08-29-2019, 07:48 PM | #1 |
Rep 328
Holding Launch Control
In a normal automatic car with a torque converter, you cannot hold your your brake and gas at the same time for an extended period of time because the torque converter will heat up too much to cause damage.
However, does the same thing apply to our M2's with DCT? Does it wear out the clutch if I hold the car in launch mode at 3500 rpm or it is just like revving a car in neutral and will not cause damage? Also, I know the car runs cooler in Sport than Comfort, but is there a difference in cooling between Sport and Sport+? Thanks |
08-29-2019, 09:39 PM | #3 | |
16074
Rep 8,371
Screw Launch control. I just hammer it.
MetalMK228.50 |
08-30-2019, 10:53 AM | #4 | |
Rep 6,634
08-30-2019, 11:05 AM | #5 |
Rep 328
08-30-2019, 01:41 PM | #6 | |
Rep 6,634
I thought you were talking about a brake torque launch? |
08-30-2019, 02:52 PM | #7 | |
Rep 328
Anyways, is it bad to keep the car in launch mode for some time without actually launching the car? |
08-31-2019, 12:43 AM | #9 |
756
Rep 2,149
I always thought it stopped after holding it for a certain period of time. But I don't know now, didn't see anything in the manual about that.
I do see in the manual that you have to drive at least 6 miles before it becomes available, and that it will become unavailable if the transmission gets too hot. Giving a yellow or red transmission warning light depending on it's temp. And that the red transmission light puts you into limp mode and you should pull over and let the car cool off. In my experience, I believe I've had it become unavailable after activating it 2-3 times in a row before without actually launching, but never had a tranny light come on. Personally, I don't see a reason or a problem with holding it for more than 20 seconds (if it allows you to). Can't think of a situation you'd want to hold it for more than a couple seconds, to be honest. Best way to answer your question though is to try it out yourself. Hold it for 5 seconds, then stop and see if a tranny light comes on. If not, do it for 10secs and see. If not, then 20secs. And so forth. The car has failsafes to prevent damage from overheating the transmission, so it'll be okay. |
MetalMK228.50 |
