05-07-2024, 06:47 PM | #1 |
Rep 6
Magnesium Levels High? OG N55
Hello All,
Is the magnesium level concerning? What parts contain magnesium? Any help is appreciated. Recent helicoil job to repair the oil pan from PO. I thought the pan was aluminum, is it maybe a magnesium composite? found what appears to be thread in the filter at one point, also pictured. 29K miles. Just added FMIC, CP, and AA catted downpipe but haven’t really driven it while I waited for this report to come back. No codes, no lights. |
05-08-2024, 01:48 AM | #2 |
22186
Rep 8,724
Those labs test are cool but somewhat ridiculous at the same time
I just use the best oil and warm my car up properly and change the oil once a year at a minimum and I focus on more important things like driving
Philly_sweden650.00 |
05-08-2024, 03:58 AM | #3 | |
Rep 7,539
If you found those threads in the filter they are very likely from the oil pan threads, since the pick up is right there. So those are likely from the helicoil job - no biggie, the oil filter did what it needed to do to protect the engine. Magnesium can come from alot of places, oil additives can contain magnesium and some of them in very high concentrations in an effort to reduce reliance on calcium (preventing LSPI). For instance virgin pennzoil platnium Euro 5w40 has ~1139 ppm of magnesium as an additive by itself, and since you don't list what oil you have in the black stone test this could be a false alert because black stone isn't expecting this much magnesium. So depending on the oil you are running 1011 ppm of magnesium might mean nothing, or it can be a bit of a concern. Edit - I just check VOA for the 2 most common lm 5w40 oils (molygen and liechthauf (idk if that is spelt correctly)) and they both have little to no magnesium, so this might be an actual issue. I don't know off the top of my head what the sources of mg are in this engine. My best advice for you is to relax and take it easy, change the oil if you haven't already done so, drive the car for awhile (the same amount as the previous test) and do another UOA to see what the results are.
https://f87.bimmerpost.com/forums/sh...2#post30368242 Last edited by F87source; 05-08-2024 at 04:05 AM.. |
05-08-2024, 09:25 PM | #4 |
Rep 6
I plan on doing another UOA and oil change once I hit the 1,000 mile point to compare. I’m just afraid of the worst case scenario here. It appears the metal “thread” pieces are not magnetic. I have cut up a few filters and find a small spec or two at most but I’ve gotten a handful of those same size, same curvature “thread” pieces overall since the helicoil job.
Edit: I run the leictlauf or whatever spelling LM 5W-40. Greatly appreciate the comments and will reply with any findings. Last edited by CB2001; 05-08-2024 at 09:28 PM.. Reason: Further comment |
05-08-2024, 09:34 PM | #5 | |
Rep 7,539
