08-22-2019, 07:33 AM | #45 | |
Rep 8,972
Kind of warm but cooling a little is good, but soon gone as you say! |
Proctor750426.00 |
08-27-2019, 11:07 AM | #48 | |
Rep 1,237
Drives: M2 Competition
Permanently "stored" is only possible via DME ECU flash or alternatively using third party hardware modules (valve controllers).
cb8042351.00 |
09-05-2019, 10:32 PM | #49 |
Rep 331
Drives: M140i F20 LCI-2
iCar Pro and OBD.Maven
I decided Carly for BMW Pro is just too much trouble to get connected to their proprietary adapter (it hates Bluetooth on my Pixel 2), so I now use an iCar Pro adapter (about AUD30/USD20) and the OBD.Maven app (free from Play Store). That stated, this morning I got Carly for BMW connected by changing the Pixel 2 Settings>>System>>Advanced>>Developer options>>Bluetooth AVRCP set to 1.6 rather than the default 1.4. Worked flawlessly coding rear inner and outer LCI DRLs on.
The iCar Pro will connect using an Android or iOS smartphone/tablet and will use WiFi or Bluetooth. I use BT and it connects instantly. Moreover, I can add it as a trusted device to Smartlock .... meaning the connection stays live even if the phone's display is off. Opening the rear exhaust flapper actuator valve is a one click operation. No need to buy a dummy plug (BMW Part No. 18302411427) with the need to tie a piece of wire to hold the actuator in the open position once you have opened it electronically.
Current: Alpine White M140i F20 LCI-2, 250kW/335hp, 2018.
Sold: Melbourne Red 340i F30 LCI Luxury Line MMPK - 265kW/355hp, 2016. Sold: Alpine White 123d e82, 2010, 150kW/204hp. Last edited by DrGadget; 09-06-2019 at 08:24 PM.. |
09-05-2019, 11:41 PM | #50 | |
Rep 632
09-06-2019, 08:20 PM | #51 |
Rep 331
The flap will stay open for as long as you keep the app connected to the car. You can turn the car ignition off and it will stay open on this basis. But, if you leave the car with your phone and connection drops, the flap will close when you deactivate the canbus.
Sold: Melbourne Red 340i F30 LCI Luxury Line MMPK - 265kW/355hp, 2016. Sold: Alpine White 123d e82, 2010, 150kW/204hp. Last edited by DrGadget; 09-07-2019 at 07:35 PM.. |
FreeDarko217.00 |
10-11-2019, 06:10 AM | #52 |
Rep 936
Bumping up this thread with another question...
Has anyone used the Burger Can Flap Module to keep the valves open? https://x-ph.com/bms-f-series-can-flap-module/ It looks super easy... just plug into OBDII port and all the settings are changed via the BC function on the turn signal. |
10-12-2019, 10:47 AM | #53 |
Rep 3,842
One easy way to keep the flap open is to do a BM3 tune and set the valve to be open in Sport modes but be normal in Efficient mode. You just press the mode button to open and close it.
10-12-2019, 10:56 AM | #54 |
Rep 1,297
This.
10-13-2019, 07:43 PM | #55 | |
Rep 764
Regarding everyone talking about how to keep them open. Yes unplug once open and your done. I don't leave them like that since I like having the option to close them if I want. Personally I get in the habit of pushing ignition on once with out foot on pedal then press M2 then press gas pedal to the floor. This forces exhaust to stay open on start up. I like gts roar :-) |
Proctor750426.00 |
10-14-2019, 12:29 PM | #56 | |
Rep 391
Drives: F87 M2C
-Accessory on -Switch to Sport -Tap throttle (Flaps open) -Start Then the flaps automatically close once you try to start the engine.
Past: 2011 Acqua Minerale Blue Hyundai Genesis Coupe 3.8 Past: 2017 Alpine White 440i F32 Current: 2020 Long Beach Blue M2 Competition PC Build: 5950x/6900xt |
10-05-2021, 08:44 PM | #57 |
2426
Rep 11,667
10-06-2021, 04:58 AM | #58 | |
Rep 327
Some have said it times out after 15 minutes as well. I have an Akrapovic and I bought the CG VSC-2. 15-20 minute install, preset buttons (I did automatic for factory default settings and open), it's programmed to the home link for open and close control. The Akrapovic came with its own sound kit that was needlessly complex to install, involving full trunk interior disassembly and running wires through body grommets. Here is a multi page rabbit hole of discussion. https://f80.bimmerpost.com/forums/sh....php?t=1099274 |
inTgr8r2425.50 |
10-06-2021, 04:59 AM | #59 | |
Rep 327
AndrewC198910910.50 |
10-06-2021, 03:23 PM | #60 | |
2426
Rep 11,667
Love to be able to control from the homelink buttons; I have two spare |
10-06-2021, 03:42 PM | #61 |
Rep 243
10-06-2021, 03:45 PM | #62 |
Rep 174
Has anyone noticed increased throttle/turbo lag keeping the valves open? I tried with Carly app leaving the exhaust flap open and I noticed more lag, I have to experiment more but maybe its in my head?
CURRENT: 2020 M2 Competition (BSM)
Previous: 2008 135i |
10-06-2021, 03:55 PM | #63 | |
2426
Rep 11,667
What I don't like is you have to leave it in the OBD port plus you loose steering wheel functions. |
10-06-2021, 05:00 PM | #64 | ||||
Rep 243
10-09-2021, 10:15 AM | #65 |
Rep 327
I have not read a written rule or suggestion to do so, but I personally only open or close the valves at idle if not in automatic mode so there is no extra flow of exhaust hindering movement and possibly leading to premature valve failure.
If I am at speed I put it in neutral and let the revs drop to idle before activating the valves. Does anyone else do this? |
