07-16-2019, 08:00 AM | #1 |
Rep 135
used M2 - carfax -
Hello all, after having repeated issues with my x3m40i, the dealer is working on buying my vehicle back. I found this OG m2 that i really like but look what the carfax shows. Is this a car i should consider ? would the replacement of clutch / flywheer etc. create any other longer term damage. I can get the car in the 46 range w low miles.
07-16-2019, 09:28 AM | #2 |
oooooo
53
Rep 320
Ask the dealer for the actual service records that show what has been done to the car. I passed on an MG M2 in Atlanta that had a similar clutch replacement listed on the carfax. Turned out the service records told a story of other drive line items being replaced and a reoccurring vibration. The owner brought the car in several times and parts were replaced. Eventually he traded it in. I ran away from that deal!
2011 135i - Gone but not forgotten | 2017 M2 - Powering out of a corner near you!
07-16-2019, 09:54 AM | #3 |
756
Rep 2,149
I agree with the other guy to ask for the service records. Usually they include an owner comment about why they are bringing it in and what they are doing to diagnose/fix the issue. For example "customer noted noise in front suspension. Inspecting components and retorquing bolts" or something like that, which will help you understand better.
Other interesting things to me is the vehicle was registered in June, then again in August. Does that mean there were two owners previously? Also interesting the brake fluid was changed at 1,580mi. I wonder why? I assume it was there for it's break-in service, but clutch and brake fluid replacement isn't part of that, as far as I recall. For the "duplicate title issued" it makes me wonder if the car was repossessed. Also front brakes and battery replaced at 3,562mi. That's not normal. Maybe the owner purchased the car, lost his job, knew it was gonna get repossessed, then drove it hard cause he knew he wasn't gonna have it much longer. Maybe did something to kill the battery to make it harder on the tow truck drive from picking it up. Well, know that I'm thinking more. If the car was repossessed, they wouldn't need to issue a duplicate title, because the bank would have the title not the owner. I was thinking the car was repossessed and the owner had the title in his house, so it was never recovered. Which doesn't make sense. Did the previous owner/s purchase the car outright? Just some thoughts/questions that I have. |
07-16-2019, 03:32 PM | #4 |
Rep 1,485
the owner probably raced it...clutch replacement and brake replacement under 5k miles. He probably tracked it on stock pads and wasnt too easy on the clutch while tracking. There's a enough og m2s to look for a better condition one...unless your getting a smoking deal.
Yellowflash21369.50 |
07-17-2019, 07:59 AM | #5 |
Rep 135
Thanks for all the input guys, going to the dealer today to ask for the service records. Maybe that will give more insight.
