02-14-2022, 02:20 PM | #1 |
Rep 39
Uk tyre choice
Anyone got any recommendations for what tyres to run in the uk? Looking for a good all rounder.
Currently have pilot sports but they spin like anything when the ground is even slightly damp. Nearly lost the back end a few times going round tight corners/roundabouts and wasn't even being that adventurous with the throttle. Love the m2c in the summer but in the winter it's a pita to drive! |
02-15-2022, 11:55 AM | #3 |
Rep 303
I am nervous about PS4S, I fitted them to an E90 M5 and disliked them, they lost all the feel and turn in precision. I think I'll move to 255/275 Cup2 or stick to 255/275 MPSS
02-15-2022, 01:40 PM | #4 | |
Rep 39
I think I will try the ps4s |
02-16-2022, 03:25 AM | #5 |
M2 comp
62
Rep 74
I found the Cup2 tyres gave excellent grip in the dry uk summer months, but they were not so great on damp / wet roads.
Plus as soon as the temperature dropped below 10 degrees C they were like driving on solid rubber tyres. So I bought a set of conti winter tyres for the wet winter months and these give amazing grip. |
02-16-2022, 05:48 AM | #6 |
Rep 303
I'd be interested how you find then PS4S for feel. I think Cup2's have improved as well, my GT3 has the N1 Cup2's and they are substantially better than the N0's they replaced in the wet and cold. But agree they are not excellent here
02-18-2022, 04:00 AM | #7 | |
Rep 15
If anyone has experience with this would appreciate it! |
02-20-2022, 02:42 AM | #8 | |
Rep 488
If you value steering feel at all, I would skip the PS4S - particularly in 255 front fitment, they are devoid of steering feel. I was so disappointed in them that I swapped to Continental SC6 after only a couple of months. I didn't like Continentals before these tyres, but the SC6 is a great sports tyre. Fast road and track they have been brilliant, and include plenty of steering feel (once warmed up). They have a lot more grip than MPSS (in both dry and wet), but retain most of the steering feel (although the MPSS and Cup2 are kings of steering feel). If I were buying a new set of tyres now, I would consider the Goodyear F1 SuperSports - from the reviews they look good, however, they are a fair bit noisier than the SC6. As a result, I would probably stick with the SC6 myself (I have topmounts that exaggerate road noise, so this is a big consideration for me). |
FlashmanM23.00 |
02-23-2022, 05:49 AM | #9 |
Rep 303
Yes I think I will skip the PS4S I put them on an F10M5 and hated the feel of the car afterwards. The Goodyear F1 supersport Ive heard very good things about, good suggestion
02-23-2022, 07:42 AM | #10 |
The Seeker
13863
Rep 3,325
The Cup2 is NOT a good road tire, regardless of what reviews you hear. It's a TRACK tire, and as such will not handle cold and wet good at all, and will wear ULTRA fast. If you have money burning a hole in your pocket it still is the WRONG tire for the street. It is a drive-to and from the track tire, nothing more.
The PS4S was the KING and had been for some time. It's unfortunate that it doesn't have the dynamic feel of the PSS, but it's a VASTLY better tire overall. The Goodyear F1SS is not as good on the road, but forgiving on the track, which is the only reason to choose it over the PS4S. The new KING is the Conti Sport Contact 7, and that's your tire if you're not a track junkie. |
03-15-2022, 03:54 PM | #12 |
Lateral grip estimator
957
Rep 1,390
I have a fair amount of experience with M2 tyres in the UK.
The Pilot Supersports actually work really well in most situations, though they do take a while to get some heat into them when it's cold outside and they are only good in the wet when they're warm. Fine in summer but not great in wet winter conditions unless you can get some heat into them. The PS4S are better in wet and cold conditions and comparable in warmer weather. They also last a bit longer and are a bit quieter. The GY Eagle Supersports are similar to the Pilot Supersports in colder conditions, they need some heat to work well. However the sidewalls are a good bit stiffer than the PSS and the PS4S so they produce a much nicer turn in as a result. Of course this has upsides and downsides - upside being they take much more abuse before starting to overheat, they'd be tricky to overheat in road use and would take much longer to overheat on track. However that does make them a bit less comfortable around town and also makes them a bit noisier on most surfaces. You pays your money, you makes your choice…
Carrera2RS203.00 KernowBMW4.50 |
