M2 Technical Topics > Wheels / Tires -- Sponsored by The Tire Rack > Increasing tire size from 245/265 to 255/275: any cons ?
      02-02-2020, 11:07 AM   #133
3t3p
New Zealand
455
Also considering doing this in my OG M2 when my MPSS are through.
Will I still be able to break traction and will turn in by much heavier/slower than 245 at the front?
      02-03-2020, 02:27 AM   #134
Bee Pee
Bee Pee's Avatar
1779
Drives: AW M2 DCT
If you go with starred MPSS 255/275 from M3/M4 then I doubt the turn in will be slower, weightier yes but no bad thing in my book for EPS. If you know someone with an F8x M3/4 with stock wheels/tyres, perhaps ask if you can drive it to check helm response and feel before you commit to 255/275 combo.
Even if you go with non-starred MPSS 255/275, I doubt it will be detrimental, other tyre brands/makes though may be a different story....
Current '22 X3M LCI..
      02-03-2020, 05:26 AM   #135
waldrops
waldrops's Avatar
171
Drives: BMW M2 Competition
Swapped to 265/30/10 - 295/30/19
Michelin PS4S
Between the tire swap and size increase, the car is completely different. I can take street turns at 40-50 without the back even sliding(not that it's a good idea).
From what I read when I swapped I think the setup I have is the closest to the same rolling diameter as OEM as well.
      02-03-2020, 08:55 AM   #136
flybigjet
Remove Before Flight
flybigjet's Avatar
Drives: M2C & Boeing's light twin
Michelin PS4S
Pretty much everything I've read says that 265's rub the front unless you're using camber plates?
Truth? Not truth?
Not interested in the "heat gun" method.
TIA--
R.
      02-03-2020, 08:58 AM   #137
waldrops
waldrops's Avatar
171
Michelin PS4S
Truth? Not truth?
TIA--
R.
265/35/19 in the front rub
265/30/19 has zero rub
This is my car with the mentioned setup - no rub - and it's on Macht Schnell lowering springs
flybigjet6822.00
AlpsRider2865.00
      02-03-2020, 10:57 AM   #138
RARZED4
Drives: MerlinTiCx
Rim widths?
      02-03-2020, 01:56 PM   #139
3t3p
New Zealand
455
Thanks, I checked my rears today and they felt lower than I thought.
So it's win win to try 255/35 r19 front and 275/35 r19 rear?
I think strangely the wider rear tyre is cheaper than the 265 variant.
I was just gonna buy PS4S. Sorry slight thread hijack.
      02-03-2020, 02:58 PM   #140
Bee Pee
Bee Pee's Avatar
1779
Drives: AW M2 DCT
255/275 35/19 MPS4S - good plan
      02-03-2020, 03:51 PM   #141
3t3p
New Zealand
455
Nice, wonder if that side wall difference can be felt? Must be literally 1mm thicker haha
      02-03-2020, 03:59 PM   #142
AlpsRider
AlpsRider's Avatar
2865
If you could give your wheel widths and offsets that would be great.
      02-04-2020, 01:10 AM   #143
whoop_ass
whoop_ass's Avatar
355
Drives: non
EC-7 wheels so i am sure it's a 9.5j and 10.5j rear
      02-04-2020, 02:01 AM   #144
AlpsRider
AlpsRider's Avatar
2865
I figured that they were EC-7s. They offer several offsets though.
      02-04-2020, 02:57 AM   #145
hlm2c
Drives: M2C
Michelin PS4S
Any difference in comfort or road noise swapping from PSS in 35 sidewall vs PS4S in 30 sidewall?
      02-04-2020, 04:38 AM   #146
waldrops
waldrops's Avatar
171
I have Apex EC-7's
Apex also made a fantastic fitment guide for the M2's
https://support.apexraceparts.com/hc...-Fitment-Guide
M2_MEDUSA664.00
      02-04-2020, 04:53 AM   #147
whoop_ass
whoop_ass's Avatar
355
Drives: non
just looking at the car i am sure it 44 rear and 28 front.
I could be wrong!!
      02-04-2020, 05:17 AM   #148
CSBM5
CSBM5's Avatar
2721
Drives: 2019 M2 Comp, 2011 M3, etc
The closest to stock diameter would be to use 275/30-19 up front paired with the 295/30-19 rears. This keeps the 20mm stagger in widths and also is closet to the stock diameter stagger ratio. I inspected an M2C with PS4S in those sizes mounted on stock wheels at O'fest, and I saw no signs of rubbing issues although I didn't come across the owner to discuss.
