09-02-2020, 01:30 PM | #1 |
Rep 247
Are the BMW tire pressure sensors accurate?
The digital tire pressure readout in iDrive always reads lower than my tire gauge. Wondering which one is accurate.
09-02-2020, 01:43 PM | #2 |
6626
Rep 4,145
Drives: '18 M2 6MT
My gauge always shows a few psi higher than the TPMS does, and I go by my gauge instead of what the car says. All I use the TPMS for is to let me know if I'm below spec.
4
09-02-2020, 01:59 PM | #3 |
Rep 4,040
I was concerned my TPMS was broken because it has showed the same reading consistently (when cold) since I bought my M2 in December. So I decided to recently check (I know, what was I thinking?) and the gauge showed the same, maybe 0.5 - 1 psi lower here and there. I then use a third gauge of measure, the electric air pump, to inflate up to 35 psi (which is my desired psi), and the air literally stopped filling within seconds. So, having triangulated all three sources of data, I'd say my TPMS was fairly spot on.
09-02-2020, 02:12 PM | #4 |
Rep 6,878
Drives: 2018 M2 AW DCT
Varies. Most are off 1 to 2 pounds. They seem to be fairly consistent among themselves.
09-03-2020, 06:05 AM | #5 |
Rep 7,594
Drives: '19 M2C
My TPMS is higher by 1 PSI than both my highly accurate gauges.
www.ReTuneTheDeTune.com
///M TOWN13117.00 |
09-03-2020, 07:11 AM | #7 |
Rep 2,602
I'd say mine is accurate to 1 PSI. I also had my tire gauges checked for accuracy. One was close 1-2 off, the other like 5 PSI off so don't use it any more...
2020 X3M non-comp, Alpine White over black : Exec Pkg, ventilated M Sport seats, 20"s
2020 M2 Comp, Sunset Orange/Blk: Orange stitching, DCT, exec pkg, bicolor rims Gone '18 M550i, '16 X4 M40i, '15 M5, '13 X3 35i, '12 335is, '11 X5 50i, '09 Z4 35i, '08 550i, 06 X3, 06 650i, '02 M5, '99 540i |
09-03-2020, 10:22 AM | #9 |
6626
Rep 4,145
Drives: '18 M2 6MT
Now I'm glad you started this thread, as I assumed they were all like mine. Weird that they are so inconsistent.
09-03-2020, 11:42 AM | #12 |
Rep 2,401
Drives: E46 ZCP, F85, E70, G07
This might seem like a silly question, have you tried to manually set the air pressure, then reset the TPMS sensor on the iDrive screen and see if that shakes out.
Brandt51839.50 HelpMeHelpU126.50 |
09-03-2020, 01:16 PM | #14 | |
Rep 308
I set all tires at 37PSI and following the TPMS reset, they were all displaying exactly 35.0 +/- 0.1. So then my question became -- is TPMS actually measuring pressure, or just assuming a correct set-point (which it declares as "35") and then inferring pressures from temperature and rolling radius differences? I haven't had these tires off the rims yet. Are there actual pressure sensors on the M2? I suppose i could let a few PSI out of one tire and reset to see what happens to the display? |
09-03-2020, 01:42 PM | #15 |
Rep 2,401
Worth a shot.
09-03-2020, 02:41 PM | #16 |
Rep 2,602
TPMS seems to accurately measure the deltas. That's most important during track days. If it's 1-2 psi low cold, it will be similar when hot. The pressure and temp go up when in the sun, when driven hard, etc so it is real time measurements when driving. Older systems were rotational based to just warn if going flat but new systems do directly measure temp and pressure. Although I don't know why it insists on driving first.
During the latest autocross after a good many runs and as air temps went up, my psi increased from 35 psi to 41 psi. Temps hit 150 f. My tire gauge was close, 42 tops. I dropped all 4 tires 2-3 psi to regain traction.
09-03-2020, 03:27 PM | #17 | |
this is the way
17924
Rep 8,459
09-04-2020, 12:56 PM | #18 |
Rep 5,727
Drives: 2019 M2 Competition
I cant speak for everyone's car but i can confirm that the TPS sensor probably reads about 1 PSI below what the actual PSI is. I used this fancy electronic machine to put all my tires to the recommended 35 psi. It blows air into the tire until it digitally reads the targeted setting. THen i was kind of speculating so i used my hand held analog reader and sure enough every tire was exactly at 35 psi. So then i checked the car, and it said 34 psi for all...
09-04-2020, 02:08 PM | #19 |
6626
Rep 4,145
Drives: '18 M2 6MT
I imagine the TPMS is set to read just a bit low because that's a common issue, especially as soon as it gets colder. Better to correct it early before increased tire wear and decreased performance sets in.
11-21-2020, 10:59 PM | #21 |
Rep 37
Today I started a similar thread by mistake. Cross posting it here: https://f87.bimmerpost.com/forums/sh....php?t=1777005 .
11-22-2020, 02:25 PM | #22 |
Rep 8,972
Yes our TPMS measures actual pressure and temp with in-wheel sensors. Older systems use wheel speed etc.
Coming from a measurement / instrumentation background I would say don't even worry about 2/3/4 psi difference at our pressures. Even 5% accuracy over say 100psi is good for a home gauge considering temperature variation etc. Fretting about 1 or 2psi is pointless to the extreme. What is more important is setting pressures with cool tyres and doing all 4 at the same time to get relative pressures correct. |
