10-26-2020, 07:20 PM | #1 |
Rep 201
Turbosmart BOV install help?
What is the best way to install a new diverter valve? I tried once before (without) removing the turbo inlet pipe, but could not reach the screws. I want to try again once I get in my new turbo inlet pipe, should I remove the stock boost pipe and the turbo inlet pipe to make space for it?
10-26-2020, 07:43 PM | #2 |
Rep 391
I changed out my diverter to Turbosmart. I followed a YouTube video from BMW DIY guy. He has some good tips towards the end of the video. I removed the water pump bolts and just pushed it over. I cut off an Allen key to be shorter to get the new bolts started. I used an assortment of extensions to get the stock ones lose and to tighten the new one up from the front by the rad (accessing from top of engine and some from bottom reaching up between rad and engine. Had to remove a bunch of stuff to make room for my hands. Water pump mounts were used to help guide my extensions in.
You will need a ball ended Allen key in correct size. I used 3 of them and cut two to the correct sizes needed, and then I hot glued them into a socket so I could marry them into an assortment of ratchet extensions to get the perfect fit. I have done a lot of work on my various cars and this is by far the hardest job I’ve done on any of them. Like 20 times harder than the downpipe. And similar to changing headers on a very old Nissan Armada! If I were to do it again I’d just take it to a shop and pay them a couple hrs labor to do it. Lots of bloodied fingers/hands. |
10-26-2020, 07:58 PM | #3 |
Rep 266
Installing the diverter valve is not too bad if you remove the upper intake pipe. Once the pipe is removed there's plenty of room to go from above and get to the top bolt. I recommend a ball end hex key. You still can't see the bolt and going by feel but you have enough room to reach it with a small extension along with your hand and feel it slip in. As for the bottom 2 bolts I found it easier to use a super long extension and go through the radiator fan to get to the bolts straight on. Removing the water pump bolts and having it loose helps a lot. Tip on getting the top water pump bolt. If you have the upper intake pipe removed you can easily reach it from above with a long extension. I'd suggest getting an MST V2 and doing it at the same time. Honestly I think I could do the Diverter install in 2hrs-ish.
10-26-2020, 08:25 PM | #4 | |
Rep 7,422
10-26-2020, 10:27 PM | #5 | |
Rep 201
10-27-2020, 08:25 AM | #6 | ||
Rep 1,899
10-27-2020, 05:00 PM | #7 |
Rep 266
I agree, it's definitely not worth 750-850 to do it. Not having the bottom the inlet pipe will give you more room to work. This is why I 'm suggesting doing the MST V2 at same time.
10-27-2020, 08:53 PM | #8 |
Rep 201
Yea im waiting for black friday to pick up the rest of my bolt ons, turbo inlet pipe, charge pipe intercooler and then im gonna install everything at once
10-28-2020, 05:50 PM | #9 |
Rep 266
That's what I did and it took me an entire weekend to do it all by myself. I see you're in SoCal? Where about?
10-28-2020, 08:34 PM | #11 |
Rep 391
It took me about 4 hrs start to finish. But if I were to do it again probably a couple hours as I know how now and have the tools to eliminate all the trial and error I was doing. A shop familiar with the job should only take a couple hours. I was also working with front wheel ramps and laying on my garage floor. So a lift would make it much easier. If you have smaller hands that would be a huge asset. My hands and fore arms are XL so I struggled and even got stuck a few times!
I should have video logged it and my tools I used to save others time. However, I underestimated the job. Top bolt was the hard one for sure. |
10-29-2020, 10:46 AM | #12 |
Rep 757
I replaced all the pipes at the same time which made removing the stock DV pretty easy and installing the TS a little easier. A ball allen is a must have but also, I found a very small ratchet to be invaluable, I could get it up over the water pump (bolts removed) with an extension and I could turn the bolts because the ratchet was so small. I picked it up years ago as an impulse purchase while checking out at AutoZone.
The harder job for me was installing the PCV hose onto the Pure Turbo intake pipe. It looked like the little set screw was in the same position as the self tapping screw on the stock pipe but it is not! Once the pipe is installed, it's closer to the 6 o'clock on the Pure Turbo vs 4 o'clock on the stock pipe. I could not get it to thread and ended up removing the intake pipe again, installing the hose and working the whole lot back into position. The MST V2 looks to be more in line with the stock pipe position so if I were doing it again...
'17 M2 DCT Long Beach Blue
10-29-2020, 12:10 PM | #14 | |
Rep 266
///M TOWN16233.50 |
11-06-2020, 11:50 AM | #15 |
Rep 52
Here's a video a buddy and I made on installing this along with the MST inlet pipe!
Cary Jordan 91 Oct Tune~ CSF FMIC, DCT Cooler~ VRSF Chargepipe~ MST Turbo Inlet Pipe~ Fabspeed Sportcat Downpipe~ Turbosmart BV~ Ohlins R&T~ do88 Oil Cooler, Radiator, Remote Radiator~ Girodisc Rotors
///M TOWN16233.50 |
11-06-2020, 02:47 PM | #16 |
Rep 201
11-06-2020, 03:17 PM | #17 |
Rep 52
You and me both haha, it was a bit of a struggle for us but hopefully this will help others who come across this thread
///M TOWN16233.50 |
06-11-2021, 09:17 AM | #18 |
New BMW owner
325
Rep 842
So does anyone know how that small screw he mentions at the end is mounted?
06-12-2021, 07:45 PM | #19 |
Rep 7,422
A ball end hex will enable you to reach all 3 bolts on the diverter valve without issue. It'll give you enough angle on that too hex by the oil line, that's what I used and it worked perfectly.
08-16-2021, 09:39 PM | #20 |
New BMW owner
325
Rep 842
Before I start to disassemble and pulling parts out, Ive got the ball-ended Allen that can plug into a socket. I'm wondering how long these extensions need to be. 6"... 12" .... 20"? I'm assuming ¼ size is best here and not the ½.
Just preparing myself. Planning to take it slow.
08-16-2021, 09:47 PM | #21 | |
Rep 7,422
Be careful ball end sockets are so fragile they will easily break, I recommend a hex key to remove the bolts initially and then ball end sockets to tighten the bolts at the end. Because at the beginning there's still enough room between the oil line and diverter valve for a hex key to fit but at the end there isn't.
08-17-2021, 01:40 PM | #22 |
Rep 266
If you're replacing the inlet piping at the same time it's so much faster going from the top of the engine and feeling for the bolts IMO than going from the bottom and trying to get your arm in strange angles to reach them.
