01-25-2021, 11:19 AM | #1 |
Rep 632
Anyone else having this issue?
Pulled car out of garage. Washed car. Dried car. Put back into garage. Then I went to take it out about 2 days later and it took some high throttle and torque to get the care to move. Went back and saw that both rear tires basically fused on to the garage floor. Temps around 50-70 F. Never happened on any other car I've owned. |
01-25-2021, 11:25 AM | #2 |
IG@i.am.wah
2779
Rep 3,815
Drives: M2 CS
Are you sure it wasn't rust on the brakes?
01-25-2021, 11:31 AM | #3 |
Rep 352
You might have used them too hard too early. Tires like the PSS need a few hundred of normal break-in, and that stuff on the floor is likely the outer-layer of compound/wax put on the tire for shipment to protect it long term.
01-25-2021, 11:35 AM | #4 | |
Rep 4,663
01-25-2021, 11:44 AM | #5 |
Rep 632
Sorry added pictures. No tire cleaner or anything this wash. Only my initial detail back in late December. Car has been babied and not driven hard at all. Only 90 miles on her and haven't been above 4k rpm
It was sticky a few other times as well but this time was tough |
01-25-2021, 11:56 AM | #6 | |
Rep 464
Looks like early 'hot tire pickup', but hard to tell without checking the texture of the garage floor. https://allgaragefloors.com/prevent-hot-tire-pickup/ |
01-25-2021, 11:57 AM | #7 |
Rep 4,047
It wasn't your tires. After washing and leaving the car for a bit the brakes get very grabby, and also emit a nasty sound when used as it gets the rust off the calipers. If your tires stuck to the floor, then thats a whole nother animal...
01-25-2021, 12:05 PM | #8 | |
Rep 26
Having same problem with any type of tires even on my 440i... |
01-25-2021, 12:18 PM | #9 | ||
Rep 464
If you hold your foot on the brake for a few seconds after coming to a complete stop and then turn the engine off, the brakes stick to the calipers and next time when started, you can hear a loud audible clunk when moving the car. It's part of the auto-hold mechanism on DCT. Same problem in winter for those living in sub zero temps. |
01-25-2021, 01:21 PM | #10 |
Rep 632
I understand the sticky brakes. I felt that before. But this was rubber. It took some serious scrubbing my floor to get it off.
Floor is 5yrs old so it definitely cured. |
01-25-2021, 02:04 PM | #11 |
IG@i.am.wah
2779
Rep 3,815
Drives: M2 CS
is there a flat spot on your tires where it "melted" onto your floors? Ive heard of hot tires melting the epoxy off the floor, but not the other way around.
01-26-2021, 10:13 AM | #12 |
Rep 114
Is it possible the front pads were stuck and you spun up the rears slightly before they let go? You sir, might be the first CS owner to do a burnout in their garage
'13 F30 335i MSport 6MT - sold
'07 E90 325i MSport 6MT - sold '20 F87 M2 CS - AW/6MT/2NH/BLK/PSS |
MadBimmeRad7121.50 |
01-26-2021, 05:13 PM | #13 |
Rep 632
