness will translate directly to how the shocks/springs absorb bumps and dips. |