Technically to match the stock diameters, front and rear, 285/30-19 and 305/30-19 does exactly that but of course with those widths and the wider wheels needed, it would take some work to make them fit I assume.
Current Stable:
2024 G20 M340i Melbourne Red/Cognac
2019 F87 M2 Competition 6MT, LBB, slicktop, exec pkg
2007 E91 328i Silver, slushbox, Eibach fr/E93 M3 rear sway bars, ARC-8
      02-04-2020, 10:45 AM   #149
3t3p
New Zealand
455
Is there a fetish for really wide tyres or something? Like people want to be in club veyron? Or am I missing something ?!
JMM125.50
      02-04-2020, 10:47 AM   #150
whoop_ass
whoop_ass's Avatar
355
Drives: non
I agree 100%
I think this would be ideal for looks and performance as well.
but i reckon you going to have a tough time fitting a 275/30 on the front lowered. again also dependent on what tyre you go with as they not all the same in tread width.
any body running a 275 on the front on 9.5J
      02-05-2020, 08:41 AM   #151
flybigjet
flybigjet's Avatar
Another question: I've pretty much decided to swap the stock 245/265 PSS's on my incoming M2C with 255/275 PS4S's (i.e. a +1 size increase.)
My thought was to order them through Tire Rack (best price I've found), pick them up at the distribution center (saves $40), and deliver to my dealer to have them mounted just before I accept delivery of the car.
Buuuuutttt-- Now I'm thinking (probably an overabundance of caution) that the dealer could "redline" the car, or "flag" it due to "non-approved" parts.
I don't want to have to get approved from Corporate any time I go in for service or warranty work.
So-- Problem? Not a problem?
Am I better going elsewhere? My worry is that BMW would know how to do the swap without dinging the wheels-- whereas I wouldn't trust some of the Tire Rack installers in the area with the wheels from my 15 year old Honda, much less a brand new, expensive BMW.
Thoughts?
      02-05-2020, 11:46 AM   #152
AlpsRider
AlpsRider's Avatar
2865
Thoughts?
I seriously doubt that the dealer would care about the bigger tires, they probably wouldn't even notice. I took my M235i in for warranty service multiple times with much bigger tires than stock without issue.
Tire purchase:
I usually find the best deal on tires then go to my local favorite tire shop Discount Tire for a price match. Michelin often has a $70. rebate on a set of 4 tires which is an extra bonus. I just checked and at the moment Michelin doesn't show an available rebate but Costco specifically does offer $110. rebate on Michelins. You'd need to go into the Costco shop to order them, they're not a stock item on their website either.
I don't think BMW techs are especially careful or gifted. I think you take the same risk on wheel scratches wherever you go. My policy is to take pictures of the wheels before the tire change and speak to the tech personally explaining that I really care about scratches. That is about the best you can do. Good luck.
flybigjet6822.00
      02-05-2020, 12:08 PM   #153
flybigjet
flybigjet's Avatar
Tire purchase:
Thanks.
I actually checked Disount first-- they were more expensive that Tire Rack. Not sure how their "price matching" works with tax and the $40 credit the Tire Rack gives for pick-up rather than delivery. I'll have to go back and ask.
Tire Rack was $1134 -$40 for pickup, totaling $1,094. Discount was $1,367 w/o the tire warranty and $1,549 with. Tire Rack has a tire warranty included and I'll have to factor in the mounting/balancing of the tires, but even at $50/tire Tire Rack is still a fair bit cheaper.
The Costco here won't deal with anything other than OEM sizes, so they're right out. I've got +1 on my Element and have been turned away by them as soon as they look in the computer for "factory" sizing.
      02-05-2020, 12:25 PM   #154
AlpsRider
AlpsRider's Avatar
2865
Thanks.
Discount usually will deal with out the door price. Sometimes I'm surprised at how low they will go :-) Also, the Discount shops are not all created equal. I have one in my area that is stingy about price matching while another one will drop their drawers .
The Michelin rebate comes and goes. I usually wait to buy when it is offered. It will probably come back in a month or two. Evans tire often has 2 for 1 sales which is good for price match also.
You: flybigjet Me: flylittleCessna
flybigjet6822.00
