M2 Technical Topics > Cosmetic Modifications > Replace Weathertech Mat Graphic
      06-26-2018, 12:51 PM   #1
GregoryK
GregoryK's Avatar
504
Drives: M2 '18
Anyone have a solution for this. I can have 100 "M" dome stickers made for $500... Anyone seen anything around?
Winter is closer than you think!
"I would rather cry in a BMW than smile on a bicycle." Ma Nuo
kfscoll208.50
M235guy75.50
      06-26-2018, 05:34 PM   #2
MiStR StEvO
MiStR StEvO's Avatar
Are you referring to the sticker on the WeatherTech Digital Floor Liners? If so I'm interested in what it would look like.
2010 AW E90 335i M Sport
2012 GTR
2017 STi Limited
2018 LBB M2 DCT
      06-26-2018, 06:02 PM   #3
GregoryK
GregoryK's Avatar
504
Drives: M2 '18
Thinking something generic like this. But sized correctly.
Thoughts?
      06-26-2018, 08:52 PM   #4
babym2
Drives: 18 M2 6MT
In for this
      06-26-2018, 09:29 PM   #5
kfscoll
kfscoll's Avatar
Drives: ‘18 MG M2 6MT, ‘15 MW X3 35i
I'm definitely in for this. I've looked extensively and haven't found anything. The graphic you've proposed is precisely what I was hoping to find.
      06-27-2018, 04:45 AM   #6
MiStR StEvO
Thoughts?
I'm interested. My last vehicle which was an STi had the sticker replaced with an actual one that matched the rear badge. When I say sticker I mean it was same thickness as the WeatherTech one too. Very OEM like.
2012 GTR
2017 STi Limited
2018 LBB M2 DCT
      06-27-2018, 03:41 PM   #7
GregoryK
GregoryK's Avatar
504
Drives: M2 '18
I found these on aliexpess. The original "Weathertech" dome is 115mm x 30mm
https://www.aliexpress.com/item/2pcs...ceBeautifyAB=0
You would see the black behind but most is covered. Just a thought!
      06-27-2018, 06:02 PM   #8
ZPrime
I INDIC8
ZPrime's Avatar
Drives: 2018 LBB M2, 6MT
2018 BMW M2  [9.50]
^^ Those aren't too bad; I'd rather have "///M2" than just the /// or ///M
I know other companies produce these things to fill that stupid logo spot on Weathertech mats for other cars (my brother had some for his Subaru).
That said, I'm kind of upset with the Weathertech mats. The lip on the back edge is not sufficiently high to hold melted snow in there when accelerating. I end up getting salty water in the holes to the left of the seat rail, I think from where it has sloshed out of the Weathertech mat.
      06-27-2018, 08:12 PM   #9
GregoryK
GregoryK's Avatar
504
Drives: M2 '18
One trick I use is to unscrew the accelerator from the floor in late fall and lay a 12" square of plastic underneath then screw it back. This way the snow and salt that comes off your boots when you drive does get into the carpet near the pedal. I find it almost impossible to get the salt out of the carpet around the pedal....I have it all too wet vacs, steam cleaners etc. You might also try this trick in other areas...
One more thing...having lived and driven in snow for almost 40 years. I would say that if snow is getting in your car you are not "kicking off" properly. Sit down and wack you feet together outside the car and then put your feet in....We learn that early in Canada!
randyt224.50
KevM2723.50
      06-27-2018, 10:17 PM   #10
ZPrime
I INDIC8
ZPrime's Avatar
2018 BMW M2  [9.50]
I definitely don't kick off as much as I should, usually because I'm freezing my ass off and/or the snow has re-frozen to my boots and no longer wants to fall off.
I like the idea around the gas pedal. I had salt around the bottom of the carpet as well as some on the weird plastic scuff pad thing on the carpet to the right of the pedal. 50-50 mix of hot water and white vinegar in a spray bottle makes quick work of road salt, but it stinks to hell while you're doing it and for a few days after. Do the vinegar mix and blot up.
My problem is at the BACK of the mat though. to the left of the driver's seat.
      06-28-2018, 06:13 AM   #11
randyt
randyt's Avatar
Drives: 2018 MGM 6MT M2
2018 BMW M2  [0.00]
Not an issue for me as I will be driving the Taco in those conditions but,
+1 for kicking the snow off before you swing your feet in.
No reasonable amount of lip on back of the floor mat is going to stop the water on hard acceleration if it is "sloshing around" in the floor mat.
      06-28-2018, 10:02 AM   #12
GregoryK
GregoryK's Avatar
504
Drives: M2 '18
I have to make a minimum order of 100. I'l post pics when done.
      06-28-2018, 10:05 PM   #13
MiStR StEvO
I have tyui make a minimum order of 100. I'l post pics when done.
Looking forward to this! Hopefully it is clean with an ///M logo
2012 GTR
2017 STi Limited
2018 LBB M2 DCT
      06-28-2018, 10:39 PM   #14
M235guy
M235guy's Avatar
Drives: 2014 M235i
Interested.
      06-29-2018, 02:38 PM   #15
GregoryK
GregoryK's Avatar
504
Drives: M2 '18
Final Artwork.
Should get in 10 days. Will post pics.
I'm not into making money on this will sell for $5 each plus shipping. I'm thinking that they will go in a regular envelope. So max $2 for postage....hopefully.
dtmurf481.50
ROASTM163.50
      06-29-2018, 07:33 PM   #16
Banilejo
Drives: M2 LCI
I’m in, let me know when they’re available. I don’t even have the mats yet but will be getting them in the fall.
How does everyone like theirs?
      06-29-2018, 11:12 PM   #17
MiStR StEvO
Final Artwork.
Will they be as thick as the OEM WeatherTech ones?
2012 GTR
2017 STi Limited
2018 LBB M2 DCT
      06-30-2018, 03:46 AM   #18
dtmurf
dtmurf's Avatar
482
1996 BMW 318is  [4.75]
2012 Audi Q5  [4.50]
2017 BMW M2  [10.00]
Interested in this also.
'17 M2 DCT Long Beach Blue
      06-30-2018, 08:15 AM   #19
GregoryK
GregoryK's Avatar
504
Drives: M2 '18
Hoping so. Dome graphics are all made using a similar technique..
      06-30-2018, 12:35 PM   #20
MiStR StEvO
Keep us posted!
2012 GTR
2017 STi Limited
2018 LBB M2 DCT
      07-02-2018, 11:04 PM   #21
Downunder99
Downunder99's Avatar
Drives: 2018 BMW M2 | LBB | MT
2018 BMW M2  [0.00]
Definetely interested!
      07-04-2018, 04:30 PM   #22
arbim
arbim's Avatar
59
Drives: 2019 M2C LBB, 2007 328xi
Also interested
