07-16-2023, 10:30 PM | #1 |
Rep 130
Drives: 2018 BMW M2
PSA Differential Plug Torque is 45 NM!!!
Hello everyone just thought I share my recent findings with my differential fluid change. Like the title, the differential drain and fill plugs are 45 NM as per ISTA. DO NOT TORQUE IT TO 60 NM like a lot of videos would instruct, I seen videos even saying 60 ftlbs.
My differential fluid has been changed twice since buying the car brand new in 2018. Once at the dealership for the break in service and once in 2021 when I did it myself. Back in 2021 I didn't have access to ISTA so I watched multiple videos and they mentioned 60 NM so I trusted the videos and torqued it to 60 NM. I just did my differential fluid tonight (The 3rd time) and when I was trying to get the fill plug in, it was impossible to thread on. I pulled the plug out and found that part of the aluminum thread on the differential side was jammed in the plug. Upon further inspection it is 100% the differential side thread on the outer side, the fill plug that came out is pristine. I was lucky that I didn't try to monkey force the plug in and it was on the outside, I probably will replace my differential cover in time if the gasket leaks. Picture below of the damaged thread piece from my fill port on my differential. Thought I share and maybe save a couple of other folks from messing up their differential threads. |
07-17-2023, 12:30 AM | #2 | |
Rep 7,473
So I always follow ISTA.
https://f87.bimmerpost.com/forums/sh...2#post30368242 Last edited by F87source; 07-17-2023 at 05:27 AM.. Reason: I realized I sounded way to harsh to YouTube diyers. |
07-17-2023, 04:56 AM | #3 |
Rep 188
Drives: 2017 BMW M3 Competition (LCII)
I’m inclined to reply as I feel personally attacked lol, in all seriousness, my video also states 60Nm; I didn’t have access to ISTA at the time and was ‘new to the game’. I apologize and will pin a comment stating that it should be torqued to 45Nm instead of 60Nm.
Tes110.50 |
07-17-2023, 05:23 AM | #4 | |
Rep 7,473
Otherwise you and faarkle put out good content. There are others that have a decent viewership that dont.
07-17-2023, 08:57 AM | #5 | |
Rep 130
Drives: 2018 BMW M2
07-17-2023, 11:59 AM | #6 |
Rep 165
Dammit I literally just did a diff flush last week with the wrong trq specs. Ty for this info
07-17-2023, 03:13 PM | #7 |
Rep 130
Drives: 2018 BMW M2
If you have a quick jack or something and can get to it easily. I would loosen it and retighten to 45 NM. Won't lose any diff fluid and relatively easy to do and I'm sure O-ring will be fine without replacing either. But then again as far as I can see, my car experienced the first documented damage, I'm sure you are fine at 60 NM considering how many people been torquing to 60 NM.
07-17-2023, 03:22 PM | #8 | |
Rep 7,473
07-17-2023, 03:57 PM | #9 | |
Rep 165
07-17-2023, 04:48 PM | #10 |
Rep 7,473
The threads are most likely stretched out and permanently deformed. But they might be able to be used at the proper torque specs for awhile longer. So I might hold off until I see the threads start to deteriorate, and once they do then switch the pan.
F87Tomei268.50 |
07-17-2023, 07:32 PM | #11 | ||
Rep 130
Drives: 2018 BMW M2
On the bright side, next time I do my diff fluid I'll make a whole DIY on how to change out the Diff cover LOL, I don't think it exists yet. |
07-18-2023, 04:35 AM | #12 | |
Rep 7,473
There literally could not be a worse example of absolute garbage youtube advice.
08-27-2023, 09:32 AM | #13 |
Rep 504
Drives: 2018 M2 6MT
I note that FCP Euro states the wrong torque spec (60 Nm instead of 45 Nm) on their listing for the diff drain/fill plug:
https://www.fcpeuro.com/products/bmw...ial-drain-plug Can the OP (or maybe F87source ) provide a snapshot of the ISTA torque spec so I can forward it to FCP Euro so they can correct their listing? I'm guessing if I just shoot from the hip and tell 'em they have the wrong spec, that might not go so well? |
08-27-2023, 02:34 PM | #14 | |
Rep 7,473
It's 45nm because they specify 5az.
09-04-2023, 09:49 AM | #16 |
Rep 392
Drives: 2019 BSM M2C
Thanks guys for sharing the proper torque for the fill and drain plugs. I just performed the 50k mile diff fluid change this morning and was glad I found this thread. YT has been invaluable to help me DIY but I always cross reference this forum.
09-05-2023, 05:53 AM | #17 |
Rep 3,359
Just checked it, and it still shows the incorrect value.
Current Stable:
09-06-2023, 11:56 AM | #18 | |
Rep 504
Drives: 2018 M2 6MT
Yeah, their first response was to ask if I was getting my torque units mixed up:
09-07-2023, 10:03 PM | #20 | |
Rep 97
I am at 34k miles and plan to do both soon and send the oil for analysis to Blackstone Labs to get objective data on the current state of the oil, I can share the data here if there is interest. |
09-07-2023, 10:17 PM | #21 | |
Rep 7,473
09-07-2023, 11:19 PM | #22 |
Rep 97
