09-08-2019, 02:54 PM | #1 |
Rep 185
Drives: 2020 M2 Comp.
M Performance Mirror Caps (not secure)
Just removed one of my factory mirror caps and attempted to install the M Performance Cap. I noticed it wasn't secure towards the bottom. Now comparing to the Factory part there's no hook and the bottom section. Is this normal? I'm thinking this is going to fall off. Something doesn't look right here. This was purchased from GetBMWParts.com
https://www.getbmwparts.com/oem-part...IFJlc3VsdHM%3D I've reached out to GetBMWParts.com waiting for their response. Last edited by MVista; 09-08-2019 at 03:52 PM.. |
09-10-2019, 02:37 PM | #2 |
Rep 251
the part code it is absolutely correct. did you try doing the installation process again? did you remove the morro for installing it to be sure that every clip was in place?
09-10-2019, 04:47 PM | #3 |
Rep 72
Looks correct based on photos cross referenced here.
https://www.ecstuning.com/b-genuine-...t/51142348099/
Current: 2020 HS M2C DCT
Past Bimmers: e46 M3 6MT, e90 328i, e46 323i, e30 325is |
