08-26-2019, 09:17 AM | #1 |
Rep 248
Coils + 295's = Putting M2C power down?
Hi Everyone,
Recently got to take part in the M Town Tour and tried out the M2C, X3M C, and M5C, what a cool experience BMW put on Anyway, loved the M5 and M2 but the M2 is the one I find myself thinking about most by far, reminded me a lot of a 991.2 C2S I drove earlier this year as far as driving dynamics and it looks incredible. I noticed though that it was a struggle to put the power down without even touching MDM (breaking news I know lol) so was just wondering for those of you fortunate enough to own the M2C and start modding it, has adding a set of coilovers and 285/295 rear tires made a noticeable difference in added traction? Especially with so many tunes available to add more power, let alone the pure turbos setup, curious if those power adds are viable. For perspective, I enjoy that accelerative punch so much and totally agree the car doesn't need more power, but the blast up to street speeds that's a bit disorienting is my jam and I'm not looking to track it much if at all, just have an incredibly fun daily. I've hunted around the forums but haven't seen any direct setup reviews of coils tires and more power and if it hooks, please point me there if I missed it. Thanks for your input! |
08-26-2019, 12:32 PM | #2 |
844
Rep 1,962
A 911 will always have better traction than other RWD cars due to where the engine is (mid-engined race models aside). Wider tyres are good in corners but less help off the line. The coil-overs are also aimed at something other than traffic light grand prix.
HTH |
automotiveaperture92.50 |
08-26-2019, 01:42 PM | #3 | |
Rep 248
My comparison to the 911 C2S was mainly around the solid feeling of the car and lack of slop/play when quickly changing direction, felt "all of once piece" which I was really impressed with. Prices being equal I think the M2C might still be my choice as it was a real blast. As far as the rear engine benefit to traction you're spot on, I had the opportunity to try a 991.2 GT3 a few months ago, absolutely incredible, best car I've ever driven, but driving the M2C also helped put things in perspective. The GT3 is the better car in pretty much every quantifiable way but the M2C is an incredible bang for buck. For 100k less it is a very viable fun/weekend or daily car. |
08-30-2019, 02:05 AM | #4 |
Rep 1,759
Get grippier tyres instead of going wider
Get Michelin Cup 2 or Yokoharma A052 or Bridgestone RE71R |
08-30-2019, 06:52 AM | #5 |
Rep 4,510
Top tip - even with oem MPSS 265 rear tyres - reduce rear camber from ~-2deg to nearer -1.5deg and helps a huge amount with traction [straight lines] and corner grip !!!
Hopefully photo below should help show change in contact patch:- - original scrub line @~-2deg, being inboard; - newest scrub line c/o -1.5 deg, upto the edge of the tyre tread.
Current '22 X3M LCI.. |
08-30-2019, 07:50 AM | #6 | |
Rep 248
Assuming that is your setup, how did you come across that camber adjustment solution? This paired with some Cup 2's or similar as Karmic mentioned ( ) sound like a solid performance upgrade without getting the coilovers. I have a longer commute so with high mileage probably wouldn't go as aggressive as Cup 2's unless I got it as a weekend car primarily, have PS4S's on my e92 M3 and really like those, would be a great performance daily tire for the M2C |
08-30-2019, 08:03 AM | #7 | |
Rep 4,510
FWIW, try the cheap fixes 1st ie I'd suggest driving it for awhile as-is then asking yr local alignment shop for:- front:- - camber/castor - n/a as this fixed/non-adjustable - toe-in set to just above zero but less than 0.05deg. Rear:- - rear camber -1.5deg - rear toe-in set to ~ 0.05deg. See how the above set up feels compared to original setup.... PS - @GreatWhiteM2 on here had -2deg+ on rear of his stg 1 M2C with 245/265 Pirelli Trofeo R's - great for track not ideal for bumpy A&B roads here in the UK. He took the car back to get less rear camber dialled and made a big difference to getting 500/500 power/torques down to the ground !
automotiveaperture92.50 FreeDarko217.00 |
08-30-2019, 08:20 AM | #8 |
Rep 248
Very informative details, thank you! I'll note these settings.
Good to know, I wouldn't be going above 500 hp/tq for quite some time if ever, that's an incredible amount of power to be put down through 265's wow, I could easily spin my 265 Continentals on the M3 with half that torque haha, the 275 PS4S's hook amazing now though. |
