09-09-2019, 04:48 AM | #1 |
Rep 48
M2C : Active Autowerke Midipe delivery to germany ?
Hi all,
my colleague and myself looking for the Active Autowerke Midpipe for an M2C. Does anone know if an delivery to Germany is possible (did not get feedback from AA so far) ? Or knows a dealer who has that in Stock and will deliver that Midpipe to Germany ? Thanks in advance. Cheers Last edited by Winterstorm; 09-09-2019 at 04:55 AM.. |
09-09-2019, 05:33 AM | #2 |
Rep 1,477
09-10-2019, 02:15 PM | #3 | |
Rep 54
Unfortunately when you give it all at low revs with a high gear the control unit goes into sleep mode. Just turn the car off and on to make communication disappear and return to full power. Unfortunately upstream of the fap, on the down pipe, are connected two small tubes that feel back pressure created by the fap. A real billet. The noise is fantastic and the performances improve by 15 CV (see dyno ) It is necessary to map the control unit to be able to use autowerke kits on European version with fap Caution . If your M2 C has the latest BMW software update released in March 2019 you can no longer map it via the OBD socket. I had to bring my Biesse Racing Tuner that manages to map them by connecting directly to the ECU without disassembling the intercooler. |
09-12-2019, 05:13 AM | #4 | |
M Addict
Rep 21
Cheers
M for life
09-12-2019, 12:29 PM | #5 | |
Rep 54
If you map the ECU you will have no problem using the autowerke kit. I made a thousand km after mapping and the ecu never entered limp mode. By eliminating the FAPs you can get the same performance on the M2C as on the M3 / M4 |
09-12-2019, 02:14 PM | #6 | |
M Addict
Rep 21
Cheers
M for life
10-02-2019, 07:09 PM | #8 |
24174
Rep 190,750
I can help
10-04-2019, 08:48 AM | #9 |
Rear Admiral
1485
Rep 1,706
Drives: Bavarian Milk Wagon
CA Technologies in the UK are an importer and Roy there was very responsive. Their up charge due to VAT, duties, etc is pretty steep, 1330 GBP.
CA Technologies International BMW Tuning : www.ca-int.co.uk Enquiries@ca-int.co.uk I've been meaning to reach out to Mike or another US dealer to see if they can send me "a used mid pipe with a value of around 50 USD" |
MRosth126.00 |
10-04-2019, 09:15 AM | #10 |
Rep 744
https://pureturbos.eu/aa-midpipe.html
Not sure if its cheaper with shipping to the UK but 1.4K Euro or 1249 pounds (man the exchange rate sucks for us guys now). |
10-05-2019, 10:42 AM | #11 | |
24174
Rep 190,750
Kankles1484.50 |
10-15-2019, 12:02 AM | #13 |
Rep 456
Try Thomas at Automotive Passion in the UK. That's where I bought my AA midpipe from. I had my car remapped by Litchfield to prevent back pressure sensor issue and no problems so far 👍🏻
2019 HS DCT M2 Competition with Essex AP Racing Radical Pro5000r front and rear BBKs, Bilstein B16s and 763M wheels with Cup 2s
Kankles1484.50 |
10-15-2019, 03:01 AM | #14 |
Rep 1,152
There is a box of tricks (appologies cann’t recall it’s name) you can wire into the CAN system which eliminates the fault code/limp mode for unmapped cars, theres a thread somewhere on the board
Edit: this is the post I was thinking of https://f87.bimmerpost.com/forums/sh....php?t=1657079 Last edited by JonD; 10-15-2019 at 03:51 PM.. |
