09-03-2022, 04:49 PM | #67 |
Rep 254
Drives: 2022 M3, 2023 X3
When installing the wireless charger #84105A3E813 I noticed it has a connector for an antenna. There was no wire in my car to connect to it. Also I saw in Bimmercode it defaults to setting that antenna compensation (cant remember the wording) to Activ. So far its working fine though so I assume no need to connect that or disable the option.
MINE: 2022 M3Cx, Sky Grey, Driv/Exec/Park/Laser
1/26 Ordered, 4/26 Prod, 5/4 Assembly, 5/9 Port, 7/11 Transit, 8/3 Port, 8/18 Dealer, 8/25 Delivered WIFE: 2023 x3 m40i |
09-13-2022, 09:02 PM | #68 |
Rep 605
Hey guys attempting this tonight and having trouble changing out the original nfc tray and don't want to force it. How do I remove it? Swift answers super appreciated as I wanna put it all back together asap!
09-13-2022, 09:24 PM | #69 |
You got my money?
3226
Rep 4,707
Drives: Ice Cream Truck
Pull cup holders rubber bottoms out. Look for the tabs at the backside (closest to shifter) and pull them out.
Remove the screws holding the cup holder. The cig power port is a BITCH to remove. At least mine was. I keep that wire connected and moved the cup holder to the side. There is some wire slack to do so. Now look at the tray. In the OPs pics where he has the tray lifted. You will see two white dots on his tabs. Those are the tabs you touch. They are facing down. Pry them towards you while pushing the tray from UNDER it with your fingers. The underside of the tray is hollow in the middle of the tray. Pry the tabs and push up on the tray. Once you get one side the other will follow.
2022 G80 M3 Competition X / 2020 Range Rover Sport P525 / 2023 Ford Raptor
09-13-2022, 09:49 PM | #70 |
Rep 605
"Now look at the tray. In the OPs pics where he has the tray lifted. You will see two white dots on his tabs. Those are the tabs you touch. They are facing down. Pry them towards you while pushing the tray from UNDER it with your fingers. The underside of the tray is hollow in the middle of the tray.
Pry the tabs and push up on the tray. Once you get one side the other will follow." This was the key I needed - much thanks to BIGW0RM for getting back to me so quick. Coded the device in wireless tray reminder as well. Alls working! |
'Cane8710.00 |
09-13-2022, 09:51 PM | #71 | |
You got my money?
3226
Rep 4,707
09-13-2022, 09:51 PM | #72 | ||
Rep 605
09-13-2022, 09:53 PM | #73 |
You got my money?
3226
Rep 4,707
Huh. Interesting. I had to active mine. At least I think I did...
09-13-2022, 09:58 PM | #74 |
Rep 605
Maybe I didn't - is it anymore than a small chime and a pop up on the bottom of the dash saying mobile device in wireless charging tray? Not being sarcastic just kinda expected more.
09-17-2022, 10:17 AM | #75 | |
You got my money?
3226
Rep 4,707
What more of a warning do you want? Vibration in the seat or something?
09-17-2022, 10:37 AM | #76 | ||
Rep 605
BIGW0RM3226.00 |
09-17-2022, 10:48 AM | #77 | ||
Rep 5,442
Drives: 2022 Aventurin/SS G82 xDrive
09-19-2022, 09:44 PM | #79 |
Rep 605
BMWRacer5232522.00 bankerkys12.00 |
09-19-2022, 09:45 PM | #80 |
Leave the gun. Take the Canoli.
9201
Rep 7,781
Well, the one that comes built into the car certainly doesn't so I assume this would be more of the same. The whole thing needs to be redesigned.
Current: 2023 Santorini Blue ///M8 ||| 2023 X3 M40 --> 2025 X5 M60 (ordered)
Retired: 2021 Enzian Blue ///M4 ||| 2018 ///M4 ||| 2017 ///M4 ||| 2014 435i ||| 2009 335i Coupe ||| 2007 335i Coupe |
BMWRacer5232522.00 |
10-12-2022, 10:27 AM | #82 |
Rep 5,393
Drives: 08 JB E92 M3
I ordered my MY23 with wireless charging option but doesn't have this. What?? Mine is just a deep pocket that won't even fit my phone.
Can someone help confirm if they should come with the vehicle if it's an added option? |
10-28-2022, 09:08 PM | #84 |
Rep 5,393
Because I have a 6MT Base, my wireless charging is in the armrest console. Does anyone know if I can add this?
10-29-2022, 11:25 AM | #85 |
Rep 122
I have a 2023 ID8 and I didn’t buy this option but I’m my tray it has the wireless charging icon. Does that mean I still need to buy the new part or is it coded off?
10-29-2022, 11:39 AM | #86 |
Rep 5,442
10-30-2022, 09:40 AM | #87 | |
Rep 202
