09-24-2023, 12:59 PM | #1123 | |
4693
Rep 2,542
Ok cool - that looks like a fun corner particularly the exit |
09-24-2023, 01:07 PM | #1124 |
Rep 4,672
Yeah, you basically turn it into a straight by going over the curb, then the last right hander was off camber. But there was a spot near the curb that was a little low and your front right wheel would kinda hook into it and sling the weight to the outside wheels. If you hit it right you could carry a lot of speed. It's a weird looking turn though. There's a lot more runout room than it looks going into it. Such an amazing track.
09-24-2023, 01:27 PM | #1125 | |
Rep 557
That 13-15 section is deceivingly up hill and you can stay on throttle. Great place to catch the GT3s as that’s a weak spot for em. They also struggle with the T2 carusel so that’s a great place to press. Laying in bed rn resting between session. I’m spoiled. |
09-24-2023, 01:55 PM | #1126 | |
4693
Rep 2,542
You have a place there at the track??? |
09-24-2023, 02:09 PM | #1127 | |
Rep 557
My place isn’t on campus but nearby enough that when I get a big enough gap between sessions and the crew ain’t hanging out I’ll run home to rest. I’m ruined with this setup. I want to run Road Atlanta or VIR but I slept in till 8:15AM today and still had time to gas up and get coffee before rolling up for a 9:00AM session. Hang out in air conditioned race tower with TVs playing football. Feels like a private country club experience without the fees. |
09-24-2023, 02:54 PM | #1128 | |
4693
Rep 2,542
09-24-2023, 03:55 PM | #1130 |
4693
Rep 2,542
09-24-2023, 06:45 PM | #1131 | |
Rep 80
My solution is always go faster stupid. LOL First track day in the M2. For setup it has AP 9660 in front with 3.12 pads, m- performance coilovers. Ran them in the BMW street setting Sunday and track setting Saturday. Not sure of the ride height. Ran out of time to corner balance it, so I just set the rear as low as it would go and eyeballed the front. Going to try and get it corner balanced before Nationals if I can. Ground control camber plates with 3.2 camber with zero toe. Rear spl toe links with 2.3 camber and 1/16 toe in. Hotchkis front sway bar. Stock rear brakes and pads. Apex wheels with 275/30/18 in front and 295/30/18 in rear. No rubbing and the car handled curbs much better then my GT4 in either setting. Not sure if you are rubbing 295/30 or 295/35. Be happy to try and answer any questions to help figure out your issues. |
medphysdave4559.50 |
09-24-2023, 08:22 PM | #1132 |
Rep 489
Well crap now the pressure is on. I need to bring some fast tires apparently.
ThreeStripes being close to the track is nice. I sold my Tesla and picked up a small RV so I could have AC during our dreadful summers |
09-24-2023, 08:43 PM | #1133 | |
Rep 80
Wish I could be there to see you guys run. |
09-24-2023, 08:56 PM | #1134 | |
Rep 557
Yeah it’s weird. It’s not rubbing fender liner at all up front. It has in the rear on driver side but that happened before I was bottoming out the shock. It self cleared back there so now it’s just shock running out of travel. I wasn’t bottoming out on the back side of the tunnel before T13 until I was sub :41 so that’s fairly new Lol. I’m really happy with the TCK otherwise. The car does daily duty 4 days a week, is really balanced on track at the limit, and generally handles the curbs there well. If I could keep it from bottoming out, I wouldn’t change a thing other than more driver mod. Last edited by ThreeStripes; 09-24-2023 at 09:09 PM.. |
09-24-2023, 09:22 PM | #1135 | |
Rep 80
09-25-2023, 12:59 PM | #1136 | |
Rep 489
Look at my off throttle and not wot. https://youtu.be/tgIRMGOkVPA?feature=shared |
09-25-2023, 01:07 PM | #1137 |
Rep 4,672
Are you running the M2 as a dedicated track car? I go in for an alignment with my updated suspension parts and wheels. Trying to determine if I want an alignment that I stick with for DD and Track. Or having the shop set it up so I can quickly adjust the camber plates between track events. I'll run up to -2.5 degrees and accept the tire wear, but that might be giving up a bit more cornering fun at the track.
I swap pads anyway, so adjusting the camber plates is only a few more minutes. CSR front sway, Turner rear toe links, SPL front LCA, solid bushing in front tension arm. 295-30-18 square.
09-25-2023, 01:52 PM | #1138 | |
4693
Rep 2,542
09-25-2023, 02:04 PM | #1139 |
4693
Rep 2,542
Likely pushing 165 to 170 depending on aero load on the back at full bore - that car screams for sure. Don't think the HP will be quite as much help at Barber but definitely won't hurt! Going to be all about how quickly get up to speed on a new track and keeping the tires happy. The car should have a lot in it - but do the drivers?
09-25-2023, 02:31 PM | #1140 | |
Rep 80
Here is my last time there in my GT4. |
09-25-2023, 02:35 PM | #1141 | |
Rep 80
09-25-2023, 02:40 PM | #1142 | |
Rep 489
Here is the 1:37.02 run. I fiddlefarted from 12 and saw the checkered so I wasnt WOT but I think that could have been a 1:36 run easy. I am also still pretty chunk. Car/Driver/Gas is around 3600lbs. OG Shark built a crazy fast car. I just need to live up to its potential. |
09-25-2023, 02:50 PM | #1143 | |
Rep 80
Love to see video. |
09-25-2023, 02:58 PM | #1144 | |
Rep 80
Have you every sent a video into the guys at Blayze? They really helped me find some more time. |
