11-18-2020, 09:52 AM | #23 |
Rep 1,348
641s are 8.5" up front and 9" in the rear, so theoretically you could go up to a 255 in the front and a 265 in the rear. 27 mm (f) and 29 mm (r) offsets though, the stock is 29 mm and 40 mm.
21 BMW X5 xDrive40i
20 BMW M2 CS 19 Mini Cooper S Countryman ALL4 6MT |
QM287.00 |
11-19-2020, 01:46 PM | #26 |
Rep 17
Haven't hit any snow yet just some rainy days and they feel good. Narrower is typically better for winter tires as they can cut through fresh snow better. Wider is better for packed snow. I'm not overly concerned about loss of performance benefits. I mostly want a safe ride/legal ride for 3-4 months then back to fun. I'll chime back in once I'm faced with some snow.
QM287.00 |
11-19-2020, 01:49 PM | #27 |
Rep 17
Found this on another site, it's for the silver version but its the same wheel if black.
Style Number: Style 641M Standard on: M4 winter wheel Wheel Name: V-Spoke OEM BMW Part Number, Front: 36102284907 OEM BMW Part Number, Rear: 36102284908 Wheel Finish: Dekor Silver II Front Offset: ET+27 Rear Offset: ET+29 Bolt Pattern: 5 x 120 Factory Setup, Front: 19 x 8.5 Factory Setup, Rear: 19 x 9.0 Factory Tire Size, Front: 235/35/19 Factory Tire Size, Rear: 235/35/19 Wheel Weight, Front: 28.66 lbs (13.0 kg) Wheel Weight, Rear: 29.76 lbs (13.5 kg) |
QM287.00 |
11-19-2020, 03:07 PM | #28 | |
Rep 1,348
https://www.leebmann24.de/bmw-winter...112358496.html https://www.leebmann24.de/bmw-winter...112462548.html
21 BMW X5 xDrive40i
11-19-2020, 03:32 PM | #29 |
Rep 1,672
Drives: M2 CS | M135i
I took the jetblack 641M. My dealer will install those winter wheels simultaneously with the 2000kms oil change. The car has 1700 kilometers so I think that I will do it in one or two weeks
2020 M2 CS DCT
2021 M135i xDrive ex: 18 M3 DCT ZCP | 15 M3 DCT | 11 M3 Coupe 6MT ZCP | 07 M Coupe |
11-20-2020, 06:05 AM | #30 |
Rep 3,069
This thread made me do some research. The last time that it snowed in Sydney was 1836. Pilot Cup 2 will be my winter tyre.
QM287.00 KahunaCanuk39.50 |
11-20-2020, 10:59 PM | #31 |
Rep 1,418
I had this OEM winter set on my old F80 ZCP and they're sitting in my basement. I don't think I will run a winter set on the M2 CS at all but will these actually fit?
36-11-2-358-495 F8x M3/M4 19" Style 641M Silver Winter Wheel/Tire - 8.5x19 Continental ContiWinterContact 255/35/R19 36-11-2-358-496 F8x M3/M4 19" Style 641M Silver Winter Wheel/Tire - 9x19 Continental ContiWinterContact 255/35/R19 |
11-21-2020, 02:40 AM | #32 | |
Rep 1,348
21 BMW X5 xDrive40i
11-21-2020, 03:05 PM | #33 | ||
Rep 1,418
12-02-2020, 04:32 PM | #34 |
Rep 1,672
First snow drive tonight for me. Like the M3 it is really good if there is not a lot of snow! Exterior temp was minus 6.5 celcius degree.
2020 M2 CS DCT
4
12-06-2020, 06:29 AM | #35 |
Rep 1,672
Morning drive (in MDM mode because -5 degrees celcius) The rear diff makes a great job!
2020 M2 CS DCT
I Epic I7.50 CarJunkie2616.50 QM287.00 MomoM3984.00 Davil6523.00 Al Bundy's Dodge1640.00 seis-speed2430.50 |
12-07-2020, 05:54 PM | #36 |
Rep 1,672
Salty winter!
2020 M2 CS DCT
12-08-2020, 10:35 AM | #38 |
Rep 1,672
None... 😱
2020 M2 CS DCT
12-08-2020, 11:42 AM | #39 |
Rep 2,819
Drives: e82 1M, f87 M2cs
Just wash regularly. Its a drivers' car, not a museum piece.
Hedoniste3834.00 |
12-08-2020, 03:29 PM | #41 |
Rep 1,672
Sure ! And it is really nice to drive even with winter tires on cold roads!
2020 M2 CS DCT
CarJunkie2616.50 |
12-08-2020, 03:30 PM | #42 |
Rep 1,672
Nice observation !
2020 M2 CS DCT
12-09-2020, 01:51 AM | #43 |
Rep 1,407
12-09-2020, 02:06 AM | #44 | |
Rep 1,672
Front wheel width is 8.5 inches and rear 9.0 inches.
2020 M2 CS DCT
