07-12-2018, 08:38 AM | #2 | |
Rep 1,339
Post#8 |
07-12-2018, 08:56 AM | #3 |
The deuce gets loose
290
Rep 499
They are a gimmick
eatingpizzainthef87rules253.00 bobert858.50 |
07-12-2018, 03:41 PM | #4 |
Rep 3,402
07-13-2018, 10:36 AM | #5 |
Rep 3,949
I don't even bother with them. I am to busy looking where I am going.
champignon1565.50 |
07-13-2018, 01:53 PM | #6 |
Rep 1,718
You are better off with one of these. http://www.awron.com/index.php/f87-m2-f87dga
Numbers are metric...so for you folks down south...392 ft/lb and 426 HP @ 21.9 PSI at 70 deg F ambient (per online conversion tools). As far as I know these are fairly accurate. Definitely better that the BMW gauges. |
07-21-2018, 06:21 PM | #7 | |
Rep 719
07-21-2018, 08:50 PM | #8 | ||
Rep 1,718
subliminalaudio313.50 |
09-23-2018, 06:23 PM | #9 |
Rep 39
I want one of those Awron multigauges too. Big problem is finding a shop that has the necessary skills to install it. The closest one to me is 100 miles away and I work full time.
09-23-2018, 07:05 PM | #10 |
Rep 1,718
I had the dealer put this one in. This is the type of stuff I will let them do...in other words...nothing important, lol.
09-24-2018, 01:06 PM | #11 | |
Meh
926
Rep 781
Drives: M3CS & Cayman S
https://www.harborfreight.com/4-piec...set-66836.html as for the power/torque reading, the AWRON most likely gets the numbers from the CAN bus, which is the same data stream on the sport display. comparing it to dyno runs, my AWRON/sport display shows a little higher than the whp figures. i wouldn't be surprised if the gauges display close to what the power to the flywheel is. |
09-24-2018, 07:14 PM | #12 |
Rep 1,755
I find it quite funny that the link in post two provides an answer to the question, which is yes, essentially the gauges are quite accurate. Further along, there are posts recommending spending money for aftermarket gauges that do the same thing the stock ones do, albeit with extra values.
2016 428ix, r, 2018 430iC, 2018 330it
