09-11-2019, 12:04 AM | #23 |
BMW forever!
1374
Rep 2,417
I have steering play going at 60 mph and above.
Alignment and suspension components are fine, got them checked. Can't figure out at this point but could be software related.
2020 BMW X5
2019 BMW M2C 2014 BMW 335i 2009 BMW 328i |
09-11-2019, 02:54 PM | #24 |
498
Rep 697
Drives: Alpine White 2020 BMW M2C
Garage List 2017 BMW X6 M [0.00]
2020 BMW M2 Competi ... [0.00] 1993 Mazda RX-7 [0.00] 2006 Mitsubishi Evo ... [0.00] 2005 BMW M3 ZCP [0.00] 2016 Ducati Panigal ... [0.00] |
still on OEM tires? if you cheaped out on them you can get some really sloppy steering feedback.
09-11-2019, 04:59 PM | #25 | |
BMW forever!
1374
Rep 2,417
I think issue could be related to PSS tires, excessive tramlining or steering software calibration. All the suspension components checked out fine, including alignment. I got my car checked from 2 different BMW dealers and got same results. My 335i has Michelin 4S tires and I don't have any play in my steering. I can't believe that I'm saying this but my 335i steering feels sharper than my M2C. Did anyone here have any bad experience with PSS stock tires? Thanks!
2020 BMW X5
09-11-2019, 05:56 PM | #27 | |
Luxury at the redline :)
9099
Rep 7,563
I didn't address this or mention it to anyone, since it was a loaner and my SA wouldn't of cared but just confirming you're not crazy and now, neither am I |
msdss497.50 |
09-11-2019, 07:59 PM | #28 |
498
Rep 697
09-11-2019, 08:00 PM | #29 | ||
498
Rep 697
Poochie9099.00 |
09-11-2019, 08:15 PM | #30 |
Rep 95
I have had, about four times, when I am in the car about to pull away it states that the trunk is open. I get out and check but the trunk is not open. It is fully latched but said it was open. I have to open the trunk and slam it shut to clear it. And I know I didn't hit the button on my fob.
Also, I now have a right rear blinker malfunction popping up occasionally. I don't think BMW engineers anticipated someone using their blinker more than five times! |
09-12-2019, 01:50 AM | #31 | |
Rep 825
09-12-2019, 09:11 AM | #32 | |
9099
Rep 7,563
Here's my DIY fix for the infamous rapid turn signal malfunction.. https://www.bimmerpost.com/forums/sh...php?p=25228472 It's just a suggestion because I get most wouldn't want to splice into their new vehicle's stock ground wiring but I know it's the only solution, as there is only so much that can go mechanically wrong in a LED taillight operation. |
09-17-2019, 05:02 AM | #34 |
9099
Rep 7,563
I think I might of found the issue with at least the random trunk opening; apparently BMW set the trunk unlock button to active after .5 seconds, stock.
Wearing tight-ish cloths or any object that slightly depresses the button, inadvertently opens the trunk. The resistance for the remote is pretty low. The dealer obvious would be "unable to duplicate the issue" so what I suggest you do is code the truck release to commence after a 5 seconds delay. This should eliminate all intermitted trunk opening. |
cptobvious2531.50 msdss497.50 |
09-17-2019, 10:40 AM | #36 | |
498
Rep 697
So all this setting does is dictate how long the button on the remote has to be pressed? .5 seconds seems like a stupid low value. |
09-17-2019, 10:45 AM | #37 | ||
9099
Rep 7,563
It's a little more effort but at-least it would prevent your remote from "butt-dialing" Edit: Yes, that's a Bimmercode snap shot, the setting is located in the pre-populated FEM menu. . |
msdss497.50 |
09-23-2019, 03:58 PM | #38 | |
Rep 843
How are we in 2019 and BMW can't perfectly align folding mirrors, lol. |
09-23-2019, 04:40 PM | #39 | |
Rep 51
happened to me the other day. |
09-24-2019, 01:53 AM | #40 | |
fuck this field
2187
Rep 2,605
BMW family... for now.
09-24-2019, 08:46 AM | #41 |
Rep 443
I find that my mirrors have a bit of 'give', but not much. If I wash them they are slightly misaligned to where I want them but not a big deal.
Only issue I'm having now is sometimes my left turn signal rate doubles in frequency and I get an error message "left rear turn signal malfunction". |
09-24-2019, 10:02 AM | #42 |
Rep 900
both of the rear tail light got problem
1 already got replaced, need time to go back to replace the other one
2019 M2 HS 10000km and counting
