10-30-2018, 11:59 AM | #24 |
Rep 5,369
A 7.9 1/4 mile? Yep, totally wrong car and goes totally against the point of the M2. Sounds like all you wanted was the body of the M2 because everything else about the car needs to be thrown out the window. You'll need to dump that DCT too as it won't last behind all the bolt-ons you currently have ordered. To go sub 10s, you need a built domestic drag racing type tranny like a 2 to 3 speed with a very loose stall.
NYC Bimmer259.50 |
10-30-2018, 01:50 PM | #25 | |
Rep 328
If I am incorrect about M2 DCT, someone please chime in. |
10-30-2018, 03:14 PM | #26 | |
Rep 5,369
Yes, the DCT used in the M2 is the same unit used in the M3/M4, bit it's pretty well known the unit can't handle big power numbers and the 6MT with a stronger clutch and a single mass flywheel is the answer. HOWEVER, to go sub 10s takes a huge amount of power which is also extremely taxing on drivetrain parts. To go sub 9s is a different world altogether. That's why I brought up the domestic transmission thing. Sub 10 second Supras typically run highly built TH400 3 speed GM transmissions. This M2 will require that because to go sub 9s requires an automatic. To go 7.9s (around 177-180mph in the 1/4) in a 3,200lb gutted M2 will take 1,300-1,400hp, a 1.3 60 foot, and a total rework on the chassis including tubbing the rear.
mr_lab_rat564.00 pz6193278.50 |
10-31-2018, 12:44 AM | #27 | |
Rep 328
10-31-2018, 10:06 AM | #28 |
Occasionally frequent poster
3000
Rep 2,744
Wow, this will be quite the project. Good luck.
Me personally, I'm amazed that the car out of the box does it in the 12s. I think that's pretty good. The first time I drag raced was in my Buick Grand National. I don't remember the ETs, but it was a 1/8 mile track. I beat everyone but a Typhoon. I did drag race my modified Corvette a couple of runs, but I couldn't keep it hooked-up, and I was running brand new Michelin street tires and didn't feel like spending $100 for a burnout. After I nearly took out the timing lights from losing traction, I gave up. I much prefer road course, but it's apples and oranges. Not everyone likes the same fruit.
Current inventory:
DiyTransport13.00 |
11-02-2018, 08:58 AM | #30 | |
Rep 72
Also people telling you this is the wrong platform to attempt this record in doesn't automatically qualify them as "haters". They're just informing you this is an extremely tall order and well...we're not sure how serious or realistic you are about this whole thing. The parts you bought for the car that you screen shotted and showed us all in your post won't get you past 500whp and you'll need a hell of a lot more than that to even hit 10's let alone a 7, so that's probably why no one here is taking you seriously. Post some shots of the engine out of the car and then people will start to lower their eyebrows. Your ideas and promises alone aren't enough to impress or convince the internet. Not hating, just telling it like it is. Last edited by NYC Bimmer; 11-02-2018 at 04:16 PM.. |
AndrewC198910915.00 nothingman522.00 |
11-02-2018, 01:19 PM | #33 |
Transport King
13
Rep 18
I will admit that we said 7.90's not fully knowing how much hp and others stuff that would need as we really wanted to make it drivable on the street also so we apologize for not doing as much homework as we should of when making .org post of that time however we still think we can achieve high 9's and still make it a solid street ride also. And we know we will need many upgrades to even get to that
11-02-2018, 01:44 PM | #34 | |
756
Rep 2,149
Yellowflash21369.50 |
11-02-2018, 05:53 PM | #35 | |
Rep 4,550
Drives: 2015 328d xDrive
nothingman522.00 Yellowflash21369.50 |
11-03-2018, 09:09 PM | #37 |
Rep 1,369
I ran 7.9x my first time out with the B58; JB4 on Map 1 and BMS intake.
(In the 1/8.....lol)
2017 M240i/ ZF8 Pure Drivetrain Solutions Stage 1 & torque converter/xHP/ DAW Ultra Flow/ DS2/ Nostrum injectors/ E40 Doug Newton tuned/ ER DP/ Remus axle back/ BMS intake/ FTP CP/ M Perf LSD
11-03-2018, 10:25 PM | #39 |
Rep 979
Drives: 2024 M4 Comp X-Drive
7.90s is an entirely different universe. Like others have said TH400 or built powerglide, 1200 plus hp and aero work. You’ll also need significant (NHRA or IHRA certified) cage and chassis work before you’d even be allowed to run the car.
I’m guessing minimum of 100K USD budget on top of the car and that’s probably conservative. Mid-High 10s is a more realistic goal for a true street car (though still not cheap) Good luck with the project it’ll be a lot of fun. Cheers, Chris |
11-04-2018, 12:27 AM | #40 |
Rep 2,700
I'm at Haltech World Finals Import vs Domestic in Maryland right now and let me tell you if a BMW ever runs 7.90 its going to be the stripped out, wheelie bar, billet block, 76+mm turbo king of car....
So basically anyone ever sane is going to buy a 6-7k 335i or 135i for that way before scrapping a 40-60k M2...
11-04-2018, 12:36 AM | #41 | |
Rep 289
///M2 - 2018 LBB DCT
PLF693766.00 |
11-04-2018, 12:37 AM | #42 | ||
Rep 2,700
11-04-2018, 12:42 AM | #43 | |||
Rep 289
11-04-2018, 01:06 AM | #44 | |
16161
Rep 8,387
Best of luck regardless.
